Can you please share an example of the configuration.yaml? I am not sure how to configure the airconwithme part to use the API… Like, do you need to confige the IP instead of the credentials?
Deze fout is ontstaan door een aangepaste integratie.
Logger: homeassistant
Source: custom_components/intesishome/climate.py:172
Integration: intesishome
First occurred: 21:57:03 (1 occurrences)
Last logged: 21:57:03
Error doing job: Task exception was never retrieved
File "/config/custom_components/intesishome/climate.py", line 172, in async_setup_platform
await controller.poll_status()
File "/usr/local/lib/python3.9/site-packages/pyintesishome/intesishomelocal.py", line 155, in poll_status
await self._authenticate()
File "/usr/local/lib/python3.9/site-packages/pyintesishome/intesishomelocal.py", line 62, in _authenticate
response = await self._request(
File "/usr/local/lib/python3.9/site-packages/pyintesishome/intesishomelocal.py", line 74, in _request
async with self._web_session.post(
File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 1138, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 559, in _request
await resp.start(conn)
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 898, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.9/site-packages/aiohttp/streams.py", line 616, in read
await self._waiter
aiohttp.client_exceptions.ServerDisconnectedError: Server disconnected
Can anybody tell me how to install this? I was not able to find a location to download the files and can also not find intesis as integration within HACS
I also tried to create folder/files manually in file editor but alson does not work.
The Intesis integration comes with the standard Home Assistant installation.
First create a userid / password using the Airconwithme application.
Then use the userid / password to configure Home Assistant using the instructions in IntesisHome - Home Assistant
And try to remove the line starting a with “device:” and restart Home Assistant.
You know you can check your YAML config file in Developer Tools / YAML?
Update: When I again add the line starting a with “device:” - The correct status is shown, but I can still not see my devices via “Settings / devices & services”.
I checked my configuration. My airco is only listed as an entity, and it is not in the device list. I guess it’s meant to be that way (and I made a mistake referring you to the devices page)
