Compatible (smart) watches
Hi there,
I want to buy a sports watch or a smartwatch. I prefer a sports watch for battery life.
Is there a list of compatible HA watches somewhere or are there general watch selection criteria for HA?
Depends on what you mean, and what you want. The Apple Watch and WearOS have support from the iOS and Android apps.
There are also options for various fitness trackers, though that’s usually for reporting stats to HA.
I don’t use Apple devices, so i need to look for wearables with " Wear OS "?
What exactly did you mean by being compatible with HA?
I have a Garmin Venu 2 with 7 to 10 days of battery life and there is a Garmin Connect HACS integration which allows the metrics from the watch that is synced with Garmin Connect to be available in HA.
There is also a HASS Control app that can be loaded on the Garmin watches to view and control HA entities.
Just ordered the Xiaomi Redmi Watch 4 so will see how compatible and reliable it is with Hassio.
what did you find?
yep just wondering is redmi watches are compatible with HA or not
I have bought a Xiaomi Watch 2 (not pro) and it works great with HA, it is wearOS. Battery life of about 3 days.
I have the Xiaomi Watch 4 and it uses HyperOS which is not compatible from what I’ve gathered so far.
Hey there! I was thinking of buying a Redmi Watch 4 as well. Do you confirm that it is not compatible with anything Home Assistant at the moment? There’s obviously 2 main things I’d like to know whether they work or not:
  • Able to add some buttons (only a few, but some lights / climate toggles would be a great start)
  • Able to ideally send back health data to HA (I assume this could prove more complicated, but being able to have sensors for steps and heart rate in HA from the watch would be great).
Did you check this thread? Affordable Smart Wearable meets Home Assistant
I have a Amazfit Watch. I donĀ“t use the factory ZEPP app but ā€œNotify for Amazfitā€ app, which offers a Home Assistant integration, but didnĀ“t yet play around with it. ItĀ“s supposed to have buttons to control simple things in HA.
Hi RoadkillUK,
I’ve bought the Xiaomi Watch 2 for my son, but can’t find anything to help me to connect it : do you have any tutorial or tips ?
I’m not sure what you mean, you will have to install the Companion App on his phone and I believe you will also need the Mi Fitness App for access to the watch.
I think that should do, if not … er I’ll have to think again :slight_smile:
There’s no single list for all HA-compatible watches, but generally look for watches that support the same apps or protocols your HA setup uses. Came across some solid tech guides on https://planet-positive.org/ that helped clarify which brands tend to play nicer with smart home gear. If battery life is king for you, a sports watch with basic smart features might be the perfect balance without constant charging.
Are There any recommodations for useable Fitness tracker Bands Like xiaomi band 10?
I’m looking for a fitness band/watch compatible with HA, too.
It seems that there are no ā€˜native’ compatible devices, but few have HACS or integration to bridge something between the two.
I’m kinda disappointed at the moment, to be honest.
