You need to call it like this:
http://ip:port/broadcast_message?message=blah
Also, no quotes or anything around the message.
Ah, thank you!!! Is the command working? I got the broadcast to work with that, but the command will not do anything, just says ok but no action
MThe command endpoint is like this:
http://ip:port/command?message=blah
The command endpoint is to control smart home things that currently are controllable through google, but do not have a way to integrate into home assistant directly.
For example, if you had a bathroom light that was added to your google home, but that brand is not able to added to home assistant, then the command could be āturn off the bathroom lightā
Thank you sir, working now.
doesnt seem to work for playing things on youtube tv. I have a nvidia shield i can say āhey google turn on fox on youtube tv on living room tvā and it goes right to it. the command through the add on shows me āi dont know how to help with thatā. I looked through my activity and worded exactly the same as I spoke it. I was going to use it for some quick buttons to goto dif channels. and some automationsā¦
Looking through the thread it looks like google have disabled being able to cast things through this unfortunately
Thanks so much for your work on this!!! Getting this up and running was a major break through for me, and has enabled me to finally control everything in my house without having to re flash it all.
Thank you!!
Iām having some trouble creating the notify component for /command. Iām able to use the command without issue from a web gui, but I would like to use a hard coded /command notify that I can use in an automation or script. I see in posts above that people seem to be using input text to form a command, but I am wanting to send the same command each time, not type input for the command. Perhaps Iām not understanding what the input text components are as mentioned above. If someone could provide a little guidance, that would be great. (Iām pretty new to Home Assistant)
The entry in my notify.yaml looks like this:
- name: Turn Off Bathroom Plug
platform: rest
resource: http://192.168.200.2:5000/command?message=turn off bathroom plug
When I call the service I get the following error:
Invalid service data for notify.turn_off_bathroom_plug: required key not provided @ data['message']. Got None
that error comes up if you have incorrect indentation. you need to use the code button when posting on here but it looks like your code is missing the required two spaces. when posting code, select the code and use the </> button
I assure you the code in the yaml file has the two space indention, using the code button here actually made it look worse. I think itās because I copied it from a Remote Desktop session and didnāt bring the proper formatting with it.
Anyway, letās say I have the indention, is the rest of the notify entry correct for this add-on? I feel like itās not, and I should have a āmessageā parameter, but the REST notify component doesnāt list message as an available parameter.
Notify components are not designed to be static, so in the service call you have to include a message. You should be able to include it with any data and it should work.
Of course, thatās it! Duh! I had it in my mind that this was somehow supposed to be different. I set it up like my iOS notifications, works fine. Thank you!!
Beautiful add-on! Thanks for sharing it
I noticed that the maximum of characters that can be sent (including spaces) is 180 ~ 192 maximum. Is this my problem, or a limitation of google APIs?
hi @AndBobsYourUnclem thanks for the add-on. I have some problems with the google_assistant.json file and i hope you can guide me:
I 'm running Hassio on docker on ubuntu 18.04, with the following add-ons samba, ssh, duck-dns. I installed the component Google Assistant (NO the Cloud setup) the manual setup and now i can see the HA devices, automations, etcā¦ on my phone and control them with the GA.
Iām trying now to install the google assistant webserver add-on. I added the repository to the add-on store and installed.
My problem is that I donāt know where is the json file or how to genereate one. this link is outdated https://www.home-assistant.io/addons/google_assistant/ so iām not sure if i can follow this instructions and also because I first installed the GA component I already have an project_id and a App_key created for the component to run.
thanks in advance
Google limitation I think, Iāve noticed it myself around 200 characters.
Can I use this to get my google mini to start playing a Spotify playlist.
The official Spotify component keeps loosing my sources and I would really like some way to resolve this.
Thank you.
mmm I will have to study a way to divide the information into two or more parts. A counter of characters or similar things.
No, not possible at this time.
I thought of doing something similar myself, but then realised I would get the BING before the broadcast twice and didnāt fancy it.
Just installed the addon with the json, great work @AndBobsYourUncle
Broadcast commands work fine, but Iād like to be able to get āturn off tvā working (which works fine from the google assistant phone app or with the home mini)
However, when trying with the browser I get a āmessageā: āInternal Server Errorā response instead of āstatusā: āOKā
EDIT: SOLVED AFTER A HASSIO RESTART!
