Upgraded to 0.74.0 which ran fine. Then activated cloud in the configuration to enable Alexa.
This fails with the message that the configuration is wrong.
The message is misleading. After starting in Debug mode, it was having problems with warrant==0.6.1 which could not be installed due to the fact that requests==2.19.1 is not compatible with warrant=0.6.1
Let me know if i can help with further testing / diagnosis.
The cloud section just contains “cloud:” and nothing else. It was commented out before and i wanted to configure it now for alexa. So very initial for the cloud section.
Wanted to upload my configuration.yaml but it seems it is not allowed for new users ;-(
Extract from configurations.yaml
# Cloud
cloud:
Messages in log
2018-07-22 20:50:51 ERROR (SyncWorker_9) [homeassistant.util.package] Unable to install package warrant==0.6.1: pyowm 2.8.0 has requirement requests<2.19,>=2.18.2, but you'll have requests 2.19.1 which is incompatible.
Command "C:\Users\edwen\AppData\Local\Programs\Python\Python36\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\edwen\\AppData\\Local\\Temp\\pip-install-n60nrbrc\\pycryptodome\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\edwen\AppData\Local\Temp\pip-record-uzhbflbl\install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in C:\Users\edwen\AppData\Local\Temp\pip-install-n60nrbrc\pycryptodome\
2018-07-22 20:50:51 ERROR (MainThread) [homeassistant.requirements] Not initializing cloud because could not install requirement warrant==0.6.1
2018-07-22 20:50:51 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: Could not install all requirements.
2018-07-22 20:50:51 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up:
- [cloud](https://home-assistant.io/components/cloud/)
Please check your config., notification_id=invalid_config, service_call_id=2470947478104-2>
2018-07-22 20:50:51 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
Please check your config. @ 2018-07-22T20:50:51.560598+02:00>>
I’m not seeing it on 0.74, with Python 3.6.3, but there may be something specific about your setup that’s causing the issues (that is, it’s Windows specific).
I’ve figured out what the problem was. One needs a C++ compiler for the crypto package.
I’ve used VS 2017 with only the C++ components. Started the command prompts for x64 and installed warrant.
If you get issues that something is missing (like malloc.h), then you did not install enough of VS.
I’ve installed everything that had to do with C++ (which took a while).
Then it was possible to install the warrant package.
subsequently i deinstalled vs as it was taking up a lot of space.
