Good morning everyone,
I have read several 3Ds but I haven’t been able to find a solution for my home automation.
I have a vimar system with the following gateway
How can I integrate all the controlled sockets and shutters on HA?
thank you very much everyone
Hi ettore,
i just read ur guide, but i’ have not a apple homekit.
there are other methode?
For italian
Ciao ettore,
avevo gia letto al tua guida ma non avendo prodotti apple non potrei configurare apple home kit, hai per caso altre soluzioni?
There is no need for Apple products.
You use that integration to connect the vimar gateway to HA.
You have to note down the code that you find where there is the QR code on the side of the gateway, on the box or inside the box on documents.
Add the integration to HA.
Put the gateway in the same network of HA
It should show as new device
If it does not you should be able to add it manually.
Hope it helps.
