I got ThermIQ integration (+MQTT)) to work in a combination Raspberry Pi5 with Home Assistant operating system, as another device an old Raspberry Pi3+ with Raspberry operating system, with ThermIQ-room2 software installed on it. The HA user system was new to me and I’m not an IT expert, so it required a lot of time and learning, but now it works great. The only problem seems to be that the clock is an hour behind for some reason. The Rasberry Pi5 clock is on time, but the ThermIQ clock is an hour behind?
ThermIQ has it’s own timezone settings which is available in the wifi/mqtt-setup. Try to re-pair the card and make sure you select the right zone.
Rgds
