Wow, thanks for this great card!!!
Is there any chance to add an option for hide all tabs (full screen option)?
At the moment you can hide the header completely with “header: false”, but I do plan to add config to hide just the tabs (only element that’s missing that option at the moment) and am working on a mode where the header is hidden with a small tab to expand. So, essentially, “watch this space”.
In the compact header is it possible to have “Titles” instead of icons for the various screens in the dashboard, for example Sensors 1, Sensors 2, etc.
Yup. That’s just part of lovelace, though. Compact-Custom-Header doesn’t change that.
Just use “title: home” instead of “icon: mdi:home” in your view.
Check out the readme on github for usage. More soon.
WOW, that was fast!!! Thanks!!
Hi @mayker,
I’ve installed but I get an error:
ERROR (MainThread) [frontend.js.latest.201811211] http://internal-ip:8123/local/custom_ui/compact-custom-header/compact-custom-header.js?=0.0.6:13:51 Uncaught TypeError: Cannot read property ‘split’ of undefined
any hint?
Hey this doesn’t seem to work too well with the new storage lovelace. If you go into Configure UI it doesn’t like the compact header. I’ve included pics of what it looks like.
It also is adding a card for the compact header where if there aren’t many cards on a view, they look off centered. You can see it in the pictures as well.
Pictures: https://imgur.com/a/bLwmqsm
And just for reference, here’s my code for this view:
- title: Basement
icon: mdi:arrow-down-bold-box
cards:
- type: picture-elements
image: /local/room_pic/Guest_off.jpg
elements:
- etc
- type: vertical-stack
cards:
image: /local/room_pic/Basement_off.jpg
elements:
- etc
- type: custom:mini-media-player
entity: media_player.basement_dot
- type: custom:compact-custom-header
clock: options
clock_format: 12
clock_am_pm: true
Not the first issue I’ve heard about this card and 0.84. I’m sure I’ve got plenty of work to do to make it compatible. I unfortunately am not on 0.84 yet myself, so I can’t test quite yet. I’ll probably be able to check it out this weekend, but bear with me. Free time is a bit limited and the holidays won’t help.
Also, a possible fix for the layout issue. Throw this card inside that vertical stack. Otherwise it looks like its working okay for you in 0.84 (aside from overlap in edit mode), so that’s not looking too bad.
- title: Basement
cards:
elements:
- etc
cards:
elements:
- etc
clock: options
clock_format: 12
clock_am_pm: true
Yea, that’s what I’ve been doing! Annoying little work around, but it works.
It’s also just a little interesting as in you can’t really use the config editor if you want to add custom components, so I don’t think I’ll be using it much anyway. But I’m sure there’ll be something in the future where it’ll work! So I guess as long as you get it ready for that, then you’re gold.
Yeah, I think if you use a fair bit of custom cards, etc. then yaml mode is the way to go for now in 0.84, until there is another solution, but again, I haven’t tried it out yet.
So this is mine… added the card on the last page and it’s adding an extra column.
- cards:
- cards:
- entities:
- sensor.busmonitor1
- sensor.busmonitor2
- sensor.trainmonitor1
- sensor.trainmonitor2
show_header_toggle: false
title: Transport
type: entities
- entities:
- sensor.caltex_woolworths_waitara_pdl
- sensor.caltex_woolworths_turramurra_pdl
- sensor.caltex_st_ives_pdl
- sensor.caltex_st_ives_north_pdl
- sensor.caltex_woolworths_glenrose_pdl
- sensor.caltex_belrose_pdl
title: NSW Fuel Watch - Sydney
type: entities
- entities:
- sensor.caltex_kariong_pdl
- sensor.caltex_woolworths_pdl
- sensor.caltex_gosford_west_pdl
- sensor.caltex_gosford_west_pdl_2
- sensor.caltex_gosford_west_pdl_3
- sensor.caltex_woolworths_erina_pdl
- sensor.caltex_wyoming_pdl
- sensor.caltex_woolworths_tuggerah_pdl
- sensor.caltex_woolworths_tuggerah_north_pdl
- sensor.caltex_wyong_pdl
- sensor.caltex_wyong_pdl_2
- sensor.coles_express_kariong_dl
title: NSW Fuel Watch - Central Coast
type: entities
- type: 'custom:compact-custom-header'
icon: 'mdi:train'
title: 'Buses, Trains & Fuel'
This is from the ‘raw’ editor in 0.84.1
I tried it on the first card as well but I then ended up with 4 colums on that card so moved it to last and was 2 columns, now 3 with third one empty/blank.
Any way to remove extra column?
see above, put the card in the vertical stack
OK! Thought I did that… the new UI editor makes it a bit hard to tell sometimes.
I do get this:
and it’s impossible to exit the editor.
Also added this:
# Custom Component Updater
custom_updater:
show_installable: false
hide_sensor: false
track:
- components
- cards
- python_scripts
component_urls:
- https://raw.githubusercontent.com/pnbruckner/homeassistant-config/master/custom_components.json
card_urls:
- https://raw.githubusercontent.com/kalkih/mini-media-player/master/tracker.json
- https://raw.githubusercontent.com/maykar/custom-lovelace/master/tracker.json
to config yaml but it’s not showing in the updater?
also tried this:
card_urls:
Both of your issues with the card are exactly what I was just going over with kfinderman in the handful of posts from the last hour. I have updated the readme to include the fix for layout issues (vertical-stack) and posted an issue on the github.
To summarize: I am very aware of the issues with 0.84, I’m not on 0.84 and may not be for a little while, until then I am unable to fix issues pertaining to 0.84.
Custom updater no longer supports cards on 0.84 unless in yaml mode. If you are using yaml mode and still having issues I’m not sure what it might be. Nothing on my side has changed and is still functional as far as I can tell. The url from the readme and from your first posted custom-updater code is correct.
Ah I see. Maybe if I add this to the YAML file it will pick it up. All my other cards are showing except this one. I updated one yesterday as well. Maybe I need to check it actually updated and the .storage agrees with the yaml…
Thanks.
