I am still having initial connection issues - despite reading all of the above and clearing cookies (hassio and duckdns ones -any others?), adding port forwarding for 7080, 8123, 3218 and having the following code in my config.yaml:
I can access mydns.duckdns.org:8123 fine.
I can access hassio.local:8123 fine
I cannot access hassio.local:7080
I cannot access mydns.duckdns.org:7080 - it goes through manual setup and then I get the error popup window with my hassio url (irrespective of whether local or duckdns one - both of which I can bring up directly).
I really like this frontend. It is simple and very easy to set up. The layout is great - and it is easy to do a configuration that is usable for non-tech users.
But there is one feature that I would really really like, and that is media player control.
I use Sonos devices all around my house, and it would be great to be able to see what is playing, starting/stopping music / turning volume up/down and skipping tracks
Just a message to share experience. I was completly mad with this ! I had always the unable to connect error. This was because i had a “#” sign in my api_password… removed it and now works like a charm !
I’m sorry to say, that this add-on is no longer supported or maintained. This add-on required a lot of time to support since a lot of you had issues with getting (and keeping) the control panel in a working state.
This caused an awful lot of support questions, which take a lot of time. This add-on (not the control panel) does not actually do much, which makes it even more painful. Therefore I have decided to drop the add-on.
You can still install this control panel manually or use the hosted version
offered by the author. For more information see:
Bad luck, I finally got it working again after disabling night mode on my google home devices.
Well, I hope it’ll continue working even without being supported, and that someone will pick this concept again to make a new supported module.
I have a big problem using your control panel.
I can not see the entities in any way, the psw API is correct, I can connect to the hassio server, but I do not see any entities.
if I try to go to http: // hassio.local: 8123 / api / states? api_password = YOUR_PASSWORD_HERE, I see only 2 square brackets, no entities are displayed.
I tried all the configurations.
thank you very much for your help, it would be wonderful for me to be able to use your addon!
if i enable the debug mode in the configuration of your control panel, the message “WebSocket Events Socket connection closed, reconnecting …” appears at the top right.
the id must remain the same as the script (“id”: “e1aba709becb4196a27574b0b7816103”) or do I put id in my configuration file (“id”: 66f7f89a8def437490baf770679c7c03 ")?
