HI ,
I am running HA Supervised in a debian VM over Proxmox.
The Duckdns and Letsencrypt have been integrated successfully as per their logs.
The remote access from HA android app fails with ERR_SSL_PROTOCOL
A possible raison is that the http configuration mentionned in the Duckdnd addon documentation for Home Assistant Core is not setup because tis prevents HA to reboot.
As per the log , HA is running but sounds like the UI is not up.
Please any expert may look at this issue ?
Thank you
http part of Duckdns addon documentation
Additionally, you'll need to configure the Home Assistant Core to pick up the SSL certificates. This is done by setting the following configuration for the [HTTP](https://www.home-assistant.io/integrations/http/) integration configuration in your `configuration.yaml` :
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
I have taken the Debian VM Syslog regarding the HA failing to stat when http configuration is in the configuration.yaml
Jan 14 13:15:26 Debian10-KVM dcc8141b0962[390]: NOCHANGE#033[0m
Jan 14 13:17:01 Debian10-KVM CRON[6610]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jan 14 13:19:46 Debian10-KVM 43242e55b673[390]:
Jan 14 13:20:28 Debian10-KVM dcc8141b0962[390]: [13:20:28] INFO: #033[32mOK
Jan 14 13:20:28 Debian10-KVM dcc8141b0962[390]: 176.167.80.172
Jan 14 13:20:28 Debian10-KVM dcc8141b0962[390]: NOCHANGE#033[0m
Jan 14 13:21:20 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:21:20 INFO (SyncWorker_1) [supervisor.docker.interface] Restarting homeassistant/qemux86-64-homeassistant#033[0m
Jan 14 13:21:20 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:21:20 INFO (SyncWorker_1) [supervisor.docker.interface] Restarting homeassistant/qemux86-64-homeassistant#033[0m
Jan 14 13:21:20 Debian10-KVM f943196c16db[390]: [cont-finish.d] executing container finish scripts...
Jan 14 13:21:20 Debian10-KVM f943196c16db[390]: [cont-finish.d] done.
Jan 14 13:21:20 Debian10-KVM f943196c16db[390]: [s6-finish] waiting for services.
Jan 14 13:21:21 Debian10-KVM f943196c16db[390]: Client error on /homeassistant/restart request Server disconnected
Jan 14 13:21:21 Debian10-KVM 00e60774e4ef[390]: 1610626881: Socket error on client 3py2FV4Q1PzIv8v5VPogii, disconnecting.
Jan 14 13:21:21 Debian10-KVM f943196c16db[390]: s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
Jan 14 13:21:21 Debian10-KVM f943196c16db[390]: [s6-finish] sending all processes the TERM signal.
Jan 14 13:21:25 Debian10-KVM f943196c16db[390]: [s6-finish] sending all processes the KILL signal and exiting.
Jan 14 13:21:25 Debian10-KVM dockerd[390]: time="2021-01-14T13:21:25.232680167+01:00" level=info msg="ignoring event" container=f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Jan 14 13:21:25 Debian10-KVM containerd[314]: time="2021-01-14T13:21:25.234388468+01:00" level=info msg="shim disconnected" id=f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e
Jan 14 13:21:25 Debian10-KVM containerd[314]: time="2021-01-14T13:21:25.360705205+01:00" level=info msg="starting signal loop" namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e pid=6711
Jan 14 13:21:25 Debian10-KVM systemd[1]: run-docker-runtime\x2drunc-moby-f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e-runc.ehwqAO.mount: Succeeded.
Jan 14 13:21:25 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:21:25 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready#033[0m
Jan 14 13:21:25 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:21:25 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready#033[0m
Jan 14 13:21:25 Debian10-KVM f943196c16db[390]: [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
Jan 14 13:21:25 Debian10-KVM f943196c16db[390]: [s6-init] ensuring user provided files have correct perms...exited 0.
Jan 14 13:21:25 Debian10-KVM f943196c16db[390]: [fix-attrs.d] applying ownership & permissions fixes...
Jan 14 13:21:25 Debian10-KVM f943196c16db[390]: [fix-attrs.d] done.
Jan 14 13:21:25 Debian10-KVM f943196c16db[390]: [cont-init.d] executing container initialization scripts...
Jan 14 13:21:25 Debian10-KVM f943196c16db[390]: [cont-init.d] udev.sh: executing...
Jan 14 13:21:25 Debian10-KVM f943196c16db[390]: [12:21:25] INFO: #033[32mUpdate udev information#033[0m
Jan 14 13:21:26 Debian10-KVM systemd-udevd[6971]: Using default interface naming scheme 'v240'.
Jan 14 13:21:26 Debian10-KVM systemd-udevd[6949]: Using default interface naming scheme 'v240'.
Jan 14 13:21:26 Debian10-KVM systemd-udevd[6945]: Using default interface naming scheme 'v240'.
Jan 14 13:21:27 Debian10-KVM f943196c16db[390]: [cont-init.d] udev.sh: exited 0.
Jan 14 13:21:27 Debian10-KVM f943196c16db[390]: [cont-init.d] done.
Jan 14 13:21:27 Debian10-KVM f943196c16db[390]: [services.d] starting services
Jan 14 13:21:27 Debian10-KVM f943196c16db[390]: [services.d] done.
Jan 14 13:21:32 Debian10-KVM 00e60774e4ef[390]: 1610626892: New connection from 172.30.32.1 on port 1883.
Jan 14 13:21:32 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:21:32 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'xxxx_mosquitto'#033[0m
Jan 14 13:21:32 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:21:32 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'xxxx_mosquitto'#033[0m
Jan 14 13:21:33 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:21:33 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache#033[0m
Jan 14 13:21:33 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:21:33 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache#033[0m
Jan 14 13:21:33 Debian10-KVM 00e60774e4ef[390]: [INFO] found xxxxxx_mosquitto on Home Assistant
Jan 14 13:21:33 Debian10-KVM 00e60774e4ef[390]: 1610626893: New client connected from 172.30.32.1 as 5VTIMTBnnyn73YiWA367IJ (p2, c1, k60, u'xxxxxxx_mosquitto').
Jan 14 13:21:33 Debian10-KVM f943196c16db[390]: #033[32m2021-01-14 12:21:33 INFO (Thread-5) [homeassistant.components.mqtt] Connected to MQTT server core-mosquitto:1883 (0)#033[0m
Jan 14 13:21:34 Debian10-KVM f943196c16db[390]: #033[36m2021-01-14 12:21:34 DEBUG (MainThread) [homeassistant.components.onvif] Setting up the ONVIF device management service#033[0m
Jan 14 13:21:34 Debian10-KVM f943196c16db[390]: #033[36m2021-01-14 12:21:34 DEBUG (MainThread) [homeassistant.components.onvif] Retrieving current device date/time#033[0m
Jan 14 13:21:34 Debian10-KVM f943196c16db[390]: #033[36m2021-01-14 12:21:34 DEBUG (MainThread) [homeassistant.components.onvif] Device date/time: 2015-01-23 10:51:13+00:00 | System date/time: 2021-01-14 12:21:34.619427+00:00#033[0m
Jan 14 13:21:37 Debian10-KVM f943196c16db[390]: #033[31m2021-01-14 12:21:37 ERROR (MainThread) [homeassistant.components.camera] The onvif platform for the camera integration does not support platform setup. Please remove it from your config.#033[0m
Jan 14 13:21:38 Debian10-KVM f943196c16db[390]: #033[31m2021-01-14 12:21:38 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': 'SYNO.API.Auth', 'code': 400, 'reason': 'Invalid credentials', 'details': 'Invalid password or not admin account: secrets ds418_username'}#033[0m
Jan 14 13:21:45 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:21:45 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance#033[0m
Jan 14 13:21:45 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:21:45 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance#033[0m
Jan 14 13:22:00 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:22:00 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Jan 14 13:22:00 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:22:00 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Jan 14 13:22:01 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:22:01 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_vscode#033[0m
Jan 14 13:22:01 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:22:01 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_vscode#033[0m
Jan 14 13:22:01 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:22:01 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running#033[0m
Jan 14 13:22:01 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:22:01 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running#033[0m
Jan 14 13:23:49 Debian10-KVM systemd[1]: Created slice User Slice of UID 1000.
Jan 14 13:23:49 Debian10-KVM systemd[1]: Starting User Runtime Directory /run/user/1000...
Jan 14 13:23:49 Debian10-KVM systemd[1]: Started User Runtime Directory /run/user/1000.
Jan 14 13:23:49 Debian10-KVM systemd[1]: Starting User Manager for UID 1000...
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Reached target Timers.
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Reached target Paths.
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Listening on GnuPG network certificate management daemon.
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Reached target Sockets.
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Reached target Basic System.
Jan 14 13:23:49 Debian10-KVM systemd[1]: Started User Manager for UID 1000.
Jan 14 13:23:49 Debian10-KVM systemd[1]: Started Session 2 of user gerardsamara.
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Reached target Default.
Jan 14 13:23:49 Debian10-KVM systemd[7279]: Startup finished in 88ms.
Jan 14 13:23:54 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:23:54 INFO (SyncWorker_0) [supervisor.docker.interface] Restarting homeassistant/qemux86-64-homeassistant#033[0m
Jan 14 13:23:54 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:23:54 INFO (SyncWorker_0) [supervisor.docker.interface] Restarting homeassistant/qemux86-64-homeassistant#033[0m
Jan 14 13:23:54 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:23:54 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str#033[0m
Jan 14 13:23:54 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:23:54 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str#033[0m
Jan 14 13:23:54 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:23:54 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed#033[0m
Jan 14 13:23:54 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:23:54 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed#033[0m
Jan 14 13:23:54 Debian10-KVM f943196c16db[390]: [cont-finish.d] executing container finish scripts...
Jan 14 13:23:54 Debian10-KVM f943196c16db[390]: [cont-finish.d] done.
Jan 14 13:23:54 Debian10-KVM f943196c16db[390]: [s6-finish] waiting for services.
Jan 14 13:23:55 Debian10-KVM f943196c16db[390]: Client error on /homeassistant/restart request Server disconnected
Jan 14 13:23:56 Debian10-KVM 00e60774e4ef[390]: 1610627036: Socket error on client 5VTIMTBnnyn73YiWA367IJ, disconnecting.
Jan 14 13:23:56 Debian10-KVM f943196c16db[390]: s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
Jan 14 13:23:56 Debian10-KVM f943196c16db[390]: [s6-finish] sending all processes the TERM signal.
Jan 14 13:23:59 Debian10-KVM f943196c16db[390]: [s6-finish] sending all processes the KILL signal and exiting.
Jan 14 13:24:00 Debian10-KVM dockerd[390]: time="2021-01-14T13:24:00.087717181+01:00" level=info msg="ignoring event" container=f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Jan 14 13:24:00 Debian10-KVM containerd[314]: time="2021-01-14T13:24:00.089776246+01:00" level=info msg="shim disconnected" id=f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e
Jan 14 13:24:00 Debian10-KVM containerd[314]: time="2021-01-14T13:24:00.205773869+01:00" level=info msg="starting signal loop" namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e pid=7362
Jan 14 13:24:00 Debian10-KVM systemd[7279]: run-docker-runtime\x2drunc-moby-f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e-runc.LAbnj7.mount: Succeeded.
Jan 14 13:24:00 Debian10-KVM systemd[1]: run-docker-runtime\x2drunc-moby-f943196c16dbe8ed9359ef69a6c5dd86dd6342b39b2995bc8d68b7077a9ce43e-runc.LAbnj7.mount: Succeeded.
Jan 14 13:24:00 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:24:00 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready#033[0m
Jan 14 13:24:00 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:24:00 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready#033[0m
Jan 14 13:24:00 Debian10-KVM f943196c16db[390]: [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
Jan 14 13:24:00 Debian10-KVM f943196c16db[390]: [s6-init] ensuring user provided files have correct perms...exited 0.
Jan 14 13:24:00 Debian10-KVM f943196c16db[390]: [fix-attrs.d] applying ownership & permissions fixes...
Jan 14 13:24:00 Debian10-KVM f943196c16db[390]: [fix-attrs.d] done.
Jan 14 13:24:00 Debian10-KVM f943196c16db[390]: [cont-init.d] executing container initialization scripts...
Jan 14 13:24:00 Debian10-KVM f943196c16db[390]: [cont-init.d] udev.sh: executing...
Jan 14 13:24:00 Debian10-KVM f943196c16db[390]: [12:24:00] INFO: #033[32mUpdate udev information#033[0m
Jan 14 13:24:00 Debian10-KVM systemd-udevd[7609]: Using default interface naming scheme 'v240'.
Jan 14 13:24:01 Debian10-KVM systemd-udevd[7608]: Using default interface naming scheme 'v240'.
Jan 14 13:24:01 Debian10-KVM systemd-udevd[7601]: Using default interface naming scheme 'v240'.
Jan 14 13:24:02 Debian10-KVM f943196c16db[390]: [cont-init.d] udev.sh: exited 0.
Jan 14 13:24:02 Debian10-KVM f943196c16db[390]: [cont-init.d] done.
Jan 14 13:24:02 Debian10-KVM f943196c16db[390]: [services.d] starting services
Jan 14 13:24:02 Debian10-KVM f943196c16db[390]: [services.d] done.
Jan 14 13:24:07 Debian10-KVM 00e60774e4ef[390]: 1610627047: New connection from 172.30.32.1 on port 1883.
Jan 14 13:24:07 Debian10-KVM 00e60774e4ef[390]: 1610627047: New client connected from 172.30.32.1 as 6Z65O69ySwKDDIeHbcqGep (p2, c1, k60, u'xxxxx_mosquitto').
Jan 14 13:24:07 Debian10-KVM f943196c16db[390]: #033[32m2021-01-14 12:24:07 INFO (Thread-5) [homeassistant.components.mqtt] Connected to MQTT server core-mosquitto:1883 (0)#033[0m
Jan 14 13:24:09 Debian10-KVM f943196c16db[390]: #033[36m2021-01-14 12:24:09 DEBUG (MainThread) [homeassistant.components.onvif] Setting up the ONVIF device management service#033[0m
Jan 14 13:24:09 Debian10-KVM f943196c16db[390]: #033[36m2021-01-14 12:24:09 DEBUG (MainThread) [homeassistant.components.onvif] Retrieving current device date/time#033[0m
Jan 14 13:24:09 Debian10-KVM f943196c16db[390]: #033[36m2021-01-14 12:24:09 DEBUG (MainThread) [homeassistant.components.onvif] Device date/time: 2015-01-23 10:53:48+00:00 | System date/time: 2021-01-14 12:24:09.305595+00:00#033[0m
Jan 14 13:24:11 Debian10-KVM f943196c16db[390]: #033[31m2021-01-14 12:24:11 ERROR (MainThread) [homeassistant.components.camera] The onvif platform for the camera integration does not support platform setup. Please remove it from your config.#033[0m
Jan 14 13:24:13 Debian10-KVM f943196c16db[390]: #033[31m2021-01-14 12:24:13 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': 'SYNO.API.Auth', 'code': 400, 'reason': 'Invalid credentials', 'details': 'Invalid password or not admin account: secrets ds418_username'}#033[0m
Jan 14 13:24:19 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:24:19 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Jan 14 13:24:19 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:24:19 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Jan 14 13:24:19 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:24:19 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_vscode#033[0m
Jan 14 13:24:19 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:24:19 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_vscode#033[0m
Jan 14 13:24:19 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:24:19 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running#033[0m
Jan 14 13:24:19 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:24:19 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running#033[0m
Jan 14 13:24:20 Debian10-KVM 43242e55b673[390]: #033[32m21-01-14 12:24:20 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance#033[0m
Jan 14 13:24:20 Debian10-KVM hassio-supervisor[906]: #033[32m21-01-14 12:24:20 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance#033[0m
Jan 14 13:24:47 Debian10-KVM 43242e55b673[390]:
Jan 14 13:25:02 Debian10-KVM 00e60774e4ef[390]: 1610627102: Saving in-memory database to /data/mosquitto.db.
Jan 14 13:25:29 Debian10-KVM dcc8141b0962[390]: [13:25:29] INFO: #033[32mOK
Jan 14 13:25:29 Debian10-KVM dcc8141b0962[390]: 176.167.80.172
Jan 14 13:25:29 Debian10-KVM dcc8141b0962[390]: NOCHANGE#033[0m
Jan 14 13:29:47 Debian10-KVM 43242e55b673[390]:
Jan 14 13:30:30 Debian10-KVM dcc8141b0962[390]: [13:30:30] INFO: #033[32mOK
Jan 14 13:30:30 Debian10-KVM dcc8141b0962[390]: 176.167.80.172
Jan 14 13:30:30 Debian10-KVM dcc8141b0962[390]: NOCHANGE#033[0m
Jan 14 13:30:43 Debian10-KVM systemd[1]: session-2.scope: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[1]: Stopping User Manager for UID 1000...
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Stopped target Default.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Stopped target Basic System.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Stopped target Sockets.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: gpg-agent.socket: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: gpg-agent-extra.socket: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 14 13:30:53 Debian10-KVM systemd[7279]: gpg-agent-ssh.socket: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Stopped target Timers.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: dirmngr.socket: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Closed GnuPG network certificate management daemon.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: gpg-agent-browser.socket: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Stopped target Paths.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Reached target Shutdown.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: systemd-exit.service: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Started Exit the Session.
Jan 14 13:30:53 Debian10-KVM systemd[7279]: Reached target Exit the Session.
Jan 14 13:30:53 Debian10-KVM systemd[1]: [email protected]: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[1]: Stopped User Manager for UID 1000.
Jan 14 13:30:53 Debian10-KVM systemd[1]: Stopping User Runtime Directory /run/user/1000...
Jan 14 13:30:53 Debian10-KVM systemd[1]: run-user-1000.mount: Succeeded.
Jan 14 13:30:53 Debian10-KVM systemd[1]: Stopped User Runtime Directory /run/user/1000.
Jan 14 13:30:53 Debian10-KVM systemd[1]: Removed slice User Slice of UID 1000.
Jan 14 13:31:00 Debian10-KVM systemd[1]: Created slice User Slice of UID 1000.
Jan 14 13:31:00 Debian10-KVM systemd[1]: Starting User Runtime Directory /run/user/1000...
Jan 14 13:31:00 Debian10-KVM systemd[1]: Started User Runtime Directory /run/user/1000.
Jan 14 13:31:00 Debian10-KVM systemd[1]: Starting User Manager for UID 1000...
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Reached target Paths.
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Reached target Timers.
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Listening on GnuPG network certificate management daemon.
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Reached target Sockets.
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Reached target Basic System.
Jan 14 13:31:00 Debian10-KVM systemd[1]: Started User Manager for UID 1000.
Jan 14 13:31:00 Debian10-KVM systemd[1]: Started Session 4 of user gerardsamara.
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Reached target Default.
Jan 14 13:31:00 Debian10-KVM systemd[7888]: Startup finished in 63ms.
Jan 14 13:34:47 Debian10-KVM 43242e55b673[390]:
Jan 14 13:35:31 Debian10-KVM dcc8141b0962[390]: [13:35:31] INFO: #033[32mOK
Jan 14 13:35:31 Debian10-KVM dcc8141b0962[390]: 176.167.80.172
Jan 14 13:35:31 Debian10-KVM dcc8141b0962[390]: NOCHANGE#033[0m
Thank you
