Compact Custom Header
I’m trying to hide all tabs and make the alarm tab the only allowed tab when my alarm is in a certain state e.g. armed_away, but I only want to do this for a specific user (e.g. UserX, this is the name, not the username).
I can’t get it to work. I’ve gone through the documentation, but I’m probably not interpreting it correctly. This is what I have right now:
exceptions:
  - conditions:
      user_agent: Mobile
    config:
      menu: show
      options: show
  # user specific configuration.
  - conditions:
      user: UserX
    config:
      default_tab: lights
      hide_tabs: tab_x,tab_y
      hide_unused: true
      disable_sidebar: true
    conditional_styles:
      - entity: alarm_control_panel.alarm
        condition:
          state: armed_away
        tab:
          lights:
            hide: true
          tab_x:
            hide: true
          tab_y:
            hide: true
          tab_z:
            hide: true
What am I doing wrong? Also… is there maybe a better way to accomplish this?
The exception’s conditional_styles should be indented to be part of UserX’s config:
  - conditions:
      user: UserX
    config:
      default_tab: lights
      hide_unused: true
      conditional_styles:
          condition:
            state: armed_away
          - tab:
              lights:
                hide: true
          - tab:
              tab_x:
                hide: true
          - tab:
              tab_y:
                hide: true
          - tab:
              tab_z:
                hide: true
Not yet.
Thanks for putting me into the right direction. I indeed had to place conditional_styles under config, but it didn’t work with all of the tabs under tab like that.
I actually had to define it like this:
  - conditions:
      user: UserX
    config:
      default_tab: lights
      hide_unused: true
      conditional_styles:
        template:
          - tab:
              lights:
                display: >
                  if (states['alarm_control_panel.alarm'].state == 'armed_home') 'hide';
                  else if (states['alarm_control_panel.alarm'].state == 'armed_away') 'hide';
                  else if (states['alarm_control_panel.alarm'].state == 'armed_night') 'hide';
                  else 'show';
          - tab:
              tab_x:
                display: >
                  else 'show';
          - tab:
Which is a lot of code when you basically want to hide all of the tabs except for the e.g. alarm tab (in this case).
Is there maybe a way to use hide_tabs in combination with conditions?
My goal is basically to only show the alarm tab when the alarm is armed in any way.
That was my bad, missed that on the copy paste. Editing post to fix.
Though, if you want to use javascript templates here’s a different way to go about that:
    template:
      - tab:
          lights:
            display: "return states['alarm_control_panel.alarm'].state.includes('armed') ? 'hide' : 'show' "
      - tab:
          tab_x:
Conditionals can for sure use some improvements, but they currently fit under the “working” category so aren’t high on the priority list. They will get some love when I get the time.
Thanks! That works perfectly with a lot less code. Didn’t think of using it like that at all.
I can totally understand that. At least it is working now with the least amount of code.
I might even try to put the repeating code into a separate template file, so I can reuse it. Not sure whether it will work, but I’ll try in a bit and if it doesn’t I’ll just use this.
In it’s current form it won’t work like that, but that is one of the first thing’s I’ll be adding to conditional templates: a way to create variables that can be accessed by all templates. A close second on the list would be allowing tab lists or groups in conditionals/templates.
You could cheat it a bit now by using global variables, but it would be much better to add something like that to config.
Awesome, sounds like a great improvement!
Edit:
For anyone wanting to do the same I’m doing, I changed the armed in the following:
to armed_ to not include the disarmed state.
Tried out this on my Kindle, found I needed CCH for older devices & unsupported browsers. · Issue #185 · maykar/compact-custom-header · GitHub
It doesn’t appear to hide the header, and the config bar seems to be missing. I made sure type: js, what else am I missing? I see that on my browser debug has the warning:
compact-custom-header.js?v=0.0.3:1 Uncaught SyntaxError: Identifier ‘LitElement’ has already been declared
at compact-custom-header.js?v=0.0.3:1
What does your resources section look like?
Edit: Updated the legacy version. Give it a shot. Also, make sure you don’t have CCH twice in your resources.
is there a way to configure background to a specific tab only? let say for tab 2 and not for all tabs.
    - conditions:
        user: test
        # user_agent: Mobile
        # media_query: "(max-width: 600px)"
      config:
        default_tab: 2
        # options: clock
        # clock_format: 24
        # hide_tabs: 0,1,2,3,4,5,6,7,8,9
        background: center / cover no-repeat url("/local/back2header.png") fixed
Thank you!
No, there are no per view/tab exceptions.
Pre-Release 1.4.3
  • Update editor to fix toggles for HA 0.100 +
  • Sync clock to system clock.
After updating to 1.4.3, the sidebar and menu don’t show on mobile unless I remove the exception I have for mobile. Here is the config of the mobile exception:
- conditions:
        user_agent: Mobile
      config:
        default_tab: []
        hide_tabs: 'Kiosk,Calendar,media-players,Github,Test'
        menu: show
        notifications: show
        options: show
        show_tabs: []
        voice: overflow
        compact_header: true
It also shows all tabs and doesn’t hide the tabs listed in hide_tabs.
Is there something wrong with my config? This was working previously.
Edit: My Home Assistant version is 0.99.3
Should be fixed in the latest pre-release. I had changed the structure of CCH a bit which is why this round of updates are still in pre-release. I have a fair few different configs that I cycle through for testing, but they don’t always catch some issues. Thanks!
Just updated to 1.4.5 and it’s working on mobile now, thanks. :+1:
Hi!
Thanks for an awsome component.
however, i have found an issue. the hide tab / show tab feature dosent work on my rpi running chromium web browser. is this known? is there a way around it?
BR Mathias
What does your config look like? Any errors in HA or in your browser’s dev tools?
Hi!
in HA log i found this:
https://XXXX.XXX/community_plugin/compact-custom-header/compact-custom-header.js:1302:17 Uncaught TypeError: ranges.flat is not a function
Anslutning tappad. Ansluter igen...
and my config looks like this:
cch:
  options: clock
  voice: hide
  clock_format: 24
  clock_date: true
  exceptions:
    - conditions:
        user: XXX
      config:
        swipe: true
        swipe_animate: swipe
        default_tab: '0'
        sidebar_closed: true
        hide_help: true
        hide_config: true
        hide_unused: true
        hide_tabs: '9,10,13'
    - conditions:
        user: XXX
      config:
        swipe: true
        default_tab: '13'
        hide_help: true
        hide_config: true
        kiosk_mode: true
    - conditions:
        user: XXX
      config:
        default_tab: '0'
        hide_help: true
        hide_config: true
        hide_unused: true
        redirect: true
        options: hide
        hide_tabs: '8,9,10,11,12,13'
it works perfectly on Chrome ( MAC) Android phone, and IOS APP.
also noticed that the clock dosent work on the Chromium either.
BR Mathias
You must be using an older version of Chromium. Either update to the latest or, if that’s not possible, use the legacy version of CCH found here: CCH for older devices & unsupported browsers
Thank you! Updated chromium and now it works.
I see that the clock is still missing, also an compability issue I assume.
Br Mathias
