I dunno, I just passed the file on.
I’ll have a look tonight what I messed up ;-p
Found it, it was a case of incorrect file encoding.
And fixed it, v1.6.1 should be as expected.
Super! Thanks! (Was afraid I did something wrong.)
Hi @tom_l
I was going through this post and saw the awesome theme. It looks like the dropbox link for the background is no longer available. Any way you could please repost this?
I no longer use it and have deleted it sorry.
Darn. Thanks for the quick reply.
I’m having trouble finding card background images. Curious if your using anything similar or can point me in a direction for this?
Google image search?
It’s off topic here, better if you start a new topic in the Configuration / Frontend category asking for suggestions.
I’m looking to put the state of a sensor in the header. Is that possible?
This should show when happened the last update. I can put it in whatever corner but I’m not able to do it.
header:
title:
value: '{{ states(''sensor.aktivo_last_measure'') }}'
icon:
show: false
Only if you use this:
No that is not possible by default.
However the post of @tom_l will help out to make it the way you’d like.
Thanks @tom_l, for the exellent suggestion, I did not know of this project.
Guys, thank you for the help. I’m just beginning in this kind of work and after many test, I found a tricky way to do it!
I put the sensor normally, activated the header just with a black dot and moved the result with the style command to the top!
type: custom:compass-card
style: |
.sensor-0 {
line-height: 12px;
.sensor-0 .measurement {
font-size: 12px !important;
.sensor-0 .value {
font-size: 18px !important;
.sensor-2 .value {
font-size: 13px !important;
position: absolute;
top: -105px;
left: -62px;
indicator_sensors:
- sensor: sensor.aktivo_wind_direction
indicator:
type: arrow_inward
value_sensors:
- sensor: sensor.aktivo_wind_gust
state_value:
color: red
- sensor: sensor.aktivo_wind_speed
- sensor: sensor.aktivo_last_measure
compass:
east:
show: true
west:
show: true
south:
show: true
north:
show: true
color: red
header:
title:
value: .
color: black
icon:
show: false
I didn’t find how to use the templatable lovelace card
Well thought of solution!
But I guess you do need card-mod for that, or is the style key a Home Assistant native function?
Great card!
I tried to adjust the offset based on a sensor value, but it seems to not accept it. Am I doing something wrong, or is it simply not possible to have a “dynamic” offset?
The dynamic offset is in the workings, however due to unforseen personal circumstances it will take some time for me to address this feature.
Hi. I have a wind sensor from swedish Sjöfartsverket ViVa HACS integration. It presents the wind direction in swedish abbreviations like “NV”, not “NW”. How can I get correct wind direction in Compass card?
Thanks!
Unfortunately the written wind direction needs to be in English at the moment for the card to work properly.
You can open a feature request issue at the GitHub page for me to try to add it in a future release.
I see, thanks. I for sure can do that.
you can probably create a sensor template to match each non english abbreviations with the english ones
I’ve installed Compass in my Home Assistant dashboard, but for some reason setting the language to Dutch doesn’t work:
To my understanding ‘E’ should be ‘O’ for ‘oost’ in Dutch, but still the ‘E’ for ‘east’ is showing. Am I doing something wrong? This is my configuration:
indicator_sensors:
- sensor: sensor.windrichting_graden
indicator:
type: arrow_inward
value_sensors:
- sensor: sensor.windsnelheid
compass:
language: nl
