Conditional Styling and Display Logic of card elements in GUI without yaml
I am kind of fed up with all the hassle I have to do when trying to change card elements on several conditions.Think of icon-color, the icon itself, the background-color etc.
Seeing lots of questions of other users how to do this makes me think I cannot be the only one :smiley: .
Now I have to go into yaml and do some coding. Wouldn’t is be nicer to achieve all this from GUI?
This is what I had in mind:
This feature allows users to define conditional styling and display logic directly from the Home Assistant GUI, eliminating the need for manual YAML coding, card-mods etc. It provides an intuitive interface to customize entity card appearance based on entity states or other entity conditions.
Steps to Configure Conditional Styling:
  1. Define the Condition:
    • Condition Type:
      • Entity State / attribute: The state/attribute of the current entity in the card.
      • Other Entity State / attribute: The state/attribute of a different entity in Home Assistant.
    • Comparison Options:
      • Range: Define a range of states or values (e.g., 20-30 for temperature). HA may look in history for unique values an use it if.
      • Absolute Value: Define specific values (e.g., on, off, cooling, number).
    • Input Values:
      • For range: Specify a minimum and maximum value.
      • For absolute value: Specify one or more discrete values.
  2. Let the user add one or more Display Elements to be styled:
    • Elements to Customize:
      • Icon: Change the displayed icon dynamically.
      • Icon Color: Define the color of the icon for specific conditions.
      • Background Color: Adjust the background color of the card based on the condition.
      • Text Style (optional): Modify the text color, font weight, or size for specific states.
  3. Mapping in the background:
    • Condition Example:
      • If temperature > 30:
        • Icon: mdi:thermometer-high
        • Icon Color: red
        • Background Color: #FFE5E5
      • If state = “on”:
        • Icon: mdi:power
        • Icon Color: green
        • Background Color: #E5FFEA
  4. Preview and Apply:
    • Real-Time Preview: Show a live preview of the entity card as conditions and styles are applied.
    • Save Configuration: Apply changes without editing YAML files.
Use Cases:
  1. Dynamic Temperature Indicator:
    • When the temperature is within a safe range, display a green icon with a neutral background.
    • If the temperature exceeds a threshold, display a red icon with a warning background.
  2. Power Status Indicator:
    • Show a green icon when the power is “on” and a gray icon when “off.”
    • Add a blue background when the device is in “standby.”
  3. Lighting Control:
    • Change the icon and color based on brightness level or on/off state.
This system offers a powerful, user-friendly way to customize Home Assistant cards, making the interface more accessible and visually dynamic without requiring coding expertise.
