I apologize if this has been answered else where. I did search, so please feel free to link me if that is the case. Also, full disclosure, I’m a bit of a n00b. Or at least I feel like one because I’m stuck on step 2 of the beginner friendly guide.
I’ve installed the add-on “Configurator”. I “open web ui”, enter my credentials, and get the error “Policy Not Fulfilled”. I believe that I have things properly setup, but would appreciate a second opinion.
Just a guess as I don’t use it, but you have two false in there without quotes round them. Presuming this is JSON it isn’t valid without quotes round the keypairs iirc.
I might try playing with mine - but if you set the banlimit it’s not like it’s going to be easy to crack and of course use a strong password and non-obvious username.
ok that doesn’t work and I know why. Helps when you read the logs eh!
It’s trying to connect from my external IP address (same one that duckdns is pointing to) So it’s useless trying to specify local network if you’re connecting via ssl
tried changing allowed IP to duckdns and I get a message saying duckdns didn’t send any data.
If you want to use a specific IP address (and you’re not using SSL) you will find that 10.0.1.57/32 will work and you will only connect from that one IP address.
That is helpful - Like I said, it is trying to connect from 172.30.32.1 which (like me) is your duckdns address. If you try 172.30.32.1/32 it will work. So if you’re using SSL you’re screwed and must use 0.0.0.0/0
AND SET A BAN LIMIT AND USE A DIFFERENT STRONG USERNAME AND PASSWORD!!!
