Cloud on Windows
Hi guys,
Im very new here, but i cant get cloud to work.
I get this in the logs
2018-05-14 00:20:34 ERROR (MainThread) [homeassistant.requirements] Not initializing cloud because could not install requirement warrant==0.6.1
Try as a mite, i cant get warrant to install
Command “C:\Users\Administrator\AppData\Local\Programs\Python\Python36\python.exe -u -c “import setuptools, tokenize;file=‘C:\Users\ADMINI~1\AppData\Local\Temp\pip-install-e9h63sbg\pycryptodome\setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record C:\Users\ADMINI~1\AppData\Local\Temp\pip-record-363mq9r_\install-record.txt --single-version-externally-managed --compile” failed with error code 1 in C:\Users\ADMINI~1\AppData\Local\Temp\pip-install-e9h63sbg\pycryptodome\
Am i missing something or does warrant just not work on Windows?
I have got Unifi Video, and iCloud happy, along with my Dakin AC, but cloud (wanting this all to play with Alexa) is beating me :frowning:
Thanks in advance, Alan
Same issue here,can’t get warrant to install
If I run
py -m pip install warrant
I get the following error
Command ““C:\Program Files\Python36\python.exe” -u -c “import setuptools, tokenize;file=‘C:\Users\Matthias\AppData\Local\Temp\pip-install-prf8v4ua\pycryptodome\setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record C:\Users\Matthias\AppData\Local\Temp\pip-record-89gbjlqo\install-record.txt --single-version-externally-managed --compile” failed with error code 1 in C:\Users\Matthias\AppData\Local\Temp\pip-install-prf8v4ua\pycryptodome\
Windows 10
Did you ever find a sollution?
I’ve posted the same issue here https://community.home-assistant.io/t/cloud-does-not-initialize-due-to-incompatible-packages/60858/8
Sorry, i did. It was part of the php or .net stuff that is said you had to download. The community edition or something. I was getting the wrong package, once i got the right one, all was right in the world.
