skitex
(Stinuz)
1
dear,
I’m moving from a KNX energy meter towards a modbus TCP energy meter (countis e27)
I can succesful retrieve the values but I don’t succeed to reconfigure my energy dashboard.
to be able to get the correct kWh value I need to combine two modbus values (see picture below)
I combine the data with a template sensor to get the proper value
sensors:
countis_total_energy_kwh:
friendly_name: "Countis Total Energy kWh"
unit_of_measurement: 'kWh'
value_template: "{{ (states('sensor.countis_net_active_energy_balance') | float) + (states('sensor.countis_net_residual_active_energy_balance') | float / 10000) }}"
device_class: 'energy'
this looks like this
But I’m unable to select this newly created sensor inside the Energy dashboard configuration.
Help is welcome
Stijn
skitex
(Stinuz)
2
I was using the old templating option. It works with the new templating integration
template:
- sensor:
- name: "Countis Total Energy kWh"
unit_of_measurement: "kWh"
state: >
device_class: energy
state_class: measurement
last_reset: '1970-01-01T00:00:00+00:00'
this thread solved my problem
skitex
(Stinuz)
3
- sensor:
- name: "Countis Total Energy Wh"
unit_of_measurement: "Wh"
state: >
{{ (states('sensor.countis_net_active_energy_balance') | int / 0.001) + (states('sensor.countis_net_residual_active_energy_balance') |int / 10) | round(0) }}
state_class: total_increasing
I ended up with the code above to get the measurements right in the dashboard
