Is it possible to change the spacing of the entities in a picture glance. I want to equally divide the icons and prevent that the state will be cut off like in the example.
@nelbs, Did you ever figure this out? Trying to do the same thing. My values are all cut off…and there is so much available room.
Unfortunately not
Check if this helps:
Warning: haven’t checked this code after 2021.12.
