Conditions for switch automation
I’m having trouble with an automation with a wake-on-lan switch for a tv.
The switch is set up and working, turns on with WOL and turns off with an IR remote command. The switch also knows what the current state of the TV is (on or off).
I’m trying to set up an automation for a zigbee button that turns off the TV. But I only want the automation to run if the TV is on, as the IR remote command also turns the TV on. So if the TV is off, then the automation should not run.
This is my code:
alias: Sonoff hold press - turn off tv
description: ''
  - platform: event
    event_type: zha_event
    event_data:
      device_ieee: '00:12:4b:00:22:42:28:6c'
      command: 'off'
condition:
  - condition: state
    entity_id: switch.panasonic_tv
    state: 'on'
  - service: homeassistant.turn_off
    data: {}
mode: single
It doesn’t seem to work as expected though, if the tv is ‘off’ (and the switch in home assistant also says it’s off) and I trigger the automation, it still sends the IR command to turn off the TV, which just ends up turning it on…
I’m sure it’s something simple, but can’t figure it out
If you trigger the automation from the interface it ignores the conditions. To test an automation, use the actual trigger.
Ergh I feel stupid, thanks
For testing you can use the developer tools / services UI to trigger automations and it has a skip_conditions option you can set to false.
