Hey there
I’m looking to add a generic ip camera to my HA setup. Without spending much money, what is the cheapest option for a generic wifi ip camera? I really just want it for images not so much video, but in the future I might. Where I want to place it, it doesn’t have access to wires LAN.
Any suggestions?
Hello. You can buy any ip cam around 25/30 eur…are good for you want. I have a tenvis had a good wifi and works very good.
Example:
Hot! wanscam hw0024 ip ptz câmera wi-fi hd 720 p dual audio P2P Baby Monitor Remoto IR-Cut câmera de Vigilância Wi-fi Câmera IP Interno Cam
http://s.aliexpress.com/6RFvYv6F
(from AliExpress Android)
gpbenton
(Graham)
February 13, 2017, 8:08am
3
If you have an old android phone you can try this
tl:dr
Here’s an example HA configuration for using the Android IP Webcam app as an IP camera, a switch for the device’s flash, and an example to poll the motion sensor data which is continually generated and published to the app’s HTTP interface. On the Android app side, download and install the app, configure the video settings and sensor data and start the server. HA config:
IP Camera
camera:
- platform: mjpeg
mjpeg_url: http://IP.ADDRESS:8080/video
name: My Android Camera
Switch to togg…
I bought Keekoon on sale around 40Euro. Is that cheap enough? They are excellent so far
Then Xiaomi square at around 30Euro, but is good with Mi Home app, neet to be hacked for working with HASS (have not dome it yet)
hangy
(Angelo La Mazza)
February 13, 2017, 1:30pm
5
i also want to buy a square one but i think it’s not usable with HA… i’ve also the 360 mija (from xiaomi) and don’t work…
you may try this (not tested )
costr
(Adam Costenbader)
June 21, 2017, 3:42pm
7
Another option is to purchase a Raspberry Pi Z W and a camera module. If you really want to get fancy you can 3D print a case for it too.
Note: It’ll be static and night vision view will cost more.
If you can get to a MicroCenter you can purchase the Raspberry Pi Zero W for $10(USD). The camera module you can get on Amazon for about $15(USD).
Alternatively you take that old USB camera out of the the junk drawer and hook it up to a Raspberry Pi and run it as an IP camera.
Tribune
October 14, 2017, 12:10pm
8
I am also looking into extending my HASS setup with a wifi camera. I would be interested in some reviews of the cameras in the price range of 20 - 40 €.
Bananaskin
(Michael Wilson)
December 9, 2017, 10:30am
9
anon35356645:
Keekoon
Claudio what model of Keekoon did you get and are there options to control Pan/Tilt in HA?
Kk003
Its PT not zoom. You can easily use presets in HASS. Also PT but to make a nice user interface is possible but difficult (for me)
macinr
(Macin)
December 28, 2017, 9:07am
11
Hi Guys,
Found something like this:
http://s.aliexpress.com/jIBju6zA
It is appealing as it does not need any additional wiring. Anyone tried this one with HA? Or could recommend similar fisheye bulb camera that could work with HA?
davedan
(Dave Dan)
December 28, 2017, 9:36am
12
I personally like very much the D-Link DCS-932L, have some at home and never had an issue. I just bought this one by 47€ (50’ish $?? didn’t check in the US store)
Did you purchase the wanscam hw0024, I but am having trouble configuring it in configuration.yami. Do you have any details on how to configure things. Thanks in advance.
Timeout getting camera image
camera:
platform: generic
ip: 192.168.2.33
port: 80
username: user
password: user
davedan
(Dave Dan)
May 4, 2018, 8:30am
16
This is how I have it in my configuration:
If you access to the cam web can you see the stream?
Hi, Thanks for your comment.
This is now the setup, but i got the error no image available.
platform: generic
mjpeg_url: http://192.168.2.33/video.cgi
still_image_url: http://192.168.2.33/image/jpeg.cgi
username: user
password: xxxxxxxx
When i’m using this setup:
I’ve got the image what is refreshing every 10 seconds. but i’d rather have live video.
greetings justin
davedan
(Dave Dan)
May 4, 2018, 10:05am
18
if you acccess to the cam website … can you see the feed?
I must say I’m having similar issues but with another cam …
If i login i get 3 choises (see image)
When i choose the first it will open the cam page in flash. I dont know how to see the feed
When i choose the second it will be a small image. I use that adress now but it has the problem that it isn’t live but refreshing every 10 seconds
When i choose for the third option it said Plugin isn’t supported:(
greetings justin
yottatsa
(Atsuko Ito)
July 1, 2018, 10:38pm
20
Could you please try open http://192.168.2.33/config/stream_info.cgi in your browser? It should contain links to the actual streams.
yottatsa$ curl -u admin:### http://192.168.1.7/config/stream_info.cgi
videos=MJPEG
resolutions=640x480,320x240,160x120
vprofilenum=1
vprofile1=MJPEG
vprofileurl1=/video.cgi
vprofileres1=640x480
vDprofileurl1=/dgvideo.cgi
aprofilenum=1
aprofile1=PCM
aprofileurl1=/audio.cgi
aDprofileurl1=/dgaudio.cgi
