I’m trying to alter my current automation. I have created a toggle switch via Helper. Now when I set the switch to ‘on’, then this automation shouldn’t run. So I have set it to ‘Off’ so it will always run except when guest at home and I toggle the switch and the condition will be false and won’t run.
However, it’s executing every time. Any idea why ?
alias: Daikin 10pm Test
description: ''
- platform: time
at: '22:00:00'
condition:
- condition: state
entity_id: input_boolean.guest_switch
state: 'Off'
- service: climate.set_temperature
hvac_mode: heat
temperature: 21
entity_id: climate.daikin_ac
area_id: living_room
device_id: 7c0635af
mode: single
It’s ‘off’ while history log has ‘On’ and ‘Off’, that’s why I tried both. Thought this would be straightforward thing before I apply complex conditions:(
I think, the option in automation screen is test or Run ‘Action’ I need to test automation as a whole. This seems to be by passing the condition, is it ?, How to test the automation as a whole ?
“Please note that if you click on Trigger of an automation in the frontend, only the action will run”
I think that was the issue
Automation.trigger under services and opt for don’t skip trigger
