đŸšȘ Closet, Pantry, and Cupboard Lighting
GitHub Link Click Here
'Open Sesame’:magic_wand: Lighting Magic! :bulb::door:
Like this blueprint? Consider hitting the :heart: button below :+1:
Version: 1.3 :fire:
:warning:You must be on Home Assistant Version 2024.6 or later.
Need help? :eyes: See our FAQ: Click Here
:newspaper: The Automation Process:
  • Trigger:
    • The trigger sensor is specifically designed to integrate seamlessly with a door contact sensor but you can choose any binary sensors to trigger the automation.
    • When activated, a trigger sensor such as a door contact sensor will turn ON the lights and switches.
  • Light - Switches:
    • Enter any lights or switches that will be activated by the trigger sensor/s.
  • Light Control Options:
    • Utilize “Light Control” to adjust brightness, colour temperature, colour, and transition times.
  • Night Lights Mode:
    • Enable ‘Night Lights’ for softer illumination during night time activities, automatically enabled based on conditions.
  • Timer Option:
    • You have the option to use a timer, which determines how long the lights remain ON after the trigger sensor is activated. It will then automatically turn OFF the ‘Lights - Switches’ when the timer expires.
  • Motion Sensor Option:
    • You have the option to use a motion sensor that will reset the timer. If the timer has turned OFF the lights and the trigger remains active, the motion sensor will turn the lights back ON when detecting motion.
  • HA Restart Safeguards:
    • Benefit from built-in safeguards for Home Assistant restarts.
  • Blueprint Integration:
    • :bulb: Sensor Light - Motion activated lighting. Click Here to learn more.
:rocket: CHANGELOG
  • Version: 1.3 - 8 Oct-24 - Fixed a bug that would stop it form being triggered if no night light entity was selected.
  • Version: 1.2 - 31 July-24 - Added RGB colour selection, night lights and collapsible sections.
  • Version: 1.1 - 26 May-24 - Update to description to show labels are excluded.
  • Version: 1.0 - 2 March-24 - Initial release
:shield: MY OTHER BLUEPRINTS
:bulb: Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time
:high_brightness: Smart Light - Entity - Sun Elevation - Ambient & Time Triggers
:infinity: Sensor Light Add On - Media & Movie Lights - House Alarm Lights - Smoke Alarm Lights & Exhaust Fans + More
:airplane: Holiday & Away Lighting
:shower: Bathroom Humidity Exhaust Fan
:low_battery: Low Battery Notifications & Actions
:vibration_mode: Appliance Notifications & Actions - Washing Machine - Clothes Dryer - Dish Washer - ETC
:loudspeaker: Notifications & Announcements
:calendar: Calendar Notifications & Actions
:round_pushpin: State Notifications & Actions
:battery: Battery Charger Notifications & Actions
:blue_book: Blueprint Update Notifications
:stop_button: Manual Control Status Tracker
:globe_with_meridians: Zone Presence of People & Devices
:honeybee: Bee In The Hive Sensor
:robot: Android Notification Channel Manager
:toilet: Toilet Exhaust Fan with time delay
:hourglass_flowing_sand: Entity - Run ON Timer
:stopwatch: Trigger - Run ON Timer
:magic_wand: Manual light control with auto OFF
:timer_clock: Timer
:thermometer: Temperature Control Fan
:snowflake: Temperature Control Exhaust Fan - Inverted
:eight_spoked_asterisk: Toggle Switch - Turn ON & OFF Entities
:nazar_amulet: Press Button - Turn ON & OFF Entities
:on: Switch - Turn ON & OFF Entities
FAQ
Q: How do I create a group helper?
A: Please Click Here
FAQ - Creating a Group
When using multiple trigger sensors or motion sensors, it’s advisable to group them together using a group helper. This ensures smoother automation execution and prevents conflicts.
CREATE A GROUP HELPER
  1. Go to Settings > Devices & Services > click on the “Helpers” tab > click “+ CREATE HELPER” and select “Group”.
  2. Select Binary sensor group.
  3. Then enter a name, in this example we put “Pantry Door Contact Sensor”. Then select your “Members” or entities (all of them that will be in the blueprint automation). Keep “Hide Members” and “All Entities” toggles OFF as shown below. Click submit.
  4. Your done :tada: Now you can use this group helper in your automation.
Enjoy
Blacky :grinning:
Back to FAQ: Click Here
Initial release 1.0
New blueprint :partying_face: Hope you like it :wink:
For all your closets, pantry, & cupboards, utilize the timer option and select a motion sensor for enhanced functionality. If you’re using my sensor light blueprint, the same motion sensor will keep the lights ON or turn them back ON as needed.
If you like this blueprint? Consider hitting the :heart: button in the top post :+1:
If you like my blueprints, and would like to show your support or just say thank you? Click Here :smiling_face_with_three_hearts:
Enjoy
Blacky :grinning:
Great automation and darn near perfect for my use case. Is there any chance of adding a nighttime option based on a time range? I have some closets that I want to have a dimmer light during the evening versus during the day.
That would make the automation perfect!
Nice one, glad you like it.
This is something that I would like to have as well. I will put it on the list.
Blacky :smiley:
I am currently using your Sensor Light BP for my pantry light triggered by a door sensor.
What’s the intention for this BP?
What’s the difference between this BP and the Sensor Light BP?
@chris400
Thanks for asking.
I will explain some use cases.
Pantry - Butlers Pantry etc.
Let say we are using the my sensor light blueprint to control the lights in the kitchen. We then have a pantry with some lights. We install a contact sensor on the pantry door.
Now we use this blueprint using the pantry contact sensor as the trigger. When the door opens the light turn ON and it will turn OFF in a given time delay, so we don’t need to close the door. When we close the door if the light is ON the light turns OFF. So we can see it works different to the Sensor light BP.
Easy, now lets take our automatons to the next level.
Let enable the ‘Motion Sensor Option’ and add our motion sensor we use in the kitchens sensor light BP automation. As we enter the kitchen our kitchen lights turn ON. We then start preparing meals etc. We open the pantry door and leave it open. The light stays ON now due to the motion sensor being active. We can go in and out of the pantry and the light is ON. Now we leave the kitchen, the kitchen lights are ON and the pantry lights are ON and the pantry door is open. The motion sensor clears turning OFF the kitchen lights and the pantry light. Nice. We come back into the kitchen and all the kitchen lights turn ON including the pantry lights. Nice. We then close the pantry door and the pantry lights turn OFF but the kitchen lights stay ON until we leave and the sensor light BP turns the kitchen lights OFF.
If we used the sensor light BP for this along with a contact sensor you would have to close the door for the light to turn OFF and all of the above scenarios would not work.
How many times do the kids/me open the pantry door and not close it? It keeps family peace as the lights always turn OFF even if you leave the door open not to mention it takes you house automation to the next level :wink:
Closet
Again same thing as above but in a bedroom. Sensor Light BP in the bedroom turns bedroom lights ON, open the closet doors (door contact sensor) and the light turn ON. Use the motion sensor option and you can walk out of the room with the closet doors open (contact sensor active) and all your light will turn OFF due to no motion in the room. Walk back into the room all lights back ON. Close the closet, closet light turn OFF.
How many times to the kids/me leave the closet doors open? Family peace, don’t need to keep telling the kids to close the closet doors :wink:
Hope this all makes scene and gives you a better understanding on why it was developed. Sensor Light BP can’t to this.
I also have a :magic_wand: Manual light control with auto OFF. This works with your lamps you manually turn ON if needed. It will then turn them OFF for you in a similar way as this PB but the trigger is different. Check it out as this to makes your automatons smarter.
Blacky :smiley:
Thx, exactly what I needed with two teenagers in the house :slight_smile:
Yep this is exactly what it is for
 household peace. Nice one thanks for your kind words.
Blacky
New Update - Version 1.1
Maintenance :toolbox:
  • Update the description in “Lights - Switches” to include the new option to select “labels”. The updated description should read:
    NOTE: Only entities can be used. Areas, devices, and labels are not supported.
Enjoy
Blacky :grinning:
You have done so many wonderful blueprints but sometimes reading the name and description, I have trouble differentiating them. Perhaps for this one, the description you give:
should be changed to:
When activated, a trigger sensor such as a door contact sensor will turn ON the lights and switches. The lights and switches will turn off either after a set time has elapsed, or when the door contact sensor is closed.
@harryfine
Thanks Harry for your input I do value it. I agree sometimes I am not the best on describing what they do. I need to get better at that.
Blacky :smiley:
Very good blueprints you make, I like them!
I have a question regarding the motion sensor options.
Does the light automatically turn off when the motion sensor state changes to “clear” (no motion detected)?
I used the HA BP “motion-activated light” previously but it did not let, or I couldn’t figure how, to include brightness and transition. But I liked the way that BP had the lights turn off when no motion was detected. And then you had the timer delaying the off action after no motion detected.
In the FAQ, if I read it correctly, the timer starts when the automation triggers the lights to turn on. And if the motion sensor is continuously in state “occupied” the timer will turn off the light. And it won’t turn the lights on until the motion sensor state toggles. Is my understanding correct?
I also want to add a vote for the nighttime feature.
My use case:
I have a walk in closet with a motion sensor.
I want the lights to turn on when motion is detected. And stay on for 2 min after no motion detected.
The turn on attributes (brightness and transition) should be different after 10PM and before 8AM.
@Ekson
Welcome to the community and thanks for your kind words.
I will go directly to your use case and thanks for providing this as it helps me help you.
This blueprint helps if you have doors with a contact sensor.
If you have a walk in closet that is open with a motion sensor in it then look at my :bulb: Sensor Light blueprint. Set it up for the lights you like normally and then use the night lights option with the time condition setting 10pm to 8am. Night lights is where you set your different lights and brightness for those times. It will be perfect for what you are trying to do.
If I got it wrong just let us know and I try and help again.
Blacky :smiley:
Of course! Much better, Thanks!
Always use the correct tools for the task.
Hey Blacky:
Any update on adding a night time option to the lights? The blueprint is really great just struggling with blinding myself when I open the closet at night.
@superbad_dad
I have looked at it and then put it aside, I will look at it again
 thanks for the reminder.
Blacky :smiley:
@superbad_dad
Hi Supper Bad Dad,
I haven’t forgotten about you. I have updated this blueprint and am now just doing the final touches. It’s all ready to go, and I think it looks really nice. You’ll understand why it took so long once you see it, as there were other developments that had to be completed first. Keep an eye out for the update, and let me know what you think.
Thank you for being patient. As they say, ‘All good things come to those who wait.’
Blacky :smiley:
New Update - Version 1.2
:new: New Features
  • Light Colour: You now have the option to select RGB, RGBW or RGBWW in your light control option.
  • Night Lights - You can now set different lights for night time.
  • Collapsible Sections - Added collapsible sections to the blueprint. This enhancement improves the blueprint user interface by making it cleaner and more organized, allowing sections to be collapsed.
    :warning: This feature was introduced in Home Assistant 2024.6, so you must have this version or later for the blueprint to work.
Enjoy
Blacky :grinning:
