Hi there all,
someone can tell me if it’s possible to change the MQTT ClientID
of integrated MQTT in Hassio please ?
Thanks in advance
Denis
Hi there all,
Thanks in advance
Denis
Nope. Why?
Cause I have some problem with some MQTT topics
and every time that I reload the integrated Hassio MQTT
it take another ClienID and on the large log files (debug)
every time I must looking to the MQTT connection in order to find the ClientID.
Before was easy (MQTT declared in configuration.yaml)
cause there was an option like “client_id: home-assistant”
With the integrated MQTT I didn’t find.
The other reason is that usually every MQTT client (Tasmota, NodeMCU, ESP32 etc…)
have an option to set the MQTT ClientID,
so I think will be beautiful to have it also in the integrated MQTT
Denis
Request it here:
https://community.home-assistant.io/c/feature-requests/
Also it has not been called hassio for a year now.
Ok thanks a lot … I just made a request
How Home Assistant is named now please ? …just HASS ?
Thanks again
Denis
Home Assistant is a home automation operating system for your home. And to make this message clear, we’re renaming Hass.io to Home Assistant
