Hi Team,
I have been trying to debug this for days but still not entirely successful. I have an Air Conditioner controller that is able to take json post requests. I have read the manual and been able to write a short python script that can control the unit and read store the system information. Once I had this working I tried to integrate it with the Broadlink IR Climate Custom Component Broadlink IR Climate Component. I have it working to a point where I can select temp and mode then see that the selected settings in the home-assistant.log.
Unfortunately, the AC Controller (iZone) is not accepting the post request when it is inside the custom_component script like it does when I use exactly the same commands in the python test script.
Here is the test code that is working perfectly. I have never learnt Python so there are likely much better ways to achieve the same result but it does work:
# https://linuxconfig.org/how-to-parse-data-from-json-into-python
import json
import requests
# defining the endpoint
onENDPOINT = "http://192.168.0.139/SystemON" #{"SystemON":"x"} "on" "off"
SetPointENDPOINT = "http://192.168.0.139/UnitSetpoint" #{"SystemON":"x"} "on" "off"
ModeENDPOINT = "http://192.168.0.139/SystemMODE" # {"SystemMODE":"x"} "cool" "heat" "vent" "dry" "auto"
SettingsENDPOINT = "http://192.168.0.139/SystemSettings"
dataOn = {"SystemON":"off"}
dataTemp = {'UnitSetpoint':'23'}
dataMode = {"SystemMODE":"vent"}
# sending post request and saving response as response object
r = requests.post(url = onENDPOINT, json= dataOn)
r = requests.post(url = ModeENDPOINT, json= dataMode)
r = requests.post(SetPointENDPOINT, json= dataTemp)
print("Response:")
print(r.url)
print(r.status_code)
rx = requests.post(SettingsENDPOINT)
#format AC response into new line for each parameter
loaded_json = json.loads(rx.text)
for x in loaded_json:
print("%s: %s" % (x, loaded_json[x]))
# store each value into an object
class sysInfo(object):
def __init__(self, data):
self.__dict__ = json.loads(rx.text)
acInfo = sysInfo(rx.text)
SystemOn = acInfo.SysOn
SetPoint = acInfo.Setpoint
FanSpeed = acInfo.SysFan
print(SetPoint)
And here is the panasonic.py code that is only 50% working but not actually changing the state of the AC Control: The code that i have been playing with is inside the "def send_izone(self): " function.
import json
# importing the requests library
import requests
import asyncio
import logging
import binascii
import socket
import os.path
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.core import callback
from homeassistant.components.climate import (ClimateDevice, PLATFORM_SCHEMA, STATE_OFF, STATE_IDLE, STATE_HEAT, STATE_COOL, STATE_AUTO,
ATTR_OPERATION_MODE, SUPPORT_OPERATION_MODE, SUPPORT_TARGET_TEMPERATURE, SUPPORT_FAN_MODE)
from homeassistant.const import (ATTR_UNIT_OF_MEASUREMENT, ATTR_TEMPERATURE, CONF_NAME, CONF_HOST, CONF_TIMEOUT, CONF_CUSTOMIZE)
from homeassistant.helpers.event import (async_track_state_change)
from homeassistant.helpers.restore_state import RestoreEntity
from configparser import ConfigParser
from base64 import b64encode, b64decode
REQUIREMENTS = ['broadlink==0.9.0']
_LOGGER = logging.getLogger(__name__)
SUPPORT_FLAGS = SUPPORT_TARGET_TEMPERATURE | SUPPORT_OPERATION_MODE | SUPPORT_FAN_MODE
#CONF_IRCODES_INI = 'ircodes_ini'
CONF_MIN_TEMP = 'min_temp'
CONF_MAX_TEMP = 'max_temp'
CONF_TARGET_TEMP = 'target_temp'
CONF_TARGET_TEMP_STEP = 'target_temp_step'
CONF_TEMP_SENSOR = 'temp_sensor'
CONF_OPERATIONS = 'operations'
CONF_FAN_MODES = 'fan_modes'
CONF_DEFAULT_OPERATION = 'default_operation'
CONF_DEFAULT_FAN_MODE = 'default_fan_mode'
CONF_DEFAULT_OPERATION_FROM_IDLE = 'default_operation_from_idle'
DEFAULT_NAME = 'Broadlink IR Climate'
DEFAULT_TIMEOUT = 10
DEFAULT_RETRY = 3
DEFAULT_MIN_TEMP = 16
DEFAULT_MAX_TEMP = 30
DEFAULT_TARGET_TEMP = 20
DEFAULT_TARGET_TEMP_STEP = 1
DEFAULT_OPERATION_LIST = [STATE_OFF, STATE_HEAT, STATE_COOL, STATE_AUTO]
DEFAULT_FAN_MODE_LIST = ['low', 'mid', 'high', 'auto']
DEFAULT_OPERATION = 'off'
DEFAULT_FAN_MODE = 'auto'
OnENDPOINT = "http://192.168.0.139/SystemON" #{"SystemON":"x"} "on" "off"
dataOn = {"SystemON":"on"}
dataTemp = {"UnitSetpoint":"23"}
CUSTOMIZE_SCHEMA = vol.Schema({
vol.Optional(CONF_OPERATIONS): vol.All(cv.ensure_list, [cv.string]),
vol.Optional(CONF_FAN_MODES): vol.All(cv.ensure_list, [cv.string])
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Required(CONF_HOST): cv.string,
# vol.Required(CONF_MAC): cv.string,
# vol.Required(CONF_IRCODES_INI): cv.string,
vol.Optional(CONF_TIMEOUT, default=DEFAULT_TIMEOUT): cv.positive_int,
vol.Optional(CONF_MIN_TEMP, default=DEFAULT_MIN_TEMP): vol.Coerce(float),
vol.Optional(CONF_MAX_TEMP, default=DEFAULT_MAX_TEMP): vol.Coerce(float),
vol.Optional(CONF_TARGET_TEMP, default=DEFAULT_TARGET_TEMP): vol.Coerce(float),
vol.Optional(CONF_TARGET_TEMP_STEP, default=DEFAULT_TARGET_TEMP_STEP): vol.Coerce(float),
vol.Optional(CONF_TEMP_SENSOR): cv.entity_id,
vol.Optional(CONF_CUSTOMIZE, default={}): CUSTOMIZE_SCHEMA,
vol.Optional(CONF_DEFAULT_OPERATION, default=DEFAULT_OPERATION): cv.string,
vol.Optional(CONF_DEFAULT_FAN_MODE, default=DEFAULT_FAN_MODE): cv.string,
vol.Optional(CONF_DEFAULT_OPERATION_FROM_IDLE): cv.string
async def async_setup_platform(hass, config, async_add_devices, discovery_info=None):
"""Set up the Broadlink IR Climate platform."""
name = config.get(CONF_NAME)
ip_addr = config.get(CONF_HOST)
# mac_addr = binascii.unhexlify(config.get(CONF_MAC).encode().replace(b':', b''))
min_temp = config.get(CONF_MIN_TEMP)
max_temp = config.get(CONF_MAX_TEMP)
target_temp = config.get(CONF_TARGET_TEMP)
target_temp_step = config.get(CONF_TARGET_TEMP_STEP)
temp_sensor_entity_id = config.get(CONF_TEMP_SENSOR)
operation_list = config.get(CONF_CUSTOMIZE).get(CONF_OPERATIONS, []) or DEFAULT_OPERATION_LIST
fan_list = config.get(CONF_CUSTOMIZE).get(CONF_FAN_MODES, []) or DEFAULT_FAN_MODE_LIST
default_operation = config.get(CONF_DEFAULT_OPERATION)
default_fan_mode = config.get(CONF_DEFAULT_FAN_MODE)
default_operation_from_idle = config.get(CONF_DEFAULT_OPERATION_FROM_IDLE)
async_add_devices([
BroadlinkIRClimate(hass, name, min_temp, max_temp, target_temp, target_temp_step, temp_sensor_entity_id, operation_list, fan_list, default_operation, default_fan_mode, default_operation_from_idle)
class BroadlinkIRClimate(ClimateDevice, RestoreEntity):
def __init__(self, hass, name, min_temp, max_temp, target_temp, target_temp_step, temp_sensor_entity_id, operation_list, fan_list, default_operation, default_fan_mode, default_operation_from_idle):
"""Initialize the Broadlink IR Climate device."""
self.hass = hass
self._name = name
self._min_temp = min_temp
self._max_temp = max_temp
self._target_temperature = target_temp
self._target_temperature_step = target_temp_step
self._unit_of_measurement = hass.config.units.temperature_unit
self._current_temperature = 0
self._temp_sensor_entity_id = temp_sensor_entity_id
self._current_operation = default_operation
self._current_fan_mode = default_fan_mode
self._operation_list = operation_list
self._fan_list = fan_list
self._default_operation_from_idle = default_operation_from_idle
if temp_sensor_entity_id:
async_track_state_change(
hass, temp_sensor_entity_id, self._async_temp_sensor_changed)
sensor_state = hass.states.get(temp_sensor_entity_id)
if sensor_state:
self._async_update_current_temp(sensor_state)
_LOGGER.error("Send data to iZone")
section = self._current_operation.lower()
if section == 'idle':
# value = 'off_command'
jsonOn = {'SystemON':'off'}
r = requests.post('http://192.168.0.139/SystemON', json = {'SystemON':'off'},timeout=1)
_LOGGER.error("Sending command [%s] to %s", jsonOn, self._name)
else:
jsonTemp = {'UnitSetpoint':'{0:g}'.format(float(self._target_temperature))}
jsonMode = {'SystemMODE':self._current_fan_mode.lower()}
jsonOn = {'SystemON':'on'}
_LOGGER.error("Sending command [%s %s] to %s", jsonTemp, jsonMode, self._name)
# r = requests.post('http://192.168.0.139/UnitSetpoint', json= {'UnitSetpoint':'27'}, timeout=1)
r = requests.post(SetPointENDPOINT, json= jsonTemp,timeout=1)
_LOGGER.error(r.url)
_LOGGER.error(r.status_code)
r = requests.post(url = ModeENDPOINT, json= jsonMode,timeout=1)
# r = requests.post('http://192.168.0.139/SystemON', json = {'SystemON':'on'},timeout=1)
r = requests.post(OnENDPOINT, json= jsonOn, timeout=1)
_LOGGER.error(rx.url)
_LOGGER.error("%s: %s" % (x, loaded_json[x]))
Mode = acInfo.SysMode
_LOGGER.error(SetPoint)
async def _async_temp_sensor_changed(self, entity_id, old_state, new_state):
"""Handle temperature changes."""
if new_state is None:
return
self._async_update_current_temp(new_state)
await self.async_update_ha_state()
@callback
def _async_update_current_temp(self, state):
"""Update thermostat with latest state from sensor."""
unit = state.attributes.get(ATTR_UNIT_OF_MEASUREMENT)
try:
_state = state.state
if self.represents_float(_state):
self._current_temperature = self.hass.config.units.temperature(
float(_state), unit)
except ValueError as ex:
_LOGGER.error('Unable to update from sensor: %s', ex)
def represents_float(self, s):
try:
float(s)
return True
except ValueError:
return False
@property
def should_poll(self):
"""Return the polling state."""
return False
@property
def name(self):
"""Return the name of the climate device."""
return self._name
@property
def temperature_unit(self):
"""Return the unit of measurement."""
return self._unit_of_measurement
@property
def current_temperature(self):
"""Return the current temperature."""
return self._current_temperature
@property
def min_temp(self):
return self._min_temp
@property
def max_temp(self):
return self._max_temp
@property
def target_temperature(self):
"""Return the temperature we try to reach."""
return self._target_temperature
@property
def target_temperature_step(self):
"""Return the supported step of target temperature."""
return self._target_temperature_step
@property
def current_operation(self):
"""Return current operation ie. heat, cool, idle."""
return self._current_operation
@property
def operation_list(self):
"""Return the list of available operation modes."""
return self._operation_list
@property
def current_fan_mode(self):
"""Return the fan setting."""
return self._current_fan_mode
@property
def fan_list(self):
"""Return the list of available fan modes."""
return self._fan_list
@property
def supported_features(self):
"""Return the list of supported features."""
return SUPPORT_FLAGS
def set_temperature(self, **kwargs):
"""Set new target temperatures."""
if kwargs.get(ATTR_TEMPERATURE) is not None:
self._target_temperature = kwargs.get(ATTR_TEMPERATURE)
if not (self._current_operation.lower() == 'off' or self._current_operation.lower() == 'idle'):
self.send_izone()
elif self._default_operation_from_idle is not None:
self.set_operation_mode(self._default_operation_from_idle)
self.schedule_update_ha_state()
def set_fan_mode(self, fan):
"""Set new target temperature."""
self._current_fan_mode = fan
self.send_izone()
def set_operation_mode(self, operation_mode):
self._current_operation = operation_mode
self.send_izone()
async def async_added_to_hass(self):
"""Run when entity about to be added."""
await super().async_added_to_hass()
last_state = await self.async_get_last_state()
if last_state is not None:
self._target_temperature = last_state.attributes['temperature']
self._current_operation = last_state.attributes['operation_mode']
self._current_fan_mode = last_state.attributes['fan_mode']
Thanks in anticipation and hopefully this might also help someone else once it is solved!
Also: the lines 174 to 194 seem to be working perfectly and pull data from the AC controller. It is just getting the controller to accept the “r = requests.post(SetPointENDPOINT, json= jsonTemp,timeout=1)” that seems to be causing the bigest problem.
