Another quick update to give it one more shot today. In some cases while in edit mode you’ll just see the edit bar, but nothing else. Happens if for some reason the card couldn’t be found or if it’s contained in another card like vertical-stack. It’s a workaround for now. Also fixed “header: false” not working properly.
also fixed the typo on the version number. new version is 0.1.1
Thanks for mentioning it @DavidFW1960
I wondered if that was a typo…
I’m seeing the same issue and getting this error (cleaned cache):
Uncaught TypeError: Cannot read property ‘shadowRoot’ of null
at compact-custom-header.lib.js?v0.1.1:31
hui_view = div_view.querySelector(‘hui-view’).shadowRoot;
Help me: ERROR (MainThread) Uncaught TypeError: Cannot read property ‘shadowRoot’ of null
Update:
Apologize for the delay, updated to address the 0.84 issues. Please, let me know how it works out for you. No notes for the update really, just had to tweak a good bit to try and cover all bases: card in panel view, in container card like vertical-stack, yaml mode, normally placed, and edit view.
Well this is a new one:
https://my-domain.duckdns.org/local/custom-lovelace/compact-custom-header/compact-custom-header.js?v=0.1.2:44:28 Uncaught ReferenceError: yaml_mode is not defined
Yup, that’s my bad. Updated
OK that seems to be working now. Thanks.
Thanks for the update!
On pages with panels I get this error now:
compact-custom-header.lib.js?v0.1.3:94 Uncaught TypeError: Cannot read property ‘0’ of undefined at VM45 compact-custom-header.lib.js:94
container_edit = (column[0].querySelector(‘hui-card-options’) != null);
Just made another quick update to address that error. Thanks!
Hi David
How are you using Lovelace? i am using the raw config editor in lovelace and its a bit tricky.
i have lovelace: in my configuration.yaml file but i still get the same as you
This is my raw LL
resources:
- type: js
url: >-
/local/lovelace/custom_cards/compact-custom-header/compact-custom-header.js?v=0.0.1
title: Home
- badges: []
cards:
- entities:
- input_boolean.door_alarm_mode
- light.dining_rm
- switch.fox_lamp
- light.dining_lamp
- light.reading_lamp
- light.side_lamp
- light.corner_lamp
- light.sitting_rm
show_header_toggle: false
title: Sitting Room
type: entities
- entity: camera.sitting_camera
show_state: false
title: null
type: picture-entity
- cards:
- entity: light.side_lamp
type: light
- type: 'custom:compact-custom-header'
notification: true
menu: true
options: false
voice: false
clock: notification
clock_format: 12
clock_am_pm: true
header: true
type: vertical-stack
- entities:
- switch.hall_light
- switch.landing_light
- light.hall_lamp
- sensor.sitting_temperature
- sensor.sitting_humidity
title: ' '
type: entities
type: light
icon: 'mdi:sofa'
path: default_view
theme: default
title: Sitting Room
Any help please. and i did do a cache refresh.
Make sure you’re using the latest version and incrementing the version number in resources. Does any error display?
Also try taking it out of that vertical stack
Ok so i changed the version number to 0.1.4 and done a cache refresh and still the same.
- type: js
url: >-
/local/lovelace/custom_cards/compact-custom-header/compact-custom-header.js?v=0.1.4
Taken out vertical stack as well but gives errors.
What errors?
OK i have tried this.
- cards: null
clock: notification
clock_am_pm: true
clock_format: 12
header: true
menu: true
notification: true
options: false
voice: false
Got this
What is “cards: null” doing there? What errors are displaying?
This is what your code should probably look like:
resources:
- type: js
url: >-
title: Home
- badges: []
cards:
- entities:
- light.dining_rm
- switch.fox_lamp
- light.dining_lamp
- light.side_lamp
- light.corner_lamp
- light.sitting_rm
title: Sitting Room
type: entities
show_state: false
title: null
type: light
notification: true
menu: true
options: false
voice: false
clock: notification
clock_format: 12
clock_am_pm: true
- entities:
- switch.hall_light
- light.hall_lamp
title: ' '
type: entities
type: light
icon: 'mdi:sofa'
path: default_view
theme: default
title: Sitting Room
