Please use https://www.jetbrains.com/lp/compose-multiplatform/ for UI, it will be native UI speed on iOS and Android. WebKit render will not be used on mobile. It will be drawn using shaders with openGl and Vulcan api. In will allow to use super beautiful animations with 60 frames for second. Same code will work also on web. Also, it is written on super language. To speed up ui
You already have a closed FR for the same thing. Please, convert code for mobile App into Kotlin language
No, topic now about UI, it is two different technology Jetbrains Compose and Kotlin multiplatform
Just implement it if it that easy.
If you will use mvi MVI Architecture with Android. The application lifespan is tied to its… | by Rim Gazzah | The Startup | Medium you can use different technology for UI (presentation in clean architecture)
With the same url.
It’s not even ready for consideration; IOS is at alpha quality and web is still experimental…
also, it uses a material design, which by the way came from Android
ok, I will write to my friends from Jetbrains to speed up so that the best automation system is on this technology
To use official compiled technology from iOS and Android we need official permission from iOS and Android, or we can use permission from Jetbrains?
You don’t need permission from anyone, but to get your app in the store, it needs to be approved by Apple or Google.
App for Huawei?
It is allowed to run Android app on any Huawei, it is compatible for Android applications
