Yeah it’s wierd. The only thing I havent’ done is default the Cielo Breeze Lite. Can you explain to me how the integration works? Does it need the Cielo Breeze Lite at all? Or does it connect to the Cielo servers and go from there? I am getting info from the Cielo website. IE: I change a name of the one device I have and it shows up in the HA. Just trying to figure this out.
So the mobile app connects to the Cielo Breeze device on my local network which connects to the Mr Cool. The HA app does the same? The Breeze Lite controls the Mr Cool from both the mobile app and the HA app ??
@edlentz let me rephrase that. The only communication is HA to the Cielo server, no local communication at all. For Mr Cool part i couldn’t say ! Probably the same if for some people my integration work on their Mr Cool HAVC.
@bodyscape I can control it, bur functionality only show on/off and temp. Not the full set of option I’d expect like mode (heat/cool/auto/dry/…) or fan etc.
Not sure how best to pull logs for you, but would be happy to if you point me in the right direction.
Any idea why the integration shows constant changes/events, even though nothing happens. The screenshot on the GitHub installation shows similar behavior! My logbook shows 7 changes within the same second. (screenshot). This is connected to a generic Mini Split, sold as Mr Cool and numerous other names.
@cvanover7 sorry i can’t help you for Mr Cool integration. I made this one for Cielo Home. I don’t know why some people said this work on Mr Cool, no idea how Mr Cool work.
This is for Cielo. There are numerous AC unit manufactures, such as Mr Cool, but the question is for Cielo and Mr Cool is an AC brand that is certified by Cielo.
I can confirm this works with MrCool units. I have this functioning with a multi-zone unit. Only feature missing is the ability to enable Freeze Protection mode. Thank you for this integration!
I can connect to Cielo, but I have very limited functionality. I am getting a couple errors and I wonder if that’s the cause.
Logger: homeassistant.components.climate
Source: custom_components/cielo_home/cielohomedevice.py:411
Integration: Climate (documentation, issues)
First occurred: 9:14:08 PM (6 occurrences)
Last logged: 9:35:51 PM
Error while setting up cielo_home platform for climate
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 320, in _async_setup_platform
await asyncio.shield(task)
File "/config/custom_components/cielo_home/climate.py", line 49, in async_setup_entry
entity = CieloHomeThermostat(device)
File "/config/custom_components/cielo_home/climate.py", line 108, in __init__
self._update_internal_state()
File "/config/custom_components/cielo_home/climate.py", line 162, in _update_internal_state
self._attr_swing_mode = self._device.get_swing_mode()
File "/config/custom_components/cielo_home/cielohomedevice.py", line 563, in get_swing_mode
if self.get_swing() == "auto":
File "/config/custom_components/cielo_home/cielohomedevice.py", line 411, in get_swing
return self._device["latestAction"]["swing"]
KeyError: 'swing'
