Compass Card - Points you in the right direction 🧭
Ha! Yeah that will certainly keep you busy. Hope you both have a great day.
What setting causes those notches to be created inside the circle? Thanks
Look at the URL in that image. It is the ecowit app/webpage. Not the compass card.
Old post I know.
But I have the same problem as kongjudas, dont know if you got the card config from her/him, and had a look at it. If you didn’t , I can send you mine. (I have not used card mod.)
Hi, yes please send yours.
Or if you could add your config to this issue on github that would be even better: Resize the circle to fit the same square like the neighbour cards · Issue #170 · tomvanswam/compass-card · GitHub
I’m still thinking of a way to implement this, but a config example would help.
Hi, I would like to ask you for help with adding a Compass card. Unfortunately, I can’t do it.
I enclose the screens of my settings.
At first sight, I cant see anything wrong in you config.
Did you reload the page after adding the resource? You can do this by pressing ctrl+r.
Unfortunately I’m niet close to a computer, so I’m not able to reproduce IT before somewhere mid next week.
Thank you for the quick response. I did a reload over F5 and it didn’t work.
Now everything is working fine. I am a beginner.
Thank you for a great wind direction card.
I would like to ask one more question.
Is it possible to set the text 2. to have the same size and font as the text 1.? See attached screen.
I would like to use the basic size and font of the text, which I use for all other tabs also directly in the tab to display the wind direction.
Now I would have to solve it so that there will be text 1. But that does not look very nice.
As described in this post the card is styled similar to the sensor-card. As the sensor card has a different title styling to entity cards you get the result you descibe.
A possible workaround would be to use card-mod to change the title styling to your liking.
Dear Tom your Dashboard looks amazing and I am a newbie it is possible to share your Dashboard settings and Theme?
Thanks Matthias
No, I no longer use that theme.
Installed your card and I liked it. Thanks. How can I add swedish to the set of languages?
Also, not quite sure aboy how to change size of compass?
The translations are here compass-card/src/localize/languages at master · tomvanswam/compass-card · GitHub - you will see that there is a .json file for each language. If you know github, make one for Swedish and post a pull request. If you don’t know github, good time to learn.
If learning github is not your thing, then I am sure there will be a way to submit the file, but you’ll need to negotiate that with @tomvanswam. Or you could get the file to me and I’ll do a pull request.
Ok, I’ll try to see what I can do. Thanks!
Edit. Too much I didn’t understand. Have enough to learn in HA right now so I’d like you to make the pull, please.
How do I send the file?
Email it to me, I’ll pm my email.
Your language file has been merged, but I guess @tomvanswam will have to release a new version to get it.
Thanks for the PR!
Ik do need to make an updated version. Will do that later this week.
I think HACS makes it possible to download the master branch (if you choose the HACS option to allow betas) but I hesitate to recommend that, not knowing what you might be part through developing.
I made the translation to Swedish, but when I set “se” as language I now get a square with a questionmark instead of the swedish letters. What have I done wrong?
