Change ZigBee channel in ZHA?
I’m using ZHA now for my remotes only, but i need to find out what channel it is running on to ensure that theres no interference from my other zigbee hub running the lights. How can i see that? Is there a default channel its using? And how do i change it?
Hi @Da9L,
Did you ever get any further information on changing channel and determining the current channel?
See Update zha.markdown with note about changing Zigbee channel by Hedda · Pull Request #18865 · home-assistant/home-assistant.io · GitHub
Nope i went back to using deCONZ. Had some other wierd behavior with ZHA, but i think I’ve managed to get deCONZ to work properly now
Thanks for responding. I actually managed to get some help from DeCONZ in the end and posted how I went about making the change here if you are interested.
I’m sticking with ZHA for now, but must admit, I was very tempted to drop it and switch to DeCONZ.
