I’m not sure! Depends on the input & output streams. Shinobi supports stream copies (in case the input & output streams are the same). They are pretty lightweight, so you might actually put up some cameras in that case.
I would love to learn some real world experiences on that specific one.
I was having issues with starting add-on, it would immediately stop so there were no logs recorded under the add-on
If you look under Hass.io -> System and at the system logs i saw that Port 5000 was already in use
[hassio.docker] Can’t start addon_a0d7b954_shinobi: 500 Server Error: Internal Server Error (“driver failed programming external connectivity on endpoint addon_a0d7b954_shinobi (8f2bb6d41daceb4001d3c6a64154fd4c8143db79b13981c678e0badde8ea0000): Bind for 0.0.0.0:5000 failed: port is already allocated”)
Turns out the Google Assistant Webserver add-on was using the same port.
I changed the port number to 5001 and now able to start the Shinobi add-on
It is Hass.io 0.66.1 install on a raspberry pi 3 model B. I am at work, so I can’t test much right now. When I tried it the other day it would not start at all through Hass.io and no logs were a shown. Changing the log_level did not seem to affect it. I will try changing the port to see if that works Appreciate the help!
Edit: probably should have tested the port change before typing this… Changing the port to 5001 did allow it to start. Thanks @uniqueandy29
Just wanted to say that I got this up and running first time… This after me trying and failing to configure Shinobi multiple times on docker, linux etc… This add-on worked straight away.
Just one piece of advice… I dont think that this is really going to work on a RPI. Especially if you have more than a couple of camera’s. More so if you have a big HA config. I have noticed HA can be quite resource hungry, so If you have a big HA config and more than a couple of camera’s then I would recommend putting any NVR onto a standalone box.
I have a i7 NUC with 16GB ram, so that is quite possibly why my experience with this addon was seamless and a pure pleasure… Thanks for all the hard work in getting it up and running… Now I just cant wait for the Shinobi Component for HA ;-)!
Up and running! As @uiguy pointed out, the performance is not the best on RPi, and the RAM looks to be fully maxed. Might be upgrading to something more powerful to get everything I want. Thanks @frenck!
For those of you that can’t get the add-on to start, you most likely have appdeamon for hadashboard installed and it also uses port 5000 for it’s http port as well. @Frenck you might want to select a different default port for your hassio add-on container.
Can anyone help me getting a local (USB Webcam) feed into the Shinobi Add-on? I have a Genius WideCam F100 plugged into my NUC and I want to be able to expose this local cam as stream into my main instance oif Shinobi…
I also have the MOtion Add-on which I disabled to try and get the local cam working but couldnt get it right…
That sounds like you are on the wrong login screen. There are multiple. The super user login screen is the only one that accepts the super user logins. Ensure you are login in into /super (ending URL). See the installation steps for the details.
The addon is working really well for me!
I just have one question which I couldn’t find an answer for:
Since this is running in a docker container, how could you install the motion plugin?
