What is the best method to change the Attribute Report conditions for a Zigbee Temperature sensor from within Home Assistant.
I would like to accellerate reporting to improve regulation of a Generic Thermostat built with a Zigbee Temperature Sensor and a Relay controlling the Electric heater.
In the ZHA integration, the reporting for a temperature sensor is set to 0.5°C
class TemperatureMeasurement(ZigbeeChannel):
"""Temperature measurement channel."""
REPORT_CONFIG = [
"attr": "measured_value",
"config": (REPORT_CONFIG_MIN_INT, REPORT_CONFIG_MAX_INT, 50),
while for the Thermostat it is set to 0.25°C
REPORT_CONFIG_CLIMATE = (REPORT_CONFIG_MIN_INT, REPORT_CONFIG_MAX_INT, 25)
class ThermostatChannel(ZigbeeChannel):
"""Thermostat channel."""
REPORT_CONFIG = (
{"attr": "local_temp", "config": REPORT_CONFIG_CLIMATE},
I see that reporting is configured from REPORT_CONFIG in the ZigbeeChannel base class inside “configure_reporting”.
I suppose that right now these can’t be overridden unless using a local copy of the zha component and modify it. And that after modifying the code, the initialisation of it is not clear: at startup or upon new
initialisation…
