Hello
I had implemented a mqtt climate control and discovered a nifty feature - Whenever I switch on AC, the graph shows up as solid color.(ie, the time it is on, the graph is solid color - else its just lines)
Here is the yaml for mqtt climate
climate:
- name: "Lounge"
availability_topic: "tele/tasmota_95D644/LWT"
payload_available: "Online"
payload_not_available: "Offline"
current_temperature_topic: "tele/tasmota_95D644/SENSOR"
current_temperature_template: "{{ value_json.MiElHVAC.Temperature }}"
precision: 0.5
temperature_state_topic: "tele/tasmota_95D644/HVACSETTINGS"
temperature_state_template: "{{ value_json.Temp }}"
temperature_unit: "C"
temp_step: 0.5
min_temp: 16
max_temp: 31
temperature_command_topic: "cmnd/tasmota_95D644/HVACSetTemp"
mode_state_topic: "tele/tasmota_95D644/HVACSETTINGS"
mode_state_template: "{{ value_json.HAMode }}"
modes:
- "off"
- "auto"
- "dry"
- "cool"
- "fan_only"
mode_command_topic: "cmnd/tasmota_95D644/HVACSetHAMode"
fan_mode_state_topic: "tele/tasmota_95D644/HVACSETTINGS"
fan_mode_state_template: "{{ value_json.Fan }}"
fan_modes:
- "auto"
- "1"
- "2"
- "3"
fan_mode_command_topic: "cmnd/tasmota_95D644/HVACSetFan"
I have also implemented climate control using KNX.
For each climate control, I have a KNX address which can tell if fan controller is on of off. What additional data I need to add in this code to see the graphs as solid color when its on?
Here is the KNX climate -
#Passage AC
- name: "1st Floor passage AC"
on_off_address: "3/1/65"
temperature_address: "3/1/68"
target_temperature_address: "3/1/160"
target_temperature_state_address: "3/1/69"
operation_mode_night_address: "3/1/161"
operation_mode_comfort_address: "3/1/162"
default_controller_mode: cool
on_off_state_address: "3/1/70"
min_temp: 18.0
max_temp: 26.0
