draft
1
Hi - I have Home Assistant working properly on a Mac Mini (Apple Silicon / M1) via UTM using this guide:
I’m adding services and got to Channels:
However, I can’t find the config directory? Where can I find the config directory for the VM running in UTM? Thanks!
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
2
Hi draft,
It could also be called /homeassistant. There was a change a while back.
draft
3
I’m not finding that either? Is there a location on disk where the filesystem for the UTM VM lives?
Sir_Goodenough
4
The VM is an isolates thing on the drive. You get to it from within the VM software. You won’t find anything on the main harddrive.
