Compact Custom Header
To avoid confusion I just pushed a new release, not listed as a pre-release, and added type: module to the readme. HACS will now display this info.
I’ve used the header with transparent background:
Now, with same setup:
How can be eliminated this gray background?
I see the issue and will update later today with a fix. Thank you
1.1.3 Update:
  • Added option to hide “Configure UI” from menu.
  • Fix for shifted background causing solid color behind a transparent header.
  • Added warnings for all options that remove the ability to edit from UI and how to restore the default header with ?disable_cch. You can toggle these warnings as well.
Thank you very much mayker! :+1::beers:
Thanks a lot, hide_config: true is what you use if anyone else wants to try it
Is it possible that the “Voice Button” no longer exists in the header of Hassio 0.95?
It still exists, but you need to have conversation: in your config:
https://www.home-assistant.io/components/conversation/
In some browsers it doesn’t display as well.
Thanks for the information. I see the button with Google Chrome, in Safari (MacOS) but not.
It doesn’t work on Apple products unfortunately. It should work on chrome though.
nice, and flawless transition to a cleaner setup. again cut a few lines of config :wink:
and works with !include still. cool.
Just upgraded. Went smooth as silk!! Thanks @mayker!
@mayker Just upgraded and It went well. Everything is working fine but I am logging errors… (HA 0.95.0)
2019-06-27 22:46:20 ERROR (MainThread) [frontend.js.latest.201906260] http://hassio-pm:8123/community_plugin/compact-custom-header/compact-custom-header.js:227:34 Uncaught TypeError: Failed to execute 'observe' on 'MutationObserver': parameter 1 is not of type 'Node'.
here is my config…
cch:
  active_tab_color: red
  chevrons: true
  clock_am_pm: true
  clock_date: true
  clock_format: 12
  date_locale: en-US
  disable: false
  hide_tabs: 16
  options: clock
  sidebar_closed: true
after updating to 1.1.4 the CCH settings menu disappeared:
I use HA: 0.95.1
CCH config:
cch:
swipe: true
swipe_animate: swipe
voice: hide
error from browser console:
compact-custom-header.js:412 Uncaught (in promise) TypeError: Cannot read property ‘style’ of null
at styleButtons (compact-custom-header.js:412)
at run (compact-custom-header.js:103)
at compact-custom-header.js:88
Hi, I’m having the same issue… Running HA 0.95.
My config and WEB UI “info” error:
cch:
  options: show
  header: true
  sidebar_swipe: true
  menu: overflow
  notifications: overflow
  swipe: true
  swipe_animate: flip
  swipe_wrap: true
http://192.168.1.30:8123/community_plugin/compact-custom-header/compact-custom-header.js:420:1 TypeError: buttons[button].shadowRoot is null
I’ve installed via HACS. Except for the blank settings page, all settings entered in Lovelace config works fine.
@Albertjvanr @Grzech @cdrom1028
Please try the latest version (1.1.6) and let me know if it helps. Thank you
Hi, thank you for the response. But I’m still getting the same error. Refreshed, cleared cache etc…
I’m just updated to 1.1.6, but error still exist.
latest working was 1.1.2
1.1.7 - no improvement
1.1.8 - no improvement
1.1.9 - success, menu visible again
Hi, I’m not able to see the Menu, I have tried 3 browsers, cleared cache and reread the docs… I could use a hand.
Running HA 0.95.0, My config and error:
cch:
  menu: overflow
  chevrons: false
  clock_am_pm: true
  clock_date: false
  clock_format: 12
  date_locale: en-US
  disable: false
  hide_tabs: 16
  options: clock
  swipe: true
  swipe_amount: 10
  swipe_animate: none
  swipe_skip: ''
  swipe_wrap: true
  swipe_prevent_default: false
  exceptions:
    - conditions:
        user: User_1
        user_agent: Mobile
      config:
        hide_tabs: '2,4,5,7,8,9,19,12,13,15'
http://hassio-pm:8123/community_plugin/compact-custom-header/compact-custom-header.js:229:34 Uncaught TypeError: Failed to execute 'observe' on 'MutationObserver': parameter 1 is not of type 'Node'.
With the latest update to 1.1.8 (15 mins ago) I see the menu’s fine, ahhh, that was nice with the swiping on my cellphone :smiley:
Though, odd thing is, it moves the CCH: heading to the top, above the ‘Ressources’, and when it does that, the CCH menu item doesn’t display, moving it below again, makes it work???
