I have a large south facing window onto a balcony, with blinds controlled through HA. For practical reasons, there are three separate blinds.
I now want to lower these three as a group, i.e. have a single ‘cover’ like switch lower, raise and stop all three at the same time. (And still be able to raise/lower all three individually)
I can’t seem to find the right way to go about this. I’ve looked at template switches, but I can’t find the corresponding entities for covers ?
If you put all 3 in a group, and then put that group as an entity on a card, does that give you a master switch?
EG:
group:
balcony_window:
entities:
- [entity_id for blind number 1]
- [entity_id for blind number 2]
- [entity_id for blind number 3]
balcony_master_switch:
entities:
- group.balcony_window
I can’t test at the moment, but I think that should give you what you’re after?
Thanks for your suggestion. I tried it, but it doesn’t quite work:
I get a group Balcony which holds an entry balcony_window, marked with an icon with three dots in a triangle and no switch or state info, but there is a second group balcony_window that holds the cover switches.
After some more googling and reading, I thought I might be able to do it with a template, but there is no cover.template platform… Judging by this https://home-assistant.io/components/switch.template/ there is a switch.template…
Can anyone point me to the switch.template source… Feels like I should be able to create a cover.template
Made some progress on the cover template. Just managed to close one blind through the template.
Only problem is that the template only has an active stop and down button; the up button is greyed out. Guess I’ll have to look for the remote, it’s a bit dark in here
Edit: The demo works! Figured out the syntax for multiple entity_ids. I’ll sync and start the submission process.
Unfortunately, little progress to report; I got side tracked by problems at home and work. Hoping to pick it up again this weekend. (I’m travelling 'till friday)
Status:
Code for the template works; I’ll see if I can put this on GItHub
Test code fails, problem seems to be in the way I attempt to define a template cover in the test.
I’ll see if I can find the code in my github repo tonight; I’ll post a link if I can.
the code for the template, is in homeassistant/components/cover/template.py
test code is in tests/components/test_template.py
Code works fine in my environment, but like I said, the template creation in for instance test_template_state_text fails; the first assert_component_setup(1, ‘cover’) fails, looks like nothing is created.
I’m needing something similar. I have 3 cover entites to control my bedroom shades. I want a single switch that will be exposed to google home so I can say “hey google, close the master bedroom shades”.
I looked at your github repo and didn’t see the files you mention. Perhaps they are on a different branch?
It’s been a while, so I can’t be too sure about the exact locations. I never had the time to finish this properly.
I do see the source code, but it does look I forgot to checkin the test code. I’ll check if I still have it on disk somewhere.
I currently use a different approach, covers as a group:
cover:
- platform: group
entities:
- cover.left_front
- cover.right_front
This gives a single switch to control two or more covers at the same time. Turns out to be just what I wanted .
I know it’s an old topic, but i struggle to get the above working.
I grouped my cover switches into one group.
Then I made a button in Lovelace. But when I press it it shows: “couldn’t find service cover.turn_off” or “couldn’t find service cover.turn_on”.
Which is obvious because for the single covers, the services are named cover.toggle, cover.open and cover.close.
