Clock Skew Hadashboard V2
Posting here as I cant find anything about it in any other posts on how to resolve this
I have run the non docker install, I ran through by cloning the repository to the location in the instructions then ran the following
pip3 install daemonize
$ pip3 install configparser
$ pip3 install astral
$ pip3 install 'requests>=2.6.0'
$ pip3 install sseclient
$ pip3 install websocket-client
$ pip3 install async
$ pip3 install 'aiohttp>=2.0.5'
$ pip3 install Jinja2==2.9.5
$ pip3 install aiohttp_jinja2
$ pip3 install pyScss
$ pip3 install pyyaml
$ pip3 install voluptuous
I then updated my config file as shown and then ran the following command
python3 -m appdaemon.appdaemon -c ./conf
I get the following issue
Ive tried the same install again but under centos rather than ubuntu.
And while I don’t get the clock skew any more I don’t get a line that says listening on 0.0.0.0:5050
Am I missing a step in my setup here? I had the same thing on ubuntu if you see the screenshot above, there is no listening ip/port
Hi there - first of all, the clock skew warning is relatively harmless - it just means that something took longer than expected and AppDaemon is catching up. It tends to happen in bursts then it is fine for a while. If it only happens occasionally don;t worry about it.
For the second piece, you need to follow the instructions in DASHBOARD.md to enable the dashboard piece. Specifically, you will need a dashboard_url.
Thank you that solved my problem.
The main instructions made it look like i should have seen the listening URL before following the DASHBOARD.md file which is why I didn’t progress further to reading it.
Thanks again
i must say that i get it more often again lately and it gets annoying if the warning pushes away all relevant info.
half of the time it stayes annoying to long for me and i and up restarting appdaemon.
it happens every time i restart HA at the moment, for a longer period off time after another.
Have you noticed if it is better/worse when you upgraded to Beta 3? There have been some changes in this area but they should be improving things.
i dont know exactly at which moment it got worse.
gladly i only notice it when i restart HA.
i know i had almost no trouble with it before i switched to the RPI 3 (and i already had installed beta 3 on my old RPI)
but i also have a broadlink installed since then given HA a bit more work with restarting.
OK, this might happen if you are doing some very long work in your initialize functions but it should be OK after that.
For the record (in case it matters), I haven’t seen this error at all and I just did a pull of the latest testing code - still not seeing it.
might be because i did implement the dependencies recently.
yeah initialize takes some time, but it happens after the initialize.
and it holds on for some time (up to a minute) and generates the warning at some point several times every second.
leaving me with a screen with nothing but those warnings, and everything else wiped out.
What sort of delta values are you seeing?
ill try to catch it for you the next time.
i dont want to start to get on te nerves from my wife on eastern :wink:
oke, i needed a restart and collected the data for you.
i have seen longer lists but it gets you an idea.
2017-04-17 14:59:31.145546 WARNING Scheduler clock skew detected - delta = 1.8545830249786377 - resetting
2017-04-17 14:59:31.219102 WARNING Scheduler clock skew detected - delta = 1.781022071838379 - resetting
2017-04-17 14:59:31.301403 WARNING Scheduler clock skew detected - delta = 1.6988680362701416 - resetting
2017-04-17 14:59:31.374168 WARNING Scheduler clock skew detected - delta = 1.6259560585021973 - resetting
2017-04-17 14:59:31.464021 WARNING Scheduler clock skew detected - delta = 1.5360939502716064 - resetting
2017-04-17 14:59:31.534373 WARNING Scheduler clock skew detected - delta = 1.4657480716705322 - resetting
2017-04-17 14:59:31.617633 WARNING Scheduler clock skew detected - delta = 1.382491111755371 - resetting
2017-04-17 14:59:31.693536 WARNING Scheduler clock skew detected - delta = 1.306588888168335 - resetting
2017-04-17 14:59:31.765121 WARNING Scheduler clock skew detected - delta = 1.2350029945373535 - resetting
2017-04-17 14:59:31.840787 WARNING Scheduler clock skew detected - delta = 1.1593480110168457 - resetting
2017-04-17 14:59:31.913455 WARNING Scheduler clock skew detected - delta = 1.0866749286651611 - resetting
2017-04-17 14:59:31.986577 WARNING Scheduler clock skew detected - delta = 1.013545036315918 - resetting
2017-04-17 14:59:32.125127 WARNING Scheduler clock skew detected - delta = 1.8749899864196777 - resetting
2017-04-17 14:59:32.195361 WARNING Scheduler clock skew detected - delta = 1.8047668933868408 - resetting
2017-04-17 14:59:32.269453 WARNING Scheduler clock skew detected - delta = 1.7307219505310059 - resetting
2017-04-17 14:59:32.345071 WARNING Scheduler clock skew detected - delta = 1.6550519466400146 - resetting
2017-04-17 14:59:32.416616 WARNING Scheduler clock skew detected - delta = 1.583509922027588 - resetting
2017-04-17 14:59:32.489867 WARNING Scheduler clock skew detected - delta = 1.5102589130401611 - resetting
2017-04-17 14:59:32.561761 WARNING Scheduler clock skew detected - delta = 1.4383649826049805 - resetting
2017-04-17 14:59:32.634478 WARNING Scheduler clock skew detected - delta = 1.3656470775604248 - resetting
2017-04-17 14:59:32.706004 WARNING Scheduler clock skew detected - delta = 1.294118881225586 - resetting
2017-04-17 14:59:32.779233 WARNING Scheduler clock skew detected - delta = 1.2208969593048096 - resetting
2017-04-17 14:59:32.850441 WARNING Scheduler clock skew detected - delta = 1.1496880054473877 - resetting
2017-04-17 14:59:32.923079 WARNING Scheduler clock skew detected - delta = 1.0770440101623535 - resetting
2017-04-17 14:59:33.081246 WARNING Scheduler clock skew detected - delta = 1.9188671112060547 - resetting
2017-04-17 14:59:33.161002 WARNING Scheduler clock skew detected - delta = 1.839245080947876 - resetting
2017-04-17 14:59:33.251558 WARNING Scheduler clock skew detected - delta = 1.7485580444335938 - resetting
2017-04-17 14:59:33.327178 WARNING Scheduler clock skew detected - delta = 1.6729469299316406 - resetting
2017-04-17 14:59:33.407476 WARNING Scheduler clock skew detected - delta = 1.5927419662475586 - resetting
2017-04-17 14:59:33.490201 WARNING Scheduler clock skew detected - delta = 1.5100080966949463 - resetting
2017-04-17 14:59:33.565388 WARNING Scheduler clock skew detected - delta = 1.4347479343414307 - resetting
2017-04-17 14:59:33.646418 WARNING Scheduler clock skew detected - delta = 1.3537158966064453 - resetting
2017-04-17 14:59:33.722813 WARNING Scheduler clock skew detected - delta = 1.277311086654663 - resetting
2017-04-17 14:59:33.806143 WARNING Scheduler clock skew detected - delta = 1.193979024887085 - resetting
2017-04-17 14:59:33.880688 WARNING Scheduler clock skew detected - delta = 1.1194350719451904 - resetting
2017-04-17 14:59:33.953520 WARNING Scheduler clock skew detected - delta = 1.0466029644012451 - resetting
2017-04-17 14:59:34.094094 WARNING Scheduler clock skew detected - delta = 1.9060370922088623 - resetting
2017-04-17 14:59:34.165545 WARNING Scheduler clock skew detected - delta = 1.834589958190918 - resetting
2017-04-17 14:59:34.239985 WARNING Scheduler clock skew detected - delta = 1.760133981704712 - resetting
2017-04-17 14:59:34.313731 WARNING Scheduler clock skew detected - delta = 1.6864008903503418 - resetting
2017-04-17 14:59:34.388291 WARNING Scheduler clock skew detected - delta = 1.6118719577789307 - resetting
2017-04-17 14:59:34.472903 WARNING Scheduler clock skew detected - delta = 1.5272939205169678 - resetting
2017-04-17 14:59:34.547414 WARNING Scheduler clock skew detected - delta = 1.4527249336242676 - resetting
2017-04-17 14:59:34.621204 WARNING Scheduler clock skew detected - delta = 1.3789589405059814 - resetting
2017-04-17 14:59:34.696465 WARNING Scheduler clock skew detected - delta = 1.3036589622497559 - resetting
2017-04-17 14:59:34.772583 WARNING Scheduler clock skew detected - delta = 1.2275390625 - resetting
2017-04-17 14:59:34.865574 WARNING Scheduler clock skew detected - delta = 1.1345388889312744 - resetting
2017-04-17 14:59:34.937943 WARNING Scheduler clock skew detected - delta = 1.0621800422668457 - resetting
2017-04-17 14:59:35.088213 WARNING Scheduler clock skew detected - delta = 1.9119179248809814 - resetting
2017-04-17 14:59:35.160163 WARNING Scheduler clock skew detected - delta = 1.8399550914764404 - resetting
2017-04-17 14:59:35.234650 WARNING Scheduler clock skew detected - delta = 1.7654991149902344 - resetting
2017-04-17 14:59:35.319027 WARNING Scheduler clock skew detected - delta = 1.6810860633850098 - resetting
2017-04-17 14:59:35.397949 WARNING Scheduler clock skew detected - delta = 1.6021618843078613 - resetting
2017-04-17 14:59:35.470828 WARNING Scheduler clock skew detected - delta = 1.5292930603027344 - resetting
2017-04-17 14:59:35.544721 WARNING Scheduler clock skew detected - delta = 1.4554119110107422 - resetting
2017-04-17 14:59:35.616361 WARNING Scheduler clock skew detected - delta = 1.3837699890136719 - resetting
2017-04-17 14:59:35.689222 WARNING Scheduler clock skew detected - delta = 1.3109049797058105 - resetting
2017-04-17 14:59:35.762698 WARNING Scheduler clock skew detected - delta = 1.2374250888824463 - resetting
2017-04-17 14:59:35.835035 WARNING Scheduler clock skew detected - delta = 1.1650989055633545 - resetting
2017-04-17 14:59:35.907452 WARNING Scheduler clock skew detected - delta = 1.0926730632781982 - resetting
2017-04-17 14:59:35.980774 WARNING Scheduler clock skew detected - delta = 1.0193500518798828 - resetting
2017-04-17 14:59:36.136743 WARNING Scheduler clock skew detected - delta = 1.8633699417114258 - resetting
2017-04-17 14:59:36.205765 WARNING Scheduler clock skew detected - delta = 1.7943589687347412 - resetting
2017-04-17 14:59:36.278142 WARNING Scheduler clock skew detected - delta = 1.7219829559326172 - resetting
2017-04-17 14:59:36.349219 WARNING Scheduler clock skew detected - delta = 1.6509120464324951 - resetting
2017-04-17 14:59:36.423194 WARNING Scheduler clock skew detected - delta = 1.5769269466400146 - resetting
2017-04-17 14:59:36.494842 WARNING Scheduler clock skew detected - delta = 1.5052869319915771 - resetting
2017-04-17 14:59:36.587510 WARNING Scheduler clock skew detected - delta = 1.4126091003417969 - resetting
2017-04-17 14:59:36.656835 WARNING Scheduler clock skew detected - delta = 1.3432860374450684 - resetting
2017-04-17 14:59:36.745625 WARNING Scheduler clock skew detected - delta = 1.254504919052124 - resetting
2017-04-17 14:59:36.816464 WARNING Scheduler clock skew detected - delta = 1.1836800575256348 - resetting
2017-04-17 14:59:36.895537 WARNING Scheduler clock skew detected - delta = 1.104583978652954 - resetting
2017-04-17 14:59:36.968714 WARNING Scheduler clock skew detected - delta = 1.0314090251922607 - resetting
2017-04-17 14:59:37.114274 WARNING Scheduler clock skew detected - delta = 1.8858370780944824 - resetting
2017-04-17 14:59:37.182985 WARNING Scheduler clock skew detected - delta = 1.8171439170837402 - resetting
2017-04-17 14:59:37.255262 WARNING Scheduler clock skew detected - delta = 1.7448649406433105 - resetting
2017-04-17 14:59:37.330709 WARNING Scheduler clock skew detected - delta = 1.6694180965423584 - resetting
2017-04-17 14:59:37.401640 WARNING Scheduler clock skew detected - delta = 1.5984869003295898 - resetting
2017-04-17 14:59:37.473686 WARNING Scheduler clock skew detected - delta = 1.5264360904693604 - resetting
2017-04-17 14:59:37.545581 WARNING Scheduler clock skew detected - delta = 1.454545021057129 - resetting
2017-04-17 14:59:37.617552 WARNING Scheduler clock skew detected - delta = 1.3825719356536865 - resetting
2017-04-17 14:59:37.689862 WARNING Scheduler clock skew detected - delta = 1.310265064239502 - resetting
2017-04-17 14:59:37.762567 WARNING Scheduler clock skew detected - delta = 1.2375600337982178 - resetting
2017-04-17 14:59:37.834432 WARNING Scheduler clock skew detected - delta = 1.1656908988952637 - resetting
2017-04-17 14:59:37.906447 WARNING Scheduler clock skew detected - delta = 1.0936760902404785 - resetting
2017-04-17 14:59:37.979373 WARNING Scheduler clock skew detected - delta = 1.0207529067993164 - resetting
2017-04-17 14:59:38.116699 WARNING Scheduler clock skew detected - delta = 1.883409023284912 - resetting
2017-04-17 14:59:38.185970 WARNING Scheduler clock skew detected - delta = 1.8141539096832275 - resetting
2017-04-17 14:59:38.256777 WARNING Scheduler clock skew detected - delta = 1.7433381080627441 - resetting
2017-04-17 14:59:38.339665 WARNING Scheduler clock skew detected - delta = 1.6604650020599365 - resetting
2017-04-17 14:59:38.413769 WARNING Scheduler clock skew detected - delta = 1.5863709449768066 - resetting
2017-04-17 14:59:38.485910 WARNING Scheduler clock skew detected - delta = 1.5142300128936768 - resetting
2017-04-17 14:59:38.558366 WARNING Scheduler clock skew detected - delta = 1.4417660236358643 - resetting
2017-04-17 14:59:38.630547 WARNING Scheduler clock skew detected - delta = 1.369581937789917 - resetting
2017-04-17 14:59:38.760636 WARNING Scheduler clock skew detected - delta = 1.2395000457763672 - resetting
2017-04-17 14:59:38.863869 WARNING Scheduler clock skew detected - delta = 1.1362988948822021 - resetting
2017-04-17 14:59:38.985534 WARNING Scheduler clock skew detected - delta = 1.014599084854126 - resetting
2017-04-17 14:59:39.167745 WARNING Scheduler clock skew detected - delta = 1.832401990890503 - resetting
2017-04-17 14:59:39.246010 WARNING Scheduler clock skew detected - delta = 1.7541320323944092 - resetting
2017-04-17 14:59:39.323997 WARNING Scheduler clock skew detected - delta = 1.6761589050292969 - resetting
2017-04-17 14:59:39.400310 WARNING Scheduler clock skew detected - delta = 1.5998120307922363 - resetting
2017-04-17 14:59:39.482323 WARNING Scheduler clock skew detected - delta = 1.5177950859069824 - resetting
2017-04-17 14:59:39.553961 WARNING Scheduler clock skew detected - delta = 1.4461500644683838 - resetting
2017-04-17 14:59:39.640166 WARNING Scheduler clock skew detected - delta = 1.360016107559204 - resetting
2017-04-17 14:59:39.712770 WARNING Scheduler clock skew detected - delta = 1.2873399257659912 - resetting
2017-04-17 14:59:39.786420 WARNING Scheduler clock skew detected - delta = 1.2137041091918945 - resetting
2017-04-17 14:59:39.866375 WARNING Scheduler clock skew detected - delta = 1.133749008178711 - resetting
2017-04-17 14:59:39.940073 WARNING Scheduler clock skew detected - delta = 1.060046911239624 - resetting
2017-04-17 14:59:40.080770 WARNING Scheduler clock skew detected - delta = 1.919339895248413 - resetting
2017-04-17 14:59:40.150350 WARNING Scheduler clock skew detected - delta = 1.8497700691223145 - resetting
2017-04-17 14:59:40.224624 WARNING Scheduler clock skew detected - delta = 1.7754979133605957 - resetting
2017-04-17 14:59:40.299194 WARNING Scheduler clock skew detected - delta = 1.7009339332580566 - resetting
2017-04-17 14:59:40.386789 WARNING Scheduler clock skew detected - delta = 1.613408088684082 - resetting
2017-04-17 14:59:40.473908 WARNING Scheduler clock skew detected - delta = 1.5262360572814941 - resetting
2017-04-17 14:59:40.549851 WARNING Scheduler clock skew detected - delta = 1.4502699375152588 - resetting
2017-04-17 14:59:40.629910 WARNING Scheduler clock skew detected - delta = 1.37021803855896 - resetting
2017-04-17 14:59:40.707781 WARNING Scheduler clock skew detected - delta = 1.2923390865325928 - resetting
2017-04-17 14:59:40.780652 WARNING Scheduler clock skew detected - delta = 1.2194740772247314 - resetting
2017-04-17 14:59:40.856790 WARNING Scheduler clock skew detected - delta = 1.1433351039886475 - resetting
2017-04-17 14:59:40.928597 WARNING Scheduler clock skew detected - delta = 1.0715909004211426 - resetting
2017-04-17 14:59:41.104534 WARNING Scheduler clock skew detected - delta = 1.8955750465393066 - resetting
2017-04-17 14:59:41.201939 WARNING Scheduler clock skew detected - delta = 1.7981739044189453 - resetting
2017-04-17 14:59:41.273479 WARNING Scheduler clock skew detected - delta = 1.7266480922698975 - resetting
2017-04-17 14:59:41.365244 WARNING Scheduler clock skew detected - delta = 1.6348741054534912 - resetting
2017-04-17 14:59:41.436306 WARNING Scheduler clock skew detected - delta = 1.5638349056243896 - resetting
2017-04-17 14:59:41.512010 WARNING Scheduler clock skew detected - delta = 1.4881150722503662 - resetting
2017-04-17 14:59:41.594169 WARNING Scheduler clock skew detected - delta = 1.405958890914917 - resetting
2017-04-17 14:59:41.669419 WARNING Scheduler clock skew detected - delta = 1.33070707321167 - resetting
2017-04-17 14:59:41.749619 WARNING Scheduler clock skew detected - delta = 1.2505090236663818 - resetting
2017-04-17 14:59:41.824522 WARNING Scheduler clock skew detected - delta = 1.1756041049957275 - resetting
2017-04-17 14:59:41.901870 WARNING Scheduler clock skew detected - delta = 1.0982530117034912 - resetting
2017-04-17 14:59:41.976968 WARNING Scheduler clock skew detected - delta = 1.0231568813323975 - resetting
2017-04-17 14:59:42.119025 WARNING Scheduler clock skew detected - delta = 1.881087064743042 - resetting
2017-04-17 14:59:42.190914 WARNING Scheduler clock skew detected - delta = 1.8092119693756104 - resetting
2017-04-17 14:59:42.264252 WARNING Scheduler clock skew detected - delta = 1.735888957977295 - resetting
2017-04-17 14:59:42.359708 WARNING Scheduler clock skew detected - delta = 1.6405360698699951 - resetting
2017-04-17 14:59:42.443399 WARNING Scheduler clock skew detected - delta = 1.5568759441375732 - resetting
2017-04-17 14:59:42.534535 WARNING Scheduler clock skew detected - delta = 1.465583086013794 - resetting
2017-04-17 14:59:42.607397 WARNING Scheduler clock skew detected - delta = 1.3927249908447266 - resetting
2017-04-17 14:59:42.761994 WARNING Scheduler clock skew detected - delta = 1.2381401062011719 - resetting
2017-04-17 14:59:42.925966 WARNING Scheduler clock skew detected - delta = 1.0742449760437012 - resetting
2017-04-17 14:59:43.068767 WARNING Scheduler clock skew detected - delta = 1.9313459396362305 - resetting
2017-04-17 14:59:43.140052 WARNING Scheduler clock skew detected - delta = 1.8600759506225586 - resetting
2017-04-17 14:59:43.227740 WARNING Scheduler clock skew detected - delta = 1.7724289894104004 - resetting
2017-04-17 14:59:43.311806 WARNING Scheduler clock skew detected - delta = 1.6884450912475586 - resetting
2017-04-17 14:59:43.397201 WARNING Scheduler clock skew detected - delta = 1.602924108505249 - resetting
2017-04-17 14:59:43.477655 WARNING Scheduler clock skew detected - delta = 1.5224668979644775 - resetting
2017-04-17 14:59:43.566411 WARNING Scheduler clock skew detected - delta = 1.4337739944458008 - resetting
2017-04-17 14:59:43.640309 WARNING Scheduler clock skew detected - delta = 1.3598248958587646 - resetting
2017-04-17 14:59:43.723701 WARNING Scheduler clock skew detected - delta = 1.2764248847961426 - resetting
2017-04-17 14:59:43.797982 WARNING Scheduler clock skew detected - delta = 1.2021429538726807 - resetting
2017-04-17 14:59:43.887515 WARNING Scheduler clock skew detected - delta = 1.112612009048462 - resetting
2017-04-17 14:59:44.073824 WARNING Scheduler clock skew detected - delta = 1.9262900352478027 - resetting
2017-04-17 14:59:44.154058 WARNING Scheduler clock skew detected - delta = 1.8460569381713867 - resetting
2017-04-17 14:59:44.238876 WARNING Scheduler clock skew detected - delta = 1.761286973953247 - resetting
2017-04-17 14:59:44.313275 WARNING Scheduler clock skew detected - delta = 1.6868400573730469 - resetting
2017-04-17 14:59:44.387191 WARNING Scheduler clock skew detected - delta = 1.6129329204559326 - resetting
2017-04-17 14:59:44.460638 WARNING Scheduler clock skew detected - delta = 1.5394868850708008 - resetting
2017-04-17 14:59:44.541069 WARNING Scheduler clock skew detected - delta = 1.4590470790863037 - resetting
2017-04-17 14:59:44.625843 WARNING Scheduler clock skew detected - delta = 1.3743269443511963 - resetting
2017-04-17 14:59:44.732778 WARNING Scheduler clock skew detected - delta = 1.2673959732055664 - resetting
2017-04-17 14:59:44.823136 WARNING Scheduler clock skew detected - delta = 1.1770060062408447 - resetting
2017-04-17 14:59:44.936734 WARNING Scheduler clock skew detected - delta = 1.0634269714355469 - resetting
2017-04-17 14:59:45.116030 WARNING Scheduler clock skew detected - delta = 1.884099006652832 - resetting
2017-04-17 14:59:45.190400 WARNING Scheduler clock skew detected - delta = 1.809730052947998 - resetting
2017-04-17 14:59:45.266010 WARNING Scheduler clock skew detected - delta = 1.734131097793579 - resetting
2017-04-17 14:59:45.351390 WARNING Scheduler clock skew detected - delta = 1.6488080024719238 - resetting
2017-04-17 14:59:45.426410 WARNING Scheduler clock skew detected - delta = 1.5737171173095703 - resetting
2017-04-17 14:59:45.519447 WARNING Scheduler clock skew detected - delta = 1.480665922164917 - resetting
2017-04-17 14:59:45.592267 WARNING Scheduler clock skew detected - delta = 1.4078600406646729 - resetting
2017-04-17 14:59:45.667587 WARNING Scheduler clock skew detected - delta = 1.3325769901275635 - resetting
2017-04-17 14:59:45.744574 WARNING Scheduler clock skew detected - delta = 1.2555639743804932 - resetting
2017-04-17 14:59:45.830646 WARNING Scheduler clock skew detected - delta = 1.169482946395874 - resetting
2017-04-17 14:59:45.905485 WARNING Scheduler clock skew detected - delta = 1.0946440696716309 - resetting
2017-04-17 14:59:45.979896 WARNING Scheduler clock skew detected - delta = 1.0202300548553467 - resetting
2017-04-17 14:59:46.124020 WARNING Scheduler clock skew detected - delta = 1.876089096069336 - resetting
2017-04-17 14:59:46.195530 WARNING Scheduler clock skew detected - delta = 1.8045899868011475 - resetting
2017-04-17 14:59:46.270706 WARNING Scheduler clock skew detected - delta = 1.7294189929962158 - resetting
2017-04-17 14:59:46.345210 WARNING Scheduler clock skew detected - delta = 1.6549160480499268 - resetting
2017-04-17 14:59:46.419415 WARNING Scheduler clock skew detected - delta = 1.5807158946990967 - resetting
2017-04-17 14:59:46.494220 WARNING Scheduler clock skew detected - delta = 1.505906105041504 - resetting
2017-04-17 14:59:46.569675 WARNING Scheduler clock skew detected - delta = 1.4304449558258057 - resetting
2017-04-17 14:59:46.644591 WARNING Scheduler clock skew detected - delta = 1.355530023574829 - resetting
2017-04-17 14:59:46.719190 WARNING Scheduler clock skew detected - delta = 1.2809350490570068 - resetting
2017-04-17 14:59:46.794810 WARNING Scheduler clock skew detected - delta = 1.2053229808807373 - resetting
2017-04-17 14:59:46.869915 WARNING Scheduler clock skew detected - delta = 1.130208969116211 - resetting
2017-04-17 14:59:46.949302 WARNING Scheduler clock skew detected - delta = 1.05082106590271 - resetting
2017-04-17 14:59:47.104973 WARNING Scheduler clock skew detected - delta = 1.8951408863067627 - resetting
2017-04-17 14:59:47.175342 WARNING Scheduler clock skew detected - delta = 1.8247790336608887 - resetting
2017-04-17 14:59:47.257471 WARNING Scheduler clock skew detected - delta = 1.7427959442138672 - resetting
2017-04-17 14:59:47.329790 WARNING Scheduler clock skew detected - delta = 1.6703429222106934 - resetting
2017-04-17 14:59:47.412193 WARNING Scheduler clock skew detected - delta = 1.5879249572753906 - resetting
2017-04-17 14:59:47.482024 WARNING Scheduler clock skew detected - delta = 1.5181059837341309 - resetting
2017-04-17 14:59:47.562420 WARNING Scheduler clock skew detected - delta = 1.4377110004425049 - resetting
2017-04-17 14:59:47.635441 WARNING Scheduler clock skew detected - delta = 1.3646879196166992 - resetting
2017-04-17 14:59:47.720502 WARNING Scheduler clock skew detected - delta = 1.279660940170288 - resetting
OK, thanks - I need to figure out what is going on here as it should correct itself after the first time it happens.
would be nice.
1 or 2 times the warning would not be a problem, but over 10 times in 1 second is a bit much :wink:
I pushed a fix to the dev branch Rene - let me know if it helps.
ill try it tommorow.
Hello.
I have the same problem.
This is the version of
2017-10-30 08:04:09.453207 INFO AppDaemon Version 2.1.10 startin appdaemon
and the error:
2017-10-29 18:23:20.606144 WARNING Scheduler clock skew detected - delta = 1.0582051277160645 - resetting
2017-10-29 20:59:11.034199 WARNING Scheduler clock skew detected - delta = 1.5720329284667969 - resetting
2017-10-29 21:05:26.202036 WARNING Scheduler clock skew detected - delta = 1.1679251194000244 - resetting
2017-10-29 21:12:47.883084 WARNING Scheduler clock skew detected - delta = 1.31895112991333 - resetting
2017-10-29 21:30:38.309860 WARNING Scheduler clock skew detected - delta = 1.4267749786376953 - resetting
2017-10-29 21:35:17.259274 WARNING Scheduler clock skew detected - delta = 1.0505869388580322 - resetting
2017-10-29 21:50:13.043309 WARNING Scheduler clock skew detected - delta = 1.2159829139709473 - resetting
2017-10-29 22:00:26.211723 WARNING Scheduler clock skew detected - delta = 1.1684339046478271 - resetting
2017-10-29 22:02:11.649428 WARNING Scheduler clock skew detected - delta = 1.5622949600219727 - resetting
Andreas H
its no error, its a warning that you appdaemon is to busy at the moments that the warning appears.
it seems like you have something running every 5 minutes that sometimes takes a little longer.
that could be a webpage that you look at every 5 mins, or a calculation from a sensor you make, or something like that.
its just a small delta, so no worries.
just something to keep in mind and see if there can be done something to speed up your apps.
Rene is correct - what used to be a bug in AppDaemon has been fixed and this is an indication that your hardware is overworked.
