" I have my Conbee running, integrated with no issue at all. I put in the port and chose deconz for the protocol on the integrations page. Be sure you have the latest firmware by looking in Phoscon. Also Phoscon may not be presenting the most current version available to flash. I am running firmware 0x26300500 and itâs been fine but had to flash manually.
Download firmware at https://www.dresden-elektronik.de/rpi/deconz-firmware/deCONZ_Rpi_0x26230500.bin.GCF and flash it with GCFFlasher -d 0 -f deCONZ_Rpi_0x26300500.bin.GCF command. You can run GCFFlasher -l to see what devices are available for -d option. The Bootloader Flash Tool is here https://www.dresden-elektronik.de/funktechnik/service/download/driver/?L=1
My experience to date which is minimal is my Samsung Motion Sensors did not work in deCONZ but work with the native integration and my Cree Bulbs which did work now do not. There have been some updates and I have not tried the Cree again yet I have them connected to my OSRAM Hub. I have found no device support list for the native ZHA so itâs all a try and see at this time.
Shouldnât make a difference but probably should have addedâŚ
Using Intel NUC, Ubuntu 18.04, Docker and HA 0.88.2
Another edit⌠should have added I did the flashing on my Windows PC."
Iâm not sure what the rpi means but you can and should flash 26300500 that I linked to using the proper Bootloader Flashtool. I have not done it in Linux but the instructions for Windows were spot on so I assume the Linux ones are as well.
You can also get help right from the manufacturer if you need it.
The issues I was having were due to not having the most current firmware so unless you upgrade your firmware your issues may never go away and as the code matures may get worse and you end up with a small expensive paperweight. Worse yet if you donât upgrade you may not get support as the first thing you will usually hear from support is âUpgrade Your Firmwareâ. I know it can be intimidating but you need to conquer your fear I just posted a link to the manufacturerâs GitHub I am sure someone can assist you in how to perform the flash. I am far from any command prompt guru and did it with no issue at all, and I too was somewhat intimidated at first.
Actually I am really not in hurry. My main ZHA is running very well with Elelabs Zigbee Shield. I have few test RPIs running on side - one is having this RaspBee for a test.
I just bet one day Conbee and Raspbee will be a great choice for ZHA. I just quickly tested ZHA with my RaspBee but returned back to Deconz addon after bad results with my test.
But Yes, you are absolutely right, I am also a lot intimidated. On the other hand I think I am doing OK as I am just learning to walk here with great support from this amazing community.
One more stupid question about this flashing. As I have a Raspbee running in Hass.IO/HassOS. I wonder is there a way to flash, I see flashing tool is meant to Rasbian - would it work on HassOS?
Maybe I really have to ask help from manufacturer âŚ
I have no experience with anything other than the way I flashed mine thatâs why I provided the link to the manufacturer. My understanding is they are very responsive. For me it was easier to install deCONZ on my Windows machine so I could see what version I had and then do the flashing from there.
FYI - I have been working on issues with Conbee using native ZHA Integration not deCONZ. They have me back on firmware 262F0500. If you are not having issues on HA version 0.91.0 and above I say leave well enough alone. If you are try using this firmware.
Yes for Conbee native ZHA the zigpy-deconz library is looking for that version on the original Conbee, that was what I was asked to used by the developers while we have been working on issues with Cree Connected bulbs which the Conbee just does not seem to like. But again if you have the later version and no issues donât fix what isnât broken IMHO. I only have my Samsung motion detectors running on it now but it has been flawless.
I will try that firmware and some later ones. I have some Ikea Tradfri devices that i hope will work with ZHA. I will post my results here as soon as i can.
