I’ve previously successfully set up my z-wave network using the built-in z-wave integration as well as zwave2mqtt. Now trying to integrate the new qt-open z-wave integration but not having a whole lot of luck.
Things I’ve tried:
- I’ve verified my MQTT integration is working via Developer Tools
- Disabled user/pw authentication on the default listener for the MQTT broker
- Numerous combinations of restarting hass, adding/removing the hacs integration, restarting the MQTT client
But I seem to get the same error:
[20200130 22:01:59.893 UTC] [ozw.library] [info]: Info - Node: 0 Queuing Lookup on mfs.db.openzwave.com for Node 0
[20200130 22:01:59.894 UTC] [ozw.library] [info]: Info - Node: 0 Opening controller /dev/ttyACM2
[20200130 22:01:59.894 UTC] [ozw.library] [info]: Info - Node: 0 Trying to open serial port /dev/ttyACM2 (attempt 1)
[20200130 22:01:59.894 UTC] [ozw.library] [info]: Info - Node: 0 Timer: thread starting
[20200130 22:01:59.894 UTC] [ozw.library] [debug]: Detail - Node: 0 Timer: waiting with timeout -1 ms
[20200130 22:01:59.894 UTC] [ozw.library] [info]: Info - Node: 0 Starting DNSThread
[20200130 22:01:59.894 UTC] [ozw.library] [info]: Info - Node: 0 mgr, Added driver for controller /dev/ttyACM2
[20200130 22:01:59.894 UTC] [ozw.manager] [debug]: AddDriver Completed
[20200130 22:01:59.894 UTC] [ozw.library] [info]: Info - Node: 0 Serial port /dev/ttyACM2 opened (attempt 1)
[20200130 22:01:59.894 UTC] [ozw.library] [info]: Info - Node: 0 LookupTxT Checking mfs.db.openzwave.com
[20200130 22:01:59.894 UTC] [qt.mqtt.connection] [debug]: void QMqttConnection::transportError(QAbstractSocket::SocketError) QAbstractSocket::HostNotFoundError
[20200130 22:01:59.894 UTC] [ozw.mqtt.publisher] [debug]: MQTT State Change 0
[20200130 22:01:59.894 UTC] [ozw.library] [debug]: Detail - Node: 255 Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
[20200130 22:01:59.894 UTC] [ozw.mqtt.publisher] [warning]: Exiting on Failure
Anything else I need to do?
Didn’t want to pollute the thread, but this one is most relevant:
