So, the basis of my smart home is a KNX system. I’ve got wall switches with built-in thermostats in every room.
I’ve got everything configured in Home Assistant via the KNX integration as follows:
climate:
- name: bathroom
target_temperature_address: 2/1/0
on_off_address: 2/4/0
temperature_address: 6/2/1
target_temperature_state_address: 3/1/0
on_off_state_address: 3/2/0
operation_mode_state_address: 3/4/1
The operation mode is moot, but I’ve got the group address set up. The boiler actually is in a ‘dumb’ state. It gets a signal to supply heat when at least one of the valves is open.
The problem comes when the room reaches the temperature setpoint.
In KNX it works as follows: setpoint is set at target temperature > thermostat heats until target is reached and will keep the temperature around the target by closing/opening the valves and sending a signal to the boiler to heat when needed.
Home Assistant does the following: setpoint is set > thermostat heats until setpoint temperature is reached > Home Assistant SHUTS OFF the Climate entity (and thus the KNX thermostat) > setpoint is cleared.
The thermostat is never turned back on unless a new setpoint is set that’s higher then the room temperature.
I don’t understand why the HA Climate entity behaves this way. If I want a room a certain temperature, I don’t want it there for a second and then never again.
Have I set this up wrong?
