Hi Blacky:
Thank you so much for making the updates. Iām traveling right now but will try it out once I get back to my casa. Looking through the blueprint I can see why it took so long and how my probablity of modifying it myself was zero.
Hi Blacky:
Hi @Blacky ,
First, thank you so much for your amazing blueprints! Iāve been using several of your creations, including the Closet, Pantry, and Cupboard Lighting, and theyāre fantastic.
I have an issue: at the end of the automation, the lights always turn off, even if they were initially on before it started.
For example, this happens at night when all lights are on and I open the closet. The assigned lights change the brightness (as part of the automation). After the automation ends, the light turns off, even though they were on before. After that, the brightness that was set before remains. Am I missing something to keep them on if they were originally on?
Thanks again for all your hard work!
Thomas
Typically, when you open a closet, pantry, or cupboard, youād want the light inside to turn ON. If youāve set a time delay, the light will turn OFF after that period, even if it was ON before⦠thatās how the automation works. Without the time delay, the light will simply stay ON until manually turned OFF or you close the door.
When using a time delay and linking a motion sensor, the light will stay ON as long as motion is detected. If you leave the door open and exit the room, the light will turn OFF once the motion sensor becomes inactive. If you re-enter and motion is detected while the door is still open, the light will turn ON again. However, if you close the door, the light will remain OFF.
Hope this make scene.
Blacky ![]()
Hi @Blacky !
I have used some of your previous blueprints and have loved how well they work in every day life. This particular one seemed an elegant solution to a simple conditional automation I had made in the past.
Logger: homeassistant.components.automation.office_closet_light_sensing
Source: components/automation/init.py:688
integration: Automation (documentation, issues)
First occurred: 20:54:05 (23 occurrences)
Last logged: 21:05:18Error rendering variables: UndefinedError: ādict objectā has no attribute āentity_idā
I have a simple setup of just a contact sensor on the door to a closet, with one ceiling fixture of a smart bulb. For whatever reason the automation was not triggering even though the contact sensor events were operating properly.
Iām not sure what this error means that I found in my logs.
Any help would be appreciated!
Welcome to the community.
Have a look at your light and it must only be an entity not a device. This is a link to my sensor light blueprint FAQ but it is all the same. Click Here
If that doesnāt work then could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on ā</>ā and paste code in there.
Blacky ![]()
Thanks for your response!
alias: Office Closet Light Sensing
description: ""
use_blueprint:
path: Blackshome/closet-pantry-cupboard-lighting.yaml
input:
trigger_entity:
- binary_sensor.office_closet_door_sensor_contact
light_switch:
entity_id: light.office_closet_light
What I donāt really understand is that when I check the logs for the door open sensor, it provides the correct states of closed / open, so I that it would be appropriate to trigger the automation, but when I look at the automations section in HA it states the automation has never been triggered. And I believe my entity for the light bulb is correct; I can independently turn the light on and off through HA so I believe it is functioning correctly.
Thanks for your YAML. My bad I had a bug when you didnāt select a light entity in night lights. All fixed now, just update and you should be good.
Blacky ![]()
'Open Sesameā
Lighting Magic! ![]()
Bugs Fixes ![]()
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
I love how as soon as I re-imported the blueprint it all just worked.
Thanks again for your quick response, fix, and overall making these great automations!
Blacky, thanks for making this Blueprint. I have an Aoetec door sensor and Sengled bulb. Iām trying to configure the sensor to trigger the light for 2 min when the door opens between 5pm-6:30am. The light comes on but when the door closes the light goes off. Iād like it to stay on for the full 2 minutes. Is that possible?
This blueprint will turn OFF the light when the door closes and it doesnāt have a time condition to run only between 5pm and 6:30am.
You could look at my
Sensor Light blueprint as that has a time condition and it will keep the light ON for X amount of time when the door closes. The only thing is if you leave the door open the light will remain ON. To resolve this you may consider using a motion sensor rather than a door sensor, that way the light will turn OFF. If you would like to keep your door sensor and there is a possibility the door is left open hence the light staying ON then you may consider creating a template sensor that when the door opens it turns ON but then has a auto OFF just encase you leave the door open.
Blacky ![]()
Hi @Blacky
Small feature suggestion here.
Would it be possible to have a delay OFF feature for lights when the sensor turns to āclosedā state? Like, the lights will only turn off if the sensorās state is set to āclosedā for a specified amount of time.
I would like to use this blueprint for the lights of my attic coupled with a reed sensor on the trap door.
I just want to make sure the lights could stay on for a short while if the trap door closes by mistake while someone is up there.
Thanks!
Why not use my
Sensor Light blueprint. Use your reed sensor on the trap door as the trigger (if you cant select it copy paste the entity ID into the input), add your lights and set the delay to your liking.
Blacky ![]()
Thanks, will do!
Works awesome but I am having trouble or misunderstanding the transition. I would like the light to come one at a lower brightness and then transition to the maximum.
Is that not what the transition option is supposed to do? Do I need to also tick the brightness and set to my lower brightness level???
When a light is turned ON in Home Assistant, it will transition from 0% (OFF) to your set brightness (e.g., 100%). The transition option controls how long this change takes.
Yes, you need to select both brightness and transition. Set your desired brightness level and specify:
Typically, the ON transition is faster than the OFF transition for a more natural lighting effect. However, some lights handle transitions differently, as they may have their own built-in transition effects.
Blacky ![]()
Great thanks for the detailed explanation
Hey man, I love these blueprints. This one and Sensor Light pretty much run my whole house.
Iām having a new issue Iām hoping you can help me with.
My closet has a door sensor to activate the light, and a motion sensor inside to keep it on if Iām in there longer than the original timer, in accordance with the blueprint. When I close the door, the light turns off. This is ideal and exactly what I want to happen.
However, if I then open the door again, Iām assuming before the two minute timer lapses, the light stays off. The door sensor wonāt trigger the light to come back on.
If I wait a couple minutes, it works again. If I disable the motion sensor entirely, I can open and close the door in quick succession and it turns the light on/off accordingly. But in combination with the motion sensor, the timer prevails over turning the light back on.
Any idea what Iām doing wrong?
I have tested it here and canāt fault it.
Could you share the YAML code for your automation settings? This will allow me to better understand your settings and help troubleshoot the issue.
To do this:
</> button in the toolbar.This ensures the formatting stays correct and makes it easier to analyze.
Blacky ![]()
Here you go.
alias: Charlie's Closet Auto Light
description: ""
use_blueprint:
input:
trigger_entity:
- binary_sensor.charlies_closet_door_opening
timer:
hours: 0
minutes: 2
seconds: 0
include_motion_trigger: enable_motion_trigger
light_switch:
entity_id: switch.charlie_s_closet_switch
include_timer: enable_timer
motion_trigger: binary_sensor.charlie_s_closet
