Compile Error - ESPHome on Windows
I installed ESPHome on a Windows 11 PC. The install went reasonably well. I’m able to edit, compile and install most code copied from an Home Assistant Blue computer. I have however run into problems with two files. Both throw errors during the compile process. I thought using the clean files command would solve the problem. Not! The same errors appear when running that command.
Here are the results from one of the files;
INFO ESPHome 2024.8.0
INFO Reading configuration C:\Users\rcbla\OneDrive\Home_Assistant\ESPHome\Config\esp32-s3box-3.yaml...
INFO Updating https://github.com/gnumpi/esphome_audio@dev-next
INFO Detected timezone 'America/New_York'
ERROR Unexpected exception while reading configuration:
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Scripts\esphome.exe\__main__.py", line 7, in <module>
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\__main__.py", line 1014, in main
    return run_esphome(sys.argv)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\__main__.py", line 992, in run_esphome
    config = read_config(dict(args.substitution) if args.substitution else {})
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\config.py", line 1091, in read_config
    res = load_config(command_line_substitutions)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\config.py", line 945, in load_config
    return _load_config(command_line_substitutions)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\config.py", line 935, in _load_config
    return validate_config(config, command_line_substitutions)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\config.py", line 859, in validate_config
    result.run_validation_steps()
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\config.py", line 142, in run_validation_steps
    task.step.run(self)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\config.py", line 562, in run
    validated = schema(self.conf)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\voluptuous_schema.py", line 35, in __call__
    res = super().__call__(data)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\voluptuous\schema_builder.py", line 281, in __call__
    return self._compiled([], data)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\voluptuous\validators.py", line 251, in _run
    return self._exec(self._compiled, value, path)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\voluptuous\validators.py", line 379, in _exec
    v = func(path, v)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\voluptuous\schema_builder.py", line 855, in validate_callable
    return schema(data)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\voluptuous\schema_builder.py", line 625, in validate_dict
    return base_validate(path, data.items(), out)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\voluptuous_schema.py", line 149, in validate_mapping
    cval = cvalue(key_path, value)
    v = func(path, v)
    return schema(data)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\components\font\__init__.py", line 308, in _file_schema
    return validate_file_shorthand(value)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\components\font\__init__.py", line 273, in validate_file_shorthand
    return FILE_SCHEMA(
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\voluptuous\validators.py", line 254, in __call__
    return self._exec((Schema(val) for val in self.validators), v)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\voluptuous\validators.py", line 377, in _exec
    v = func(v)
    return schema(data)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\components\font\__init__.py", line 309, in _file_schema
    return TYPED_FILE_SCHEMA(value)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\config_validation.py", line 1621, in validator
    value = Schema(schemas[key_v])(value)
    v = func(path, v)
    return schema(data)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\components\font\__init__.py", line 221, in download_web_font
    external_files.download_content(url, path)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\external_files.py", line 105, in download_content
    path.write_bytes(req.content)
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\pathlib.py", line 1036, in write_bytes
    with self.open(mode='wb') as f:
  File "C:\Users\rcbla\AppData\Local\Programs\Python\Python312\Lib\pathlib.py", line 1013, in open
    return io.open(self, mode, buffering, encoding, errors, newline)
OSError: [Errno 22] Invalid argument: 'C:\\Users\\rcbla\\OneDrive\\Home_Assistant\\ESPHome\\Config\\.esphome\\font\\c9ee33c7\\font.ttf'
Try as I may, I’m not able to decipher what this message is telling me.
The other device is the RATGDO. Here are the results from that file;
INFO Reading configuration C:\Users\rcbla\OneDrive\Home_Assistant\ESPHome\Config\garage-door-opener.yaml...
Failed config
packages: [source C:\Users\rcbla\OneDrive\Home_Assistant\ESPHome\Config\garage-door-opener.yaml:5]
  not a valid value.
  ratgdo.esphome: github://ratgdo/esphome-ratgdo/v25iboard.yaml@main
Both files were copied from the HA Blue pc. Both compile without a problem on that computer.
Any insight you can offer would be appreciated.
