poudenes
(Poudenes)
May 1, 2019, 6:36am
1
Hi All,
Can you change status of switch, input boolean, text device using a http link?
In Domoticz you can send commands using API. I use this lot of time and want do this as well in HA… when I want change from Domoticz to HA for me a important thing.
Can someone assist me?
Thats what you’re looking for I guess
~~https://developers.home-assistant.io/docs/en/external_api_rest.html#post-api-services-lt-domain-lt-service~~ q12021 dead link updated link:
REST API | Home Assistant Developer Docs
edit 2021
web-hooks should work out too, but it is not as mighty, this can be either good or bad.
Automation Trigger - Home Assistant
this is a very good tasker template when you want to use an android phone
Thanks for offering some guidance, but I’m not familiar with using GitHub and don’t really have the bandwidth to learn another source code control system at the moment. I was (perhaps naively) expecting the process of submitting an example to be a little simpler, but I do understand the reasoning behind it.
I have mocked up a valid RestAPICallExample.tsk.xml attached below with the description export blockquoted in case it is of use: .
RestAPICallExample.tsk.xml (1.6 KB)
RestAPICallExample (3…
The next thing you could set up is a webhook (never used it - so no info from my side)
but keep in mind that you want to keep your setup secure
