Community Hass.io Add-on: Home Assistant Control Panel
Try this
ok, removing the cookies worked! so what manual settings should I use? I tried using both port numbers and niether worked. does it need the http: ?
http://192.168.0.13:8123 And your HA password if you set one up.
same issue… loading screen but its not happy with the URL
could it be due to SSL / no SSL? I use SSL for my DuckDNS connection but when at home chrome is not happy because the certificate is not for my local IP
Yeah sorry should of asked if SSL, Redo it all again with https://
thank you! I think I have success!
it does work but I find that functions are extremely delayed. Simpoly turning on a light takes quite a few seconds whereas its instant via the normal HA frontend.
EDIT: for some reason it seems to be getting better :thinking:
Not sure about that one :slight_smile: mine is almost instant… I am not using the addon though mine is local on the pi.
Yep, mine is now like that. not sure what was going on with the delay but its fine now. Thanks heaps for your help mate
Hi !
Is there a way to configure the time in french and have a 12h/24h time ?
Thanks !
Is there any way to scroll down as I lose alot of my switches and sensors off the bottom :stuck_out_tongue:
Same here. Should we go into some of these add-ons files to change that? How about the weather display in the screenshot?
With the current state of the add-on, Is there still a benefit to run it locally iso via add-on?
Fantastic work, congrats.
I have a strange problem. It appears that I cant access the control panel through any of my iOS devices, but accessing it from my macbook works fine.
I get “A problem occured with this webpage, so it was reloaded”. It then loads again for a while before showing an error. I am using the exact same connection settings as on my macbook.
I tested that I can access home assistant on the iOS device which works fine.
I tried multiple iOS devices, clearing cache, allow/disallow cookies, changing javascript settings, other browsers, but no luck. I am using latest iOS versions, btw.
I would love to have this awesome plugin working on my tablets, so I can put it on the wall :slight_smile:
Any ideas?
@frenck Having a issue with the background weather image. Everything else is working solid VERY NICE WORK.
So here is what I am seeing using Weather Underground api using sensor.pws_weather_1n as the condition entity. (which has a image)
When I load the https://xxx.xxx.xxx:7080 and open up dev tools I see a error
“Failed to load resouce: the server responded with a 415 error…” it is trying to access https://reformedreality.com/media/300/40/hacp-bg/bg-{{i}}.jpg which I assume is supposed to be my background image I am missing :slight_smile:
Anyone have a idea on how I might be able to fix this ? I have cleared cache etc… with no luck
can someone help please, already clean cache and everything is on the top of the page
Hi!
I read that there are plans to include more entity types. I’m especially interested in the Cover entity. I realize that this is not a quick job, as it has to fit in the tile lay-out etc. Any idea as to when this might make it’s way into HACP? As covers are the reason why I am using Home assistant (on a hot day, shut the covers to keep the living room bearable :wink: )
TIA
Hey,
I have the same problem. On all devices. Did someone find a solution for this?
Daranto
As far as i know…nop
I’ve got a script that I can ‘execute’ on the main home assistant UI but on the control panel, pressing the button does nothing. Anyone else experienced this?
I just found this add-on today and have successfully installed it. I have panel access via a Samsung phone that I want to use as a wall mounted monitor for my house front camera . I can do that via this control panel no problem, but the camera image is too tiny to be useful.
I have not seen the method to resize the tiles for each entity, is there a how-to guide for that some place ?
Also for non-image entities (like Room Temp), is there a way to increase the tiles font size (for the vision impaired like me) ?
Thanks.
