Compatibiity zigbee home automation profile
Hi, I have a legacy home automation system with Zigbee devices that are compatible wtih home automation profile. I knowe the Zigbee radios are DIGI. How can I test or verify if they are compatible with HA?
Thank you,
Take a look here.
Zigbee Device Compatibility Repository is only a rough starting guideline but not a bible for ZHA. Read:
https://www.home-assistant.io/integrations/zha#knowing-which-devices-are-supported
More importantly, when not all entities/attributes are seen read this which explains why and how to fix:
https://www.home-assistant.io/integrations/zha#zha-exception-and-deviation-handling
At this time the only real way to know if a device is fully compatible with ZHA is to test it. If not report to:
https://github.com/zigpy/zha-device-handlers/issues
