Ok, I just tried a test where I start with 2.8.4 with a config similar to yours. Then I upgraded to 3.0.0b1, restarted, and it worked fine. Here is the warning about unsupported options that is issued after the restart:
This error originated from a custom integration.
Logger: custom_components.composite
Source: custom_components/composite/__init__.py:111
Integration: Composite (documentation, issues)
First occurred: 11:13:24 AM (1 occurrences)
Last logged: 11:13:24 AM
Your composite configuration contains options that are no longer supported: time_as; Please remove them
So, not sure why you’re having a problem.
So, this integration is not moving from YAML to UI; it’s adding UI. You can continue to use YAML, or you can remove YAML and use UI, or you can do both.
removing those from yaml, and restarting, took them out of the integrations panel, where Composite now no longer was shown (which was expected, as I took them out…)
Ive rebuild them all using the UI now, however there is this result:
Hmm, I thought that removing a config entry would also remove all associated entities. But now that I think about it more, and given your experience, that probably isn’t the case. I think there is a function I need to call to “clear” the entity registry of an entities related to a config.
I’ll probably be releasing another beta soon. Thanks for being my guinea pig!
EDIT:
I reproduced what you experienced.
Well, I rechecked the code and removing a config entry does clear out associated entries in the entity registry, so this shouldn’t be happening. BUT…
It’s possible there is a race condition between removing the config and the (previously existing) config getting set up. This is probably a side effect of one of my recent changes to keep setup from delaying startup. I think I know how to fix this. Stay tuned (although this probably doesn’t matter to you anymore.)
I had added the restored attribute if the state was restored after restart. However, this is used for other purposes and has an undesired side effect when used in this situation. Therefore, do not add that attribute anymore.
I’m also planning to fully release (as 3.0.0) soon. If anyone is having any issues with the beta releases, please let me know ASAP so I can fix any problems before releasing 3.0.0. Thanks!
Well, this is the second time today I noticed I got bit by using features in the dev branch of HA Core that are so new they are not in any release. Argh!
This time (with this integration) it causes the speed sensors (only for UI based configs) to be wrong. There’s a new translation feature I used, and without it, the names come out goofy.
In the interim, if you care, use the Settings (gear) page for the entities to change their names and entity IDs.
I’ll have to consider what to do about this. One choice is to make the minimum HA version 2024.2 (so it will work when that comes out.) Or I could try for a workaround to support older HA versions. Hmm…
It’s only the name (and, hence, entity ID) of the speed sensor, and only for UI created configuration entries. The fix only works when you create new entries from the UI. Existing UI created speed sensors can have their names and entity IDs changed the normal way.
I haven’t done enough testing yet to know exactly what HA version is needed.
I don’t remember if this has been asked (or answered) but is it a possibility to add a new state to the composite tracker that indicates “driving” similar to what the Life360 integration had?
I don’t recall anyone asking for that feature in the composite integration. But it would be very easy to add. Please add an issue to that repo and label it “enhancement.”
