Composite Device Tracker Platform
Click the link above
to get the custom integration.
Continuing the discussion from Composite GPS-based Device Tracker?:
Ok, well there wasn't much discussion, but... ![]()
As I understand it, if you have a GPS-based device tracker and one or more network-based device trackers for a given person, they can be combined by simply editing known_devices.yaml. However, what do you do if you have more than one GPS-based device tracker per person? I couldn't find anything that would combine them (although I'll admit I didn't look too hard. If something already exists for this situation, please let me know!)
"But why would you have more than one GPS-based device tracker per person", you ask?
Well in my case I've been using Life360 to provide presence detection for a few family members, and it's worked pretty well. I also started using Google Maps Location Sharing for family members that weren't using Life360. I immediately realized that for some people I could use either ... or both!
Then, as chance would have it, one of the people whose device location was being obtained via Life360 (but could be obtained via either method) put their phone into a power saving mode, which caused Life360 updates to become irregular. No matter what I changed in the phone's settings to let Life360 run whenever it wants, nothing seemed to help. So I tried changing that user over to Google location sharing. But I discovered that it was inconsistent, too, on this phone.
After further monitoring with both enabled, I noticed that although they were both inconsistent, they weren't inconsistent at the same time. To put that another way, when one would seem to drop out for a while, the other seemed to be updating fine, and vice versa. Weird, because they're both running on the same phone, using the same GPS service. ![]()
It occurred to me, I could use an automation that triggered on either entity (Life360 or Google Maps) updating, and use that to create a "composite" device_tracker entity using the device_tracker.see service. And it worked, and worked well!! The biggest downside was now my logs were clogged with this automation triggering all the time.
So, I decided to create a new Device Tracker platform that would do the same thing as the automation. And so far it's working pretty well.
If anyone has a similar scenario and would like to try this out, by all means, follow the link at the top of the page ... and don't forget to let me know how it works for you, if you can think of any improvements, or if run into any problems using it.
) but I’ll definitely try to look at this as soon as I can.
