Okay makes sense. Is there a reason why the plugin is not picking up the garage door? Garage door is controllable through HA.
That is an HA/Homebridge specific questions I donāt have an answer to since I do not use any covers type of stuff myself.
thats fine, just as long as I know. Hoping HASSIO gets released as a docker in the near future.
That is not a bad idea
Homebridge stopped working
this is the loge I get running log as trace
[cont-init.d] 50-config.sh: executing...
TRACE: hass.directory_exists: /config/homebridge
TRACE: hass.file_exists: /config/homebridge/config.json
[cont-init.d] 50-config.sh: exited 0.
[cont-init.d] 60-ipv6-hotfix.sh: executing...
TRACE: hass.config.false: enable_ipv6
TRACE: hass.jq.is_boolean: /data/options.json .enable_ipv6
TRACE: hass.jq.is: /data/options.json .enable_ipv6 boolean
TRACE: hass.jq: /data/options.json .enable_ipv6 | if type=="boolean" then true else false end
TRACE: hass.config.get: enable_ipv6
TRACE: hass.config.exists: enable_ipv6
TRACE: hass.jq.exists: /data/options.json .enable_ipv6
TRACE: hass.jq.is_string: /data/options.json .enable_ipv6
TRACE: hass.jq.is: /data/options.json .enable_ipv6 string
TRACE: hass.jq: /data/options.json .enable_ipv6 | if type=="string" then true else false end
TRACE: hass.jq: /data/options.json .enable_ipv6 // false
[cont-init.d] 60-ipv6-hotfix.sh: exited 0.
[cont-init.d] 80-user-packages.sh: executing...
TRACE: hass.config.has_value: packages
TRACE: hass.jq.has_value: /data/options.json .packages
TRACE: hass.jq: /data/options.json .packages | if (. == {} or . == []) then empty else . end // empty
TRACE: hass.has_value:
[cont-init.d] 80-user-packages.sh: exited 0.
[cont-init.d] 81-user-scripts.sh: executing...
TRACE: hass.config.has_value: init_commands
TRACE: hass.jq.has_value: /data/options.json .init_commands
TRACE: hass.jq: /data/options.json .init_commands | if (. == {} or . == []) then empty else . end // empty
[cont-init.d] 81-user-scripts.sh: exited 0.
[cont-init.d] 82-user-plugins.sh: executing...
TRACE: hass.config.has_value: plugins
TRACE: hass.jq.has_value: /data/options.json .plugins
TRACE: hass.jq: /data/options.json .plugins | if (. == {} or . == []) then empty else . end // empty
[cont-init.d] 82-user-plugins.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
starting version 3.2.2
[services.d] done.
Found user 'avahi' (UID 86) and group 'avahi' (GID 86).
Successfully dropped root privileges.
avahi-daemon 0.6.32 starting up.
chroot.c: chroot() helper started
WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Successfully called chroot().
Successfully dropped remaining capabilities.
chroot.c: chroot() helper got command 02
No service file found in /etc/avahi/services.
*** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
*** WARNING: Detected another IPv6 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Joining mDNS multicast group on interface hassio.IPv6 with address fe80::42:a1ff:fe96:eb82.
New relevant interface hassio.IPv6 for mDNS.
Joining mDNS multicast group on interface hassio.IPv4 with address 172.30.32.1.
New relevant interface hassio.IPv4 for mDNS.
Joining mDNS multicast group on interface eth0.IPv6 with address fe80::1256:ab7:5550:772c.
New relevant interface eth0.IPv6 for mDNS.
Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.29.203.
New relevant interface eth0.IPv4 for mDNS.
Network interface enumeration completed.
Registering new address record for fe80::42:a1ff:fe96:eb82 on hassio.*.
Registering new address record for 172.30.32.1 on hassio.*.
Registering new address record for fe80::1256:ab7:5550:772c on eth0.*.
Registering new address record for 192.168.29.203 on eth0.*.
Server startup complete. Host name is hassio.local. Local service cookie is 2858995729.
/usr/lib/node_modules/homebridge/node_modules/decimal.js/decimal.js:3442
"// number with exponent >= 150000000000p100 (9e15 / 6 = .5e15)( so instead recall this
SyntaxError: Invalid or unexpected token
at createScript (vm.js:53:10)
at Object.runInThisContext (vm.js:95:10)
at Module._compile (module.js:543:28)
at Object.Module._extensions..js (module.js:580:10)
at Module.load (module.js:488:32)
at tryModuleLoad (module.js:447:12)
at Function.Module._load (module.js:439:3)
at Module.require (module.js:498:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Characteristic.js:6:15)
/usr/bin/run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
Got SIGHUP, reloading.
write() failed: Broken pipe
Failed to open /etc/resolv.conf: Broken pipe
Got SIGTERM, quitting.
Leaving mDNS multicast group on interface hassio.IPv6 with address fe80::42:a1ff:fe96:eb82.
dbus[654]: [system] Reloaded configuration
Leaving mDNS multicast group on interface hassio.IPv4 with address 172.30.32.1.
Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::1256:ab7:5550:772c.
Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.29.203.
avahi-daemon 0.6.32 exiting.
[s6-finish] sending all processes the KILL signal and exiting.
my Options
"log_level": "trace",
"avahi_interfaces": "",
"avahi_hostname": "hassio",
"avahi_domainname": "local",
"enable_ipv6": true,
"packages": [],
"init_commands": [],
"plugins": []
My config.json
"bridge": {
"name": "Home Assistant",
"username": "B8:27:EB:9B:CC:58",
"port": 51826,
"pin": "717-89-596"
"description": "Homebridge for Home Assistant",
"accessories": [],
"platforms": [
"platform": "HomeAssistant",
"name": "HomeAssistant",
"host": "http://homeassistant:8123",
"password": "XXXXXXXX",
"default_visibility": "visible",
"supported_types": [
"automation",
"binary_sensor",
"climate",
"cover",
"device_tracker",
"fan",
"group",
"input_boolean",
"light",
"lock",
"media_player",
"remote",
"scene",
"sensor",
"switch"
"logging": true,
"verify_ssl": true
@frenck Thanks for the updates!
But now homebridge-zp requires Homebridge 0.4.29. So, my question is: can one prevent the add-on from looking for the latest plugin version? Is it possible to point to/install locally an older version?
i tried adding both Chamberlain and lift master but am getting the below error. Iām not 100% sure where i should be putting the plugin in he config?
/usr/lib/node_modules/homebridge/lib/api.js:122
throw new Error("The requested platform '" + name + "' was not registered by any plugin.");
Error: The requested platform 'LiftMaster2' was not registered by any plugin.
at API.platform (/usr/lib/node_modules/homebridge/lib/api.js:122:13)
at Server._loadPlatforms (/usr/lib/node_modules/homebridge/lib/server.js:284:45)
at Server.run (/usr/lib/node_modules/homebridge/lib/server.js:80:36)
at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:40:10)
at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (module.js:571:32)
dbus[661]: [system] Reloaded configuration
Leaving mDNS multicast group on interface hassio.IPv6 with address fe80::42:6eff:fe13:3b60.
Leaving mDNS multicast group on interface eth0.IPv6 with address 2607:fea8:919f:f40a:c7:2d81:2cb8:cd2b.
Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.0.27.
@scheeko You cloud try adding [email protected]
to the plugins list.
Please be sure to install the plugin as well. See the documentation for more information: https://github.com/hassio-addons/addon-homebridge#option-plugins
Ya i read the documentation but when I try to add the plugin in the config I get json erros. Maybe an example will help me understand.
@Maaniac I absolutely want to help, but your question does not make sense to me. If you need help with how JSON must be formatted and/or works, I suggest youād use the power of the Google force. An example of how to install plugins is listed in the documentation as well.
Frenck,
Okay I think I finally figured it out. I was trying to add the plugin information for the chamberlain package within the config.json and that is why I was getting errors. After reading the main documentation for homebridge-homeassistant and checking your hass.io package again I realized that I should have been adding the additional packages in the options panel within your plugin and not in the json file. Not sure how I missed that
Anyway I was able to add the garage door by changing the customize.yaml to include āhomebridge_cover_type: garage_doorā.
Thanks again for trying to help and for the great plugin.
Add-on: Homebridge v2.0.1
This release fixes some minor issues reported by you guys!
Thank you all for the feedback!
Added
- Made git available by default #44
Fixed
- Wonāt start; sed: unmatched ā/ā #45
Changed
- Use the Hass.io to Home Assistant proxy by default
- Upgraded addon-base image to v1.0.1
This update is now available in your Hass.io panel.
Note: Please be sure you are running the latest Supervisor (0.73 or higher).
Thanks @frenck. Iām not entirely sure if Iām understanding your suggestion, as the homebridge-homeassistant is not homebridge itself. Or does your add-on pull the version from there?
In any case, I did try what you suggested, but when restarting homebridge at hassio, the log files says:
npm ERR! code ETARGET
npm ERR! notarget No matching version found for [email protected]
npm ERR! notarget In most cases you or one of your dependencies are requesting
npm ERR! notarget a package version that doesn't exist.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2017-10-26T16_12_06_660Z-debug.log
FATAL: Failed installing plugin [email protected]
Thanks for any clarifications!
Sorry, my bad @scheeko, the example I gave was the Home Assistant plugin.
I meant try adding [email protected]
to the plugins list of the add-on configuration.
Nevertheless, you where stating 0.4.29, but it does not exist, so⦠dunno, your info was impossible, to begin with.
See the list of available Homebridge releases on their GitHub page: https://github.com/nfarina/homebridge/releases
Add-on: Homebridge v2.1.0
Changed
- Upgraded NodeJS to 8.x #47
- Upgraded
to v3.0.1
Iām not seeing the last two updates to Homebridge on Hass.io. Iām currently on version 2.0.0 and thereās no option to update it. I have updated Homebridge in the past but just these two latest releases I havenāt seen. Iām running the latest version of Home Assistant (0.56.2), Supervisor (0.73) and Host OS (1.1).
I didnāt see it either, but found out I needed to go to the Hass.io panel, click the add-ons shopping bag (or whatever that icon is), then click the update curl in the top right corner. Then it showed up as an update on the Homebridge line.
Hope that helps.
Thanks, that worked.
Thereās an āAuto Updateā toggle near the top of all these add-ons. What is that supposed to do?
