I am very new to Homeassistant and have just installed the SSH Terminal. The problem is that the font is almost unreadable on my system (not the size but the font style!). Is there a straightforward method to change it?
This has been on for a while, see Font lost right pixel column or two in HA terminal UI
However, it looks like it is a browser-specific issue. Try to disable fingerprinting block in your browser.
In Brave:
Not sure about other browsers.
In my case it was the “Duck Duck Go Privacy Essentials” extension.
The fact this showed up only when accessing HA from my domain and not the IP should have tipped me off…
Thanks!
Yes, same here, thanks for finding it!
I confirm that disabling “duck duck go” protections for the site restores the correct font.
Curious, though, what is it that DuckDuckGo does to result in broken fonts?
