Hi, thanks you guys for sharing your achievements. I was able to successfully connect my wpc 05 to the home assistant. A Wemos d1 mini, MCP2515 CAN bus module from AZ Delivery and ESPHome are used. On the configurations already published here, only the source temperature (is this the correct translation for Quellentemperatur address had to be adjusted.
Here is my config
captive_portal:
globals:
- id: el_aufnahmeleistung_ww_tag_wh_float
type: float
restore_value: yes
- id: el_aufnahmeleistung_ww_tag_wh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_ww_tag_kwh
type: float
restore_value: yes
- id: el_aufnahmeleistung_ww_tag_kwh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_heiz_tag_wh_float
type: float
restore_value: yes
- id: el_aufnahmeleistung_heiz_tag_wh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_heiz_tag_kwh
type: float
restore_value: yes
- id: el_aufnahmeleistung_heiz_tag_kwh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_ww_total_kWh_float
type: float
restore_value: yes
- id: el_aufnahmeleistung_ww_total_kWh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_ww_total_mWh
type: float
restore_value: yes
- id: el_aufnahmeleistung_ww_total_mWh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_heiz_total_kWh_float
type: float
restore_value: yes
- id: el_aufnahmeleistung_heiz_total_kWh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_heiz_total_mWh
type: float
restore_value: yes
- id: el_aufnahmeleistung_heiz_total_mWh_flag
type: bool
restore_value: yes
- id: waermemertrag_ww_tag_wh_float
type: float
restore_value: yes
- id: waermemertrag_ww_tag_wh_flag
type: bool
restore_value: yes
- id: waermemertrag_ww_tag_kwh
type: float
restore_value: yes
- id: waermemertrag_ww_tag_kwh_flag
type: bool
- id: waermemertrag_electr_ww_tag_wh_float
type: float
restore_value: yes
- id: waermemertrag_electr_ww_tag_wh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_ww_tag_kwh
type: float
restore_value: yes
- id: waermemertrag_electr_ww_tag_kwh_flag
type: bool
restore_value: yes
- id: waermemertrag_heiz_tag_wh_float
type: float
restore_value: yes
- id: waermemertrag_heiz_tag_wh_flag
type: bool
restore_value: yes
- id: waermemertrag_heiz_tag_kwh
type: float
restore_value: yes
- id: waermemertrag_heiz_tag_kwh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_heiz_tag_wh_float
type: float
restore_value: yes
- id: waermemertrag_electr_heiz_tag_wh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_heiz_tag_kwh
type: float
restore_value: yes
- id: waermemertrag_electr_heiz_tag_kwh_flag
type: bool
restore_value: yes
- id: waermemertrag_ww_total_kWh_float
type: float
restore_value: yes
- id: waermemertrag_ww_total_kWh_flag
type: bool
restore_value: yes
- id: waermemertrag_ww_total_mWh
type: float
restore_value: yes
- id: waermemertrag_ww_total_mWh_flag
type: bool
restore_value: yes
- id: waermemertrag_heiz_total_kWh_float
type: float
restore_value: yes
- id: waermemertrag_heiz_total_kWh_flag
type: bool
restore_value: yes
- id: waermemertrag_heiz_total_mWh
type: float
restore_value: yes
- id: waermemertrag_heiz_total_mWh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_heiz_total_kWh_float
type: float
restore_value: yes
- id: waermemertrag_electr_heiz_total_kWh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_heiz_total_mWh
type: float
restore_value: yes
- id: waermemertrag_electr_heiz_total_mWh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_ww_total_kWh_float
type: float
restore_value: yes
- id: waermemertrag_electr_ww_total_kWh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_ww_total_mWh
type: float
restore_value: yes
- id: waermemertrag_electr_ww_total_mWh_flag
type: bool
restore_value: yes
unit_of_measurement: "°C"
icon: "mdi:thermometer-lines"
device_class: "temperature"
state_class: "measurement"
accuracy_decimals: 1
icon: "mdi:waves-arrow-right"
icon: "mdi:waves-arrow-left"
name: "Stromverbrauch Warmwasser heute"
unit_of_measurement: "kWh"
device_class: "energy"
accuracy_decimals: 3
icon: "mdi:transmission-tower"
name: "Stromverbrauch Heizung heute"
name: "Stromverbrauch Warmwasser total"
unit_of_measurement: "MWh"
state_class: "total_increasing"
name: "Stromverbrauch Heizung total"
name: "WM Heizung heute"
icon: "mdi:water-boiler"
name: "WM Heizen total"
name: "WM Warmwasser heute"
name: "WM Warmwasser total"
name: "WM elektr. Warmwasser total"
name: "WM elektr. heizen total"
binary_sensor:
time:
- platform: homeassistant
on_time:
- seconds: /180
then:
#WM NE WW Summe wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x22,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE WW Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x23,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE Heizen Summe wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x26,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE Heizen Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x27,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Tag wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2a,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Tag kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2b,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2c,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Summe Mwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2d,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Tag wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2e,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Tag kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2f,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x30,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Summe Mwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x31,0x00,0x00 ]
can_id: 0x680
- delay: 10s
- lambda: |-
if (id(waermemertrag_electr_ww_total_mWh_flag) and id(waermemertrag_electr_ww_total_kWh_flag)){
id(waermemertrag_electr_ww_total_mWh) += id(waermemertrag_electr_ww_total_kWh_float);
id(total_electric_heating_energy_water).publish_state(id(waermemertrag_electr_ww_total_mWh));
id(waermemertrag_electr_ww_total_mWh_flag)=false;
id(waermemertrag_electr_ww_total_kWh_flag)=false;
- lambda: |-
if (id(waermemertrag_electr_heiz_total_kWh_flag) and id(waermemertrag_electr_heiz_total_mWh_flag)){
id(waermemertrag_electr_heiz_total_mWh) += id(waermemertrag_electr_heiz_total_kWh_float);
id(total_electric_heating_energy).publish_state(id(waermemertrag_electr_heiz_total_mWh));
id(waermemertrag_electr_heiz_total_kWh_flag)=false;
id(waermemertrag_electr_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(waermemertrag_ww_total_mWh_flag) and id(waermemertrag_ww_total_kWh_flag)){
id(waermemertrag_ww_total_mWh) += id(waermemertrag_ww_total_kWh_float);
id(total_heating_energy_water).publish_state(id(waermemertrag_ww_total_mWh));
id(waermemertrag_ww_total_mWh_flag)=false;
id(waermemertrag_ww_total_kWh_flag)=false;
- lambda: |-
if (id(waermemertrag_heiz_total_kWh_flag) and id(waermemertrag_heiz_total_mWh_flag)){
id(waermemertrag_heiz_total_mWh) += id(waermemertrag_heiz_total_kWh_float);
id(total_heating_energy).publish_state(id(waermemertrag_heiz_total_mWh));
id(waermemertrag_heiz_total_kWh_flag)=false;
id(waermemertrag_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(waermemertrag_heiz_tag_kwh_flag) and id(waermemertrag_heiz_tag_wh_flag)){
id(waermemertrag_heiz_tag_kwh) += id(waermemertrag_heiz_tag_wh_float);
id(daily_heating_energy).publish_state(id(waermemertrag_heiz_tag_kwh));
id(waermemertrag_heiz_tag_kwh_flag)=false;
id(waermemertrag_heiz_tag_wh_flag)=false;
- lambda: |-
if (id(waermemertrag_ww_tag_kwh_flag) and id(waermemertrag_ww_tag_wh_flag)){
id(waermemertrag_ww_tag_kwh) += id(waermemertrag_ww_tag_wh_float);
id(daily_heating_energy_water).publish_state(id(waermemertrag_ww_tag_kwh));
id(waermemertrag_ww_tag_kwh_flag)=false;
id(waermemertrag_ww_tag_wh_flag)=false;
#el. Leistungsaufnahme WW Tag Wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1a,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme WW Tag kWh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1b,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme WW Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1c,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme WW Summe Mwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1d,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme Heizen Tag Wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1e,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1f,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme Heizen Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x20,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme Heizen Summe Mwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x21,0x00,0x00 ]
can_id: 0x680
- delay: 10s
- lambda: |-
if (id(el_aufnahmeleistung_ww_total_mWh_flag) and id(el_aufnahmeleistung_ww_total_kWh_flag)){
id(el_aufnahmeleistung_ww_total_mWh) += id(el_aufnahmeleistung_ww_total_kWh_float);
id(total_electric_energy_water).publish_state(id(el_aufnahmeleistung_ww_total_mWh));
id(el_aufnahmeleistung_ww_total_mWh_flag)=false;
id(el_aufnahmeleistung_ww_total_kWh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_heiz_total_mWh_flag) and id(el_aufnahmeleistung_heiz_total_kWh_flag)){
id(el_aufnahmeleistung_heiz_total_mWh) += id(el_aufnahmeleistung_heiz_total_kWh_float);
id(total_electric_energy_heating).publish_state(id(el_aufnahmeleistung_heiz_total_mWh));
id(el_aufnahmeleistung_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_ww_tag_kwh_flag) and id(el_aufnahmeleistung_ww_tag_wh_flag)){
id(el_aufnahmeleistung_ww_tag_kwh) += id(el_aufnahmeleistung_ww_tag_wh_float);
id(daily_electric_energy_water).publish_state(id(el_aufnahmeleistung_ww_tag_kwh));
id(el_aufnahmeleistung_ww_tag_kwh_flag)=false;
id(el_aufnahmeleistung_ww_tag_wh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_heiz_tag_kwh_flag) and id(el_aufnahmeleistung_heiz_tag_wh_flag)){
id(el_aufnahmeleistung_heiz_tag_kwh) += id(el_aufnahmeleistung_heiz_tag_wh_float);
id(daily_electric_energy_heating).publish_state(id(el_aufnahmeleistung_heiz_tag_kwh));
id(el_aufnahmeleistung_heiz_tag_kwh_flag)=false;
id(el_aufnahmeleistung_heiz_tag_wh_flag)=false;
- lambda: |-
ESP_LOGD("main", "EVU Sperre requested");
#Aussentemperatur 1/10 Frad et dec value - ok /10 0x000c, et_dec_val
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x0c,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#Vorlauftemperatur Hzg - ok 1/10 0x01d6 WPVORLAUFIST
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x01,0xd6,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#Ruecklauftemperatur Hzg - ok 1/10 0x0016 RUECKLAUFISTTEMP
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x16,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WW Temperatur - ok + offset 0x000e SPEICHERISTTEMP
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x0e,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#Quelle IST: - ok 1/10 0x01d4 QUELLE_IST
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x01,0xd4,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
spi:
clk_pin: GPIO16
mosi_pin: GPIO5
miso_pin: GPIO4
canbus:
- platform: mcp2515
spi_id: McpSpi
cs_pin: GPIO14
can_id: 680
use_extended_id: false
bit_rate: 20kbps
on_frame:
#Warmwasser-Temperaturabfrage + Offset 3.9 Grad
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x0e) {
float temperature =float((float((int((x[6])+( (x[5])<<8))))/10)+3.9);
id(temperature_water).publish_state(temperature);
ESP_LOGD("main", "Temperature received over can is %f", temperature);
#Quellen-Temperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x01 and x[4] == 0xd4) {
float temperature =float(float((int((x[6])+( (x[5])<<8))))/10);
id(temperature_source).publish_state(temperature);
#Vorlauftemperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x01 and x[4] == 0xd6) {
id(temperature_forerun).publish_state(temperature);
#Ruecklauftemperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x16) {
id(temperature_return).publish_state(temperature);
#Aussentemperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x0c) {
id(temperature_outside).publish_state(temperature);
#Elektrische Leistungsaufnahme Wh /kWh
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0xfa and x[3]==0x09) {
if (x[4]==0x1a){
id(el_aufnahmeleistung_ww_tag_wh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_ww_tag_wh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_tag_kwh received over can is %f", id(el_aufnahmeleistung_ww_tag_wh_float));}
else if (x[4]==0x1e){
id(el_aufnahmeleistung_heiz_tag_wh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_heiz_tag_wh_flag) = true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_tag_wh received over can is %f", id(el_aufnahmeleistung_heiz_tag_wh_float));}
else if (x[4]==0x1c){
id(el_aufnahmeleistung_ww_total_kWh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_ww_total_kWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_total_kkWh received over can is %f", id(el_aufnahmeleistung_ww_total_kWh_float));}
else if (x[4]==0x20){
id(el_aufnahmeleistung_heiz_total_kWh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_heiz_total_kWh_flag) = true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_total_kWh received over can is %f", id(el_aufnahmeleistung_heiz_total_kWh_float));}
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0xfa and x[3]==0x00 and x[4]==0x74){
if(x[5]==0x80 and x[6]==0x00){
id(evu_lock).publish_state(false);
else{
id(evu_lock).publish_state(true);
#Elektrische Leistungsaufnahme kWh / MWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x1b){
id(el_aufnahmeleistung_ww_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_ww_tag_kwh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_tag_kwh received over can is %f", id(el_aufnahmeleistung_ww_tag_kwh));}
else if(x[4]==0x1f){
id(el_aufnahmeleistung_heiz_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_heiz_tag_kwh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_tag_kwh received over can is %f", id(el_aufnahmeleistung_heiz_tag_kwh));}
else if(x[4]==0x1d){
id(el_aufnahmeleistung_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_ww_total_mWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_total_mWh received over can is %f", id(el_aufnahmeleistung_ww_total_mWh));}
else if(x[4]==0x21){
id(el_aufnahmeleistung_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_total_mWh received over can is %f", id(el_aufnahmeleistung_heiz_total_mWh));}
#Wärmeertrag WW/Heizung MWh / kWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x23){
id(waermemertrag_electr_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_electr_ww_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_ww_tag_kwh received over can is %f", id(waermemertrag_electr_ww_total_mWh));}
else if(x[4]==0x27){
id(waermemertrag_electr_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_electr_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_heiz_tag_kwh received over can is %f", id(waermemertrag_electr_heiz_total_mWh));}
else if(x[4]==0x2b){
id(waermemertrag_ww_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_ww_tag_kwh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_tag_kwh received over can is %f", id(waermemertrag_ww_tag_kwh));}
else if(x[4]==0x2d){
id(waermemertrag_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_ww_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_total_mWh received over can is %f", id(waermemertrag_ww_total_mWh));}
else if(x[4]==0x2f){
id(waermemertrag_heiz_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_heiz_tag_kwh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_tag_kwh received over can is %f", id(waermemertrag_heiz_tag_kwh));}
else if(x[4]==0x31){
id(waermemertrag_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_total_kWh_float received over can is %f", id(waermemertrag_heiz_total_mWh));}
#Wärmeertrag WW/Heizung Wh / kWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x22){
id(waermemertrag_electr_ww_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_electr_ww_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_ww_tag_wh_float received over can is %f", id(waermemertrag_electr_ww_total_kWh_float));}
else if(x[4]==0x26){
id(waermemertrag_electr_heiz_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_electr_heiz_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_heiz_tag_wh_float received over can is %f", id(waermemertrag_electr_heiz_total_kWh_float));}
else if(x[4]==0x2a){
id(waermemertrag_ww_tag_wh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_ww_tag_wh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_tag_wh_float received over can is %f", id(waermemertrag_ww_tag_wh_float));}
else if(x[4]==0x2c){
id(waermemertrag_ww_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_ww_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_total_kWh_float received over can is %f", id(waermemertrag_ww_total_kWh_float));}
else if(x[4]==0x2e){
id(waermemertrag_heiz_tag_wh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_heiz_tag_wh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_tag_wh_float received over can is %f", id(waermemertrag_heiz_tag_wh_float));}
else if(x[4]==0x30){
id(waermemertrag_heiz_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_heiz_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_total_kWh_float received over can is %f", id(waermemertrag_heiz_total_kWh_float));}
#Show data in raw form as hex-values
- can_id: 0x180
then:
- lambda: |-
int wert0 = int(x[0]);
int wert1 =int(x[1]);
int wert2 =int(x[2]);
int wert3 =int(x[3]);
int wert4 =int(x[4]);
int wert5 =int(x[5]);
int wert6 =int(x[6]);
float wert7 = float(int((x[6])+( (x[5])<<8)));
ESP_LOGD("main", "Antwort von 180 Hex: %x %x %x %x %x %x %x", wert0, wert1, wert2, wert3, wert4, wert5, wert6);
ESP_LOGD("main", "Antwort von 180 Float: %f", wert7);
ESP_LOGD("main", "Antwort von 180 Dez.: %i %i", wert5, wert6);
Prototype
