Thanks for these hints. I will give it a try when I am back from business travel.
I see two separate scenarios for the two approaches.
storing PV electricity. Your solution to force the hot water production definitely makes sense.
do not run the heating at night, if the following day is expected to be very sunny or surprisingly high temperature.
For the latter I see a big savings potential for us, so I would be very interested to automate this, or at least have it manually controllable via Home Assistant.
Do you still have the program code to switch between Eco and Comfort or could you give me a tip on how to do that?
Thanks in advance
Hey all,
Thank you all for sharing your achievements!
Iâve successfully connected esp32 with mcp2515 to my WPM4 module and getting some data.
None of the hex data received match on frame if statements
08:40:14][D][canbus:070]: received can message (#1) std can_id=0x480 size=7
[08:40:14][I][main:1491]: Antwort von 480 Hex: a1 0 fa 1 d6 0 0
[08:40:14][I][main:1492]: Antwort von 480 Float: 0.000000
[08:40:14][I][main:1493]: Antwort von 480 Dez.: 0 0
[08:40:14][I][main:1494]: Antwort klein von 480 Float: 470.000000
[08:40:14][I][main:1495]: Antwort klein von 480 Dez.: 1 214
[08:40:14][D][canbus:070]: received can message (#2) std can_id=0x480 size=7
[08:40:14][I][main:1491]: Antwort von 480 Hex: a1 0 fa 7 a8 0 0
[08:40:14][I][main:1494]: Antwort klein von 480 Float: 1960.000000
[08:40:14][I][main:1495]: Antwort klein von 480 Dez.: 7 168
[08:24:33][D][canbus:070]: received can message (#3) std can_id=0x180 size=7
[08:24:33][I][main:1435]: Antwort von 180 Hex: a0 79 c 0 60 0 0
[08:24:33][I][main:1436]: Antwort von 180 Float: 0.000000
[08:24:33][I][main:1437]: Antwort von 180 Dez.: 0 0
[08:24:33][I][main:1438]: Antwort klein von 180 Float: 96.000000
[08:24:33][I][main:1439]: Antwort klein von 180 Dez.: 0 96
[08:24:37][D][canbus:070]: received can message (#1) std can_id=0x180 size=7
[08:24:37][I][main:1435]: Antwort von 180 Hex: 60 79 16 80 0 0 0
[08:24:37][I][main:1436]: Antwort von 180 Float: 0.000000
[08:24:37][I][main:1437]: Antwort von 180 Dez.: 0 0
[08:24:37][I][main:1438]: Antwort klein von 180 Float: 32768.000000
[08:24:37][I][main:1439]: Antwort klein von 180 Dez.: 128 0
[08:24:42][D][canbus:070]: received can message (#1) std can_id=0x180 size=7
[08:24:42][I][main:1435]: Antwort von 180 Hex: 60 79 16 80 0 0 0
[08:24:42][I][main:1436]: Antwort von 180 Float: 0.000000
[08:24:42][I][main:1437]: Antwort von 180 Dez.: 0 0
[08:24:42][I][main:1438]: Antwort klein von 180 Float: 32768.000000
[08:24:42][I][main:1439]: Antwort klein von 180 Dez.: 128 0
[08:24:44][D][canbus:070]: received can message (#7) std can_id=0x180 size=7
[08:24:44][I][main:1435]: Antwort von 180 Hex: 60 79 16 80 0 0 0
[08:24:44][I][main:1436]: Antwort von 180 Float: 0.000000
[08:24:44][I][main:1437]: Antwort von 180 Dez.: 0 0
[08:24:44][I][main:1438]: Antwort klein von 180 Float: 32768.000000
[08:24:44][I][main:1439]: Antwort klein von 180 Dez.: 128 0
[08:24:45][D][canbus:070]: received can message (#1) std can_id=0x180 size=7
[08:24:45][I][main:1435]: Antwort von 180 Hex: 60 79 16 80 0 0 0
[08:24:45][I][main:1436]: Antwort von 180 Float: 0.000000
[08:24:45][I][main:1437]: Antwort von 180 Dez.: 0 0
[08:24:45][I][main:1438]: Antwort klein von 180 Float: 32768.000000
[08:24:45][I][main:1439]: Antwort klein von 180 Dez.: 128 0
[08:24:48][D][canbus:070]: received can message (#3) std can_id=0x180 size=7
[08:24:48][I][main:1435]: Antwort von 180 Hex: a0 79 c 0 5f 0 0
[08:24:48][I][main:1436]: Antwort von 180 Float: 0.000000
[08:24:48][I][main:1437]: Antwort von 180 Dez.: 0 0
[08:24:48][I][main:1438]: Antwort klein von 180 Float: 95.000000
[08:24:48][I][main:1439]: Antwort klein von 180 Dez.: 0 95
[08:24:48][D][canbus:070]: received can message (#4) std can_id=0x180 size=7
[08:24:48][I][main:1435]: Antwort von 180 Hex: 60 79 16 80 0 0 0
[08:24:48][I][main:1438]: Antwort klein von 180 Float: 32768.000000
[08:24:48][I][main:1439]: Antwort klein von 180 Dez.: 128 0
[08:40:14][D][canbus:070]: received can message (#3) std can_id=0x480 size=7
[08:40:14][I][main:1491]: Antwort von 480 Hex: a0 0 fa 9 17 fd 66
[08:40:14][I][main:1492]: Antwort von 480 Float: 64870.000000
[08:40:14][I][main:1493]: Antwort von 480 Dez.: 253 102
[08:40:14][I][main:1494]: Antwort klein von 480 Float: 2327.000000
[08:40:14][I][main:1495]: Antwort klein von 480 Dez.: 9 23
[08:40:14][D][canbus:070]: received can message (#4) std can_id=0x500 size=7
[08:40:14][I][main:1454]: Antwort von 180 Hex: 92 0 fa 1 d6 0 f1
[08:40:14][I][main:1455]: Antwort von 180 Float: 241.000000
[08:40:14][I][main:1456]: Antwort von 180 Dez.: 0 241
[08:40:14][I][main:1457]: Antwort klein von 180 Float: 470.000000
[08:40:14][I][main:1458]: Antwort klein von 180 Dez.: 1 214
[08:40:14][D][canbus:070]: received can message (#5) std can_id=0x500 size=7
[08:40:14][I][main:1454]: Antwort von 180 Hex: 92 0 16 0 b1 0 0
[08:40:14][I][main:1455]: Antwort von 180 Float: 0.000000
[08:40:14][I][main:1456]: Antwort von 180 Dez.: 0 0
[08:40:14][I][main:1457]: Antwort klein von 180 Float: 177.000000
[08:40:14][I][main:1458]: Antwort klein von 180 Dez.: 0 177
[08:40:14][D][canbus:070]: received can message (#6) std can_id=0x500 size=7
[08:40:14][I][main:1454]: Antwort von 180 Hex: 92 0 fa 7 a8 0 8
[08:40:14][I][main:1455]: Antwort von 180 Float: 8.000000
[08:40:14][I][main:1456]: Antwort von 180 Dez.: 0 8
[08:40:14][I][main:1457]: Antwort klein von 180 Float: 1960.000000
[08:40:14][I][main:1458]: Antwort klein von 180 Dez.: 7 168
[08:40:14][D][canbus:070]: received can message (#7) std can_id=0x480 size=7
[08:40:14][I][main:1491]: Antwort von 480 Hex: a1 0 fa a 36 0 0
[08:40:14][I][main:1494]: Antwort klein von 480 Float: 2614.000000
[08:40:14][I][main:1495]: Antwort klein von 480 Dez.: 10 54
[08:40:14][D][canbus:070]: received can message (#8) std can_id=0x180 size=7
[08:40:14][I][main:1436]: Antwort von 180 Hex: a0 0 fa 1 d7 1 17
[08:40:14][I][main:1437]: Antwort von 180 Float: 279.000000
[08:40:14][I][main:1438]: Antwort von 180 Dez.: 1 23
[08:40:14][I][main:1439]: Antwort klein von 180 Float: 471.000000
[08:40:14][I][main:1440]: Antwort klein von 180 Dez.: 1 215
[08:40:14][D][canbus:070]: received can message (#9) std can_id=0x480 size=7
[08:40:14][I][main:1491]: Antwort von 480 Hex: a0 0 fa 4e 30 0 0
[08:40:14][I][main:1494]: Antwort klein von 480 Float: 20016.000000
[08:40:14][I][main:1495]: Antwort klein von 480 Dez.: 78 48
config
#WW_Programm
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x17,0xa0,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM NE WW Summe kwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x24,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM NE WW Summe mwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x25,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM NE Heizen Summe kwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x28,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM NE Heizen Summe mwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x29,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM WW Tag wh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2a,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM WW Tag kwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2b,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM WW Summe kwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2c,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM WW Summe Mwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2d,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM Heizen Tag wh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2e,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM Heizen Tag kwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2f,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM Heizen Summe kwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x30,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WM Heizen Summe Mwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x31,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#el. Leistungsaufnahme WW Tag Wh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1a,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#el. Leistungsaufnahme WW Tag kWh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1b,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#el. Leistungsaufnahme WW Summe kwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1c,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#el. Leistungsaufnahme WW Summe Mwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1d,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#el. Leistungsaufnahme Heizen Tag Wh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1e,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1f,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#el. Leistungsaufnahme Heizen Summe kwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x20,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#el. Leistungsaufnahme Heizen Summe Mwh
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x21,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
- lambda: |-
if (id(waermemertrag_electr_ww_total_mWh_flag) and id(waermemertrag_electr_ww_total_kWh_flag)){
id(waermemertrag_electr_ww_total_mWh) += id(waermemertrag_electr_ww_total_kWh_float);
id(total_electric_heating_energy_water).publish_state(id(waermemertrag_electr_ww_total_mWh));
id(ww_cop_ertrag_electr_flag)=true;
id(waermemertrag_electr_ww_total_mWh_flag)=false;
id(waermemertrag_electr_ww_total_kWh_flag)=false;
- lambda: |-
if (id(waermemertrag_electr_heiz_total_kWh_flag) and id(waermemertrag_electr_heiz_total_mWh_flag)){
id(waermemertrag_electr_heiz_total_mWh) += id(waermemertrag_electr_heiz_total_kWh_float);
id(total_electric_heating_energy).publish_state(id(waermemertrag_electr_heiz_total_mWh));
id(heat_cop_ertrag_electr_flag)=true;
id(waermemertrag_electr_heiz_total_kWh_flag)=false;
id(waermemertrag_electr_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(waermemertrag_ww_total_mWh_flag) and id(waermemertrag_ww_total_kWh_flag)){
id(waermemertrag_ww_total_mWh) += id(waermemertrag_ww_total_kWh_float);
id(total_heating_energy_water).publish_state(id(waermemertrag_ww_total_mWh));
id(ww_cop_ertrag_flag)=true;
id(waermemertrag_ww_total_mWh_flag)=false;
id(waermemertrag_ww_total_kWh_flag)=false;
- lambda: |-
if (id(waermemertrag_heiz_total_kWh_flag) and id(waermemertrag_heiz_total_mWh_flag)){
id(waermemertrag_heiz_total_mWh) += id(waermemertrag_heiz_total_kWh_float);
id(total_heating_energy).publish_state(id(waermemertrag_heiz_total_mWh));
id(heat_cop_ertrag_flag)=true;
id(waermemertrag_heiz_total_kWh_flag)=false;
id(waermemertrag_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(waermemertrag_heiz_tag_kwh_flag) and id(waermemertrag_heiz_tag_wh_flag)){
id(waermemertrag_heiz_tag_kwh) += id(waermemertrag_heiz_tag_wh_float);
id(daily_heating_energy).publish_state(id(waermemertrag_heiz_tag_kwh));
id(waermemertrag_heiz_tag_kwh_flag)=false;
id(waermemertrag_heiz_tag_wh_flag)=false;
- lambda: |-
if (id(waermemertrag_ww_tag_kwh_flag) and id(waermemertrag_ww_tag_wh_flag)){
id(waermemertrag_ww_tag_kwh) += id(waermemertrag_ww_tag_wh_float);
id(daily_heating_energy_water).publish_state(id(waermemertrag_ww_tag_kwh));
id(waermemertrag_ww_tag_kwh_flag)=false;
id(waermemertrag_ww_tag_wh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_ww_total_mWh_flag) and id(el_aufnahmeleistung_ww_total_kWh_flag)){
id(el_aufnahmeleistung_ww_total_mWh) += id(el_aufnahmeleistung_ww_total_kWh_float);
id(total_electric_energy_water).publish_state(id(el_aufnahmeleistung_ww_total_mWh));
id(ww_cop_electr_leistung_flag)=true;
id(el_aufnahmeleistung_ww_total_mWh_flag)=false;
id(el_aufnahmeleistung_ww_total_kWh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_heiz_total_mWh_flag) and id(el_aufnahmeleistung_heiz_total_kWh_flag)){
id(el_aufnahmeleistung_heiz_total_mWh) += id(el_aufnahmeleistung_heiz_total_kWh_float);
id(total_electric_energy_heating).publish_state(id(el_aufnahmeleistung_heiz_total_mWh));
id(heat_cop_electr_leistung_flag)=true;
id(el_aufnahmeleistung_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_ww_tag_kwh_flag) and id(el_aufnahmeleistung_ww_tag_wh_flag)){
id(el_aufnahmeleistung_ww_tag_kwh) += id(el_aufnahmeleistung_ww_tag_wh_float);
id(daily_electric_energy_water).publish_state(id(el_aufnahmeleistung_ww_tag_kwh));
id(el_aufnahmeleistung_ww_tag_kwh_flag)=false;
id(el_aufnahmeleistung_ww_tag_wh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_heiz_tag_kwh_flag) and id(el_aufnahmeleistung_heiz_tag_wh_flag)){
id(el_aufnahmeleistung_heiz_tag_kwh) += id(el_aufnahmeleistung_heiz_tag_wh_float);
id(daily_electric_energy_heating).publish_state(id(el_aufnahmeleistung_heiz_tag_kwh));
id(el_aufnahmeleistung_heiz_tag_kwh_flag)=false;
id(el_aufnahmeleistung_heiz_tag_wh_flag)=false;
#Berechnung Coefficient of Performance (COP)
- lambda: |-
if (id(ww_cop_ertrag_electr_flag) and id(ww_cop_ertrag_flag) and id(ww_cop_electr_leistung_flag)){
id(ww_cop_float) = (id(waermemertrag_ww_total_mWh)+id(waermemertrag_electr_ww_total_mWh))/id(el_aufnahmeleistung_ww_total_mWh);
id(cop_water).publish_state(id(ww_cop_float));
id(ww_cop_flag)=true;
id(ww_cop_ertrag_electr_flag)=false;
id(ww_cop_ertrag_flag)=false;
id(ww_cop_electr_leistung_flag)=false;
- lambda: |-
if (id(heat_cop_ertrag_electr_flag) and id(heat_cop_ertrag_flag) and id(heat_cop_electr_leistung_flag)){
id(heat_cop_float) = (id(waermemertrag_heiz_total_mWh)+id(waermemertrag_electr_heiz_total_mWh))/id(el_aufnahmeleistung_heiz_total_mWh);
id(cop_heater).publish_state(id(heat_cop_float));
id(heat_cop_flag)=true;
id(heat_cop_ertrag_electr_flag)=false;
id(heat_cop_ertrag_flag)=false;
id(heat_cop_electr_leistung_flag)=false;
- lambda: |-
if (id(heat_cop_flag) and id(ww_cop_flag)){
id(total_cop_float) = ((id(waermemertrag_heiz_total_mWh)+id(waermemertrag_electr_heiz_total_mWh))+(id(waermemertrag_ww_total_mWh)+id(waermemertrag_electr_ww_total_mWh)))/(id(el_aufnahmeleistung_heiz_total_mWh)+id(el_aufnahmeleistung_ww_total_mWh));
id(cop_total).publish_state(id(total_cop_float));
id(heat_cop_flag)=false;
id(ww_cop_flag)=false;
#AuĂentemperatur 1/10 °C et dec value
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x0c,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WW Speicher IST
- canbus.send:
data: [ 0x31, 0x00, 0x0e,0x00,0x00,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#RĂŒcklauftemperatur Hzg - 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x16,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WW Soll-Temperatur
- canbus.send:
data: [ 0x31, 0x00, 0x03,0x00,0x00,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#Quelle IST: - 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x01,0xd4,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
# { "HEISSGAS_TEMP" , 0x0265, et_dec_val}
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x02,0x65,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#T_Heizkreis_IST Abfrage: - 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x02,0xca,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#T_Heizkreis_Soll Abfrage: - 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x01,0xd7,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#Warmwasser Betriebsmodus Abfrage: - 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x01,0x12,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WW Eco Soll Abfrage
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x0a,0x06,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
#WW Komfort Soll Abfrage
- canbus.send:
data: [ 0x31, 0x00, 0x13,0x00,0x00,0x00,0x00 ]
can_id: 0x680
- delay: 500ms
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
canbus:
- platform: mcp2515
spi_id: McpSpi
cs_pin: GPIO17
can_id: 680
use_extended_id: false
bit_rate: 20kbps
on_frame:
#T Heizkreis WW Komfort Soll Abfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0x13) {
float temperature =(float((int16_t((x[4])+( (x[3])<<8))))/10);
id(ww_temp_komfort_log).publish_state(temperature);
ESP_LOGD("main", "T Komfort Soll empfangen over can is %f", temperature);
#T Heizkreis WW Eco Soll Abfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x0a and x[4]==0x06) {
float temperature =(float((int16_t((x[6])+( (x[5])<<8))))/10);
id(ww_temp_eco_log).publish_state(temperature);
ESP_LOGD("main", "T Eco Soll empfangen over can is %f", temperature);
#T Heizkreis IST Abfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x02 and x[4] == 0xca) {
id(t_heizkreis_ist).publish_state(temperature);
ESP_LOGD("main", "T Heizkreis IST empfangen over can is %f", temperature);
#T Heizkreis Soll Abfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x01 and x[4] == 0xd7) {
id(t_heizkreis_soll).publish_state(temperature);
ESP_LOGD("main", "T Heizkreis Soll empfangen over can is %f", temperature);
#T WW Soll Abfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0x03) {
id(t_ww_soll).publish_state(temperature);
ESP_LOGD("main", "T Warmwasser Soll empfangen over can is %f", temperature);
#WW Programm Start- und Ende-Zeit
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0xfa and x[3]==0x17 and x[4]==0xa0 ) {
int start = int(x[5]);
int ende = int(x[6]);
id(ww_start).publish_state(start);
id(ww_ende).publish_state(ende);
ESP_LOGD("main", "Warmwasser Programmzeit Start und Ende empfangen over can is %i %i", start, ende);
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0xfa and x[3]==0x01 and x[4]==0x12) {
if (x[5]==0x00){
auto call = id(wasserbetrieb).make_call();
call.set_option("Notbetrieb");
call.perform();}
else if (x[5]==0x01){
call.set_option("Bereitschaft");
call.perform();}
else if (x[5]==0x02){
call.set_option("Automatik");
call.perform();}
else if (x[5]==0x03){
call.set_option("Komfort");
call.perform();}
else if (x[5]==0x04){
call.set_option("Eco");
call.perform();}
else if (x[5]==0x05){
call.set_option("Warmwasserbetrieb");
call.perform();}
#Warmwasser-Temperaturabfrage + individueller Offset (3.9 °C)
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x0e) {
float temperature =(float((int16_t((x[6])+( (x[5])<<8))))/10)+3.9;
id(temperature_water).publish_state(temperature);
ESP_LOGD("main", "Warmwasser-Temperature empfangen over can is %f", temperature);
#Quellen-Temperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x01 and x[4] == 0xd4) {
float temperature =float((int16_t((x[6])+( (x[5])<<8))))/10;
id(temperature_source).publish_state(temperature);
ESP_LOGD("main", "Quellen-Temperature received over can is %f", temperature);
#Speicher IST-temperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0x0e) {
float temperature =float((int16_t((x[4])+( (x[3])<<8))))/10;
id(t_ww_ist).publish_state(temperature);
ESP_LOGD("main", "Speicher-Temperature received over can is %f", temperature);
#RĂŒcklauftemperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x16) {
id(temperature_return).publish_state(temperature);
ESP_LOGD("main", "RĂŒcklauf-Temperature received over can is %f", temperature);
#AuĂentemperaturabfrage
#float temperature =float(float((int((x[6])+( (x[5])<<8))))/10);
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x0c) {
id(temperature_outside).publish_state(temperature);
ESP_LOGD("main", "Aussen-Temperature received over can is %f", temperature);
#Luftfeuchtigkeit FEK mitlesen
- can_id: 0x301
then:
- lambda: |-
if(x[0]==0xc0 and x[1]==0x01 and x[2]==0x75) {
float humidity =float(float((int16_t((x[4])+( (x[3])<<8))))/10);
id(humidity_inside).publish_state(humidity);
ESP_LOGD("main", "Humidity received over can is %f", humidity);
#Raumtemperatur FEK mitlesen
- can_id: 0x301
then:
- lambda: |-
if(x[0]==0xc0 and x[1]==0x01 and x[2]==0x11) {
id(temperature_inside).publish_state(temperature);
ESP_LOGD("main", "Raum-Temperature received over can is %f", temperature);
#Elektrische Leistungsaufnahme Wh /kWh
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0xfa and x[3]==0x09) {
if (x[4]==0x1a){
id(el_aufnahmeleistung_ww_tag_wh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_ww_tag_wh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_tag_kwh received over can is %f", id(el_aufnahmeleistung_ww_tag_wh_float));}
else if (x[4]==0x1e){
id(el_aufnahmeleistung_heiz_tag_wh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_heiz_tag_wh_flag) = true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_tag_wh received over can is %f", id(el_aufnahmeleistung_heiz_tag_wh_float));}
else if (x[4]==0x1c){
id(el_aufnahmeleistung_ww_total_kWh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_ww_total_kWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_total_kWh received over can is %f", id(el_aufnahmeleistung_ww_total_kWh_float));}
else if (x[4]==0x20){
id(el_aufnahmeleistung_heiz_total_kWh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_heiz_total_kWh_flag) = true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_total_kWh received over can is %f", id(el_aufnahmeleistung_heiz_total_kWh_float));}
#Elektrische Leistungsaufnahme kWh / MWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x1b){
id(el_aufnahmeleistung_ww_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_ww_tag_kwh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_tag_kwh received over can is %f", id(el_aufnahmeleistung_ww_tag_kwh));}
else if(x[4]==0x1f){
id(el_aufnahmeleistung_heiz_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_heiz_tag_kwh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_tag_kwh received over can is %f", id(el_aufnahmeleistung_heiz_tag_kwh));}
else if(x[4]==0x1d){
id(el_aufnahmeleistung_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_ww_total_mWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_total_mWh received over can is %f", id(el_aufnahmeleistung_ww_total_mWh));}
else if(x[4]==0x21){
id(el_aufnahmeleistung_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_total_mWh received over can is %f", id(el_aufnahmeleistung_heiz_total_mWh));}
#WĂ€rmeertrag WW/Heizung MWh / kWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x25){
id(waermemertrag_electr_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_electr_ww_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_ww_tag_kwh received over can is %f", id(waermemertrag_electr_ww_total_mWh));}
else if(x[4]==0x29){
id(waermemertrag_electr_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_electr_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_heiz_tag_kwh received over can is %f", id(waermemertrag_electr_heiz_total_mWh));}
else if(x[4]==0x2b){
id(waermemertrag_ww_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_ww_tag_kwh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_tag_kwh received over can is %f", id(waermemertrag_ww_tag_kwh));}
else if(x[4]==0x2d){
id(waermemertrag_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_ww_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_total_mWh received over can is %f", id(waermemertrag_ww_total_mWh));}
else if(x[4]==0x2f){
id(waermemertrag_heiz_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_heiz_tag_kwh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_tag_kwh received over can is %f", id(waermemertrag_heiz_tag_kwh));}
else if(x[4]==0x31){
id(waermemertrag_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_total_kWh_float received over can is %f", id(waermemertrag_heiz_total_mWh));}
#WĂ€rmeertrag WW/Heizung Wh / kWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x24){
id(waermemertrag_electr_ww_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_electr_ww_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_ww_tag_wh_float received over can is %f", id(waermemertrag_electr_ww_total_kWh_float));}
else if(x[4]==0x28){
id(waermemertrag_electr_heiz_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_electr_heiz_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_heiz_tag_wh_float received over can is %f", id(waermemertrag_electr_heiz_total_kWh_float));}
else if(x[4]==0x2a){
id(waermemertrag_ww_tag_wh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_ww_tag_wh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_tag_wh_float received over can is %f", id(waermemertrag_ww_tag_wh_float));}
else if(x[4]==0x2c){
id(waermemertrag_ww_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_ww_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_total_kWh_float received over can is %f", id(waermemertrag_ww_total_kWh_float));}
else if(x[4]==0x2e){
id(waermemertrag_heiz_tag_wh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_heiz_tag_wh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_tag_wh_float received over can is %f", id(waermemertrag_heiz_tag_wh_float));}
else if(x[4]==0x30){
id(waermemertrag_heiz_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_heiz_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_total_kWh_float received over can is %f", id(waermemertrag_heiz_total_kWh_float));}
Do you have any suggestions on what to do next ?
Many thanks
Hi Bart,
in the log file I donât see that you send a request.
That would look something like this:
[00:05:09][D][canbus:032]: send extended id=0x680 size=7
So it seems to me that you only see the regular communication between the heat pump and the display.
180 being the heat pump and I have no idea what the 480 is.
What I did to make it work (for me) is the following:
I took something where I know the value and which is displayed on first page of my heat pump display. For me this was AuĂentemperatur.
Then I verified the id of AuĂentemperatur by removing the if check for x0 and x1.
Then I tried sending with different can ids.
For me (LWZ 5S Trend) the 6a2 worked nicely.
Hi Bart,
as RedAnt79 mentioned, your log doesnât look if any request was sent from your component.
If you used my last config from September 21st, make sure that you give it some time, as the values only update every few minutes.
e.g. the sensor âAuĂentemperaturâ has an update_interval of 10 minutes.
If you want them to update more often, you can either reduce the time in update_interval, or you create a script in home assistant as I did it, to force an update by pushing a button.
@Sab3rRid3r
Here is the script I currently use for preparing the warm water. For sure it can be improved.
In the heat-pump Iâve set a time-program, that switches to comfort-temperature during the day, and eco at night. You could also leave it at comfort-temperature over the whole day since I only change the comfort-temperature. But I like it to have some failure mode protection if something goes wrong with home assistant.
I also have a towel-heater in the bathroom, which I only turn on if there is enough power available. Thatâs why I distinguish some values with around 650 Watts difference.
alias: A_WW_Warmwasseraufbereitung
description: Warmwasseraufbereitung je nach PV-Strom
- platform: numeric_state
entity_id: sensor.power_real_fronius_meter_0_192_168_1_16
for:
hours: 0
minutes: 8
seconds: 0
below: -2700
for:
hours: 0
minutes: 8
seconds: 0
below: -2050
for:
hours: 0
minutes: 5
seconds: 0
above: 50
entity_id: sensor.wt_dammerung_lx
for:
hours: 0
minutes: 1
seconds: 0
below: 20
value_template: >-
{{as_timestamp(utcnow())|float >=
as_timestamp(states("sensor.power_highest_peak_time_today"))|float}}
condition: []
- if:
- condition: and
conditions:
- condition: trigger
- condition: numeric_state
entity_id: sensor.speicher_ist_temperatur
below: 54
then:
- service: input_text.set_value
value: "{{ 580|int }}"
entity_id: input_text.ww_komfort_temp
else:
- if:
- condition: and
conditions:
below: 48
below: 500
then:
value: "{{ 500|int }}"
else:
- if:
- condition: and
conditions:
below: 450
below: 400
- condition: template
value_template: >
{{states("sensor.energy_production_today")|float >=
states("sensor.energy_production_tomorrow")|float*1.7}}
then:
value: "{{ 450|int }}"
else:
- if:
- condition: and
conditions:
above: 400
then:
value: "{{ 380|int }}"
else:
- if:
- condition: and
conditions:
above: 380
then:
mode: queued
trace:
stored_traces: 20
Hey @RedAnt79 and @roberreiter,
Thank you for all your help.
There were couple of issues with my setup.
First of all I have HM Trend (WPM4) it has 2 CAN A and 2 CAN B ports, CAN A ports are used to connect wpm4 to the heat pump mfg etc and the CAN B ports are for ISG, FET and a like. Initially Iâve been connecting to CAN A ports because these were the only ports that returned some data to the ESP but that setup was troublesome since pump was displaying issues about (interrupted or missing communications between components) so definitely a âno goâ there, CAN B ports where not returning any data⊠after a while Iâve found that CAN A ports are running on 20kbps and CAN B are running on 50kbps, so after changing config in ESP home I finally am getting the data from the heat pump.
Second thing was that not all requests where being accepted when can_id was set to 680, mainly Power consumption and Heat generated were missing so I ended up using can_id: 4 for the mcp2515, but the requests that are send are still send with can_id: 680
Third, the power consumption and heat is transported over can_id: 514.
So at the moment I am able to change the pump mode (comfort, eco, etc.), get water target and current, power consumption, heat generated, circulating heat in the underfloor heating, so, so far so good.
There are still things missing like the FES not answering the temperature or humidity so I guess I have to find correct can_id, or eco and comfort tank target settings
I am trying to get the missing values to show up although Iâve got most of the values that I really cared about.
Now what I need to figure out is how to change comfort and eco heating temperature, it would be great to be able to set that and connect to my Heatmiser unit and set the temperature from thereâŠ
Thank you for all your help and great work!
If anyone is interested thatâs what Iâve got up and running for last couple of days:
globals:
#Variablen fĂŒr Wirkungsgrad der WĂ€rmepumpe
- id: VD_starts_h
type: int
initial_value: '0'
restore_value: no
- id: VD_starts_t
initial_value: '0'
type: float
restore_value: no
- id: ww_cop_float
type: float
restore_value: no
- id: ww_cop_ertrag_electr_flag
type: bool
restore_value: no
- id: ww_cop_ertrag_flag
type: bool
restore_value: no
- id: ww_cop_electr_leistung_flag
type: bool
restore_value: no
- id: heat_cop_float
type: float
restore_value: no
- id: heat_cop_ertrag_electr_flag
type: bool
restore_value: no
- id: heat_cop_ertrag_flag
type: bool
restore_value: no
- id: heat_cop_electr_leistung_flag
type: bool
restore_value: no
- id: heat_cop_flag
type: bool
restore_value: no
- id: ww_cop_flag
type: bool
restore_value: no
- id: total_cop_float
type: float
restore_value: no
##Variablen fĂŒr Senden von CAN-Bus Befehlen aus Eingabefeldern (fĂŒr Debuggin-Zwecke)
# - id: val0
# type: int
# restore_value: no
# - id: val1
# type: int
# restore_value: no
# - id: val2
# type: int
# restore_value: no
# - id: val3
# type: int
# restore_value: no
# - id: val4
# type: int
# restore_value: no
# - id: val5
# type: int
# restore_value: no
# - id: val6
# type: int
# restore_value: no
#Arrays zum Senden von Can-Bus Befehlen aus Programmcode
- id: ww_temp_komfort
type: int[7]
#Vorbelegung zum Senden an CAN-Adresse 480
initial_value: '{0x30,0x00,0x13,0x00,0x00,0x00,0x00}'
restore_value: no
- id: ww_temp_eco
type: int[7]
initial_value: '{0x30,0x00,0xfa,0x0a,0x06,0x00,0x00}'
restore_value: no
#Variablen fĂŒr senden von CAN-Bus Befehlen zum Umschalten auf Warmwasserbetrieb (evtl. ersetzen durch Array)
- id: dataframe0
type: int
restore_value: no
- id: dataframe1
type: int
restore_value: no
- id: dataframe2
type: int
restore_value: no
- id: dataframe3
type: int
restore_value: no
- id: dataframe4
type: int
restore_value: no
- id: dataframe5
type: int
restore_value: no
- id: dataframe6
type: int
restore_value: no
#Variablen fĂŒr Leistungsaufnahme und Flags zur programminternen Berechnung
- id: el_aufnahmeleistung_ww_tag_wh_float
type: float
restore_value: no
- id: el_aufnahmeleistung_ww_tag_wh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_ww_tag_kwh
type: float
restore_value: no
- id: el_aufnahmeleistung_ww_tag_kwh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_heiz_tag_wh_float
type: float
restore_value: no
- id: el_aufnahmeleistung_heiz_tag_wh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_heiz_tag_kwh
type: float
restore_value: no
- id: el_aufnahmeleistung_heiz_tag_kwh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_ww_total_kWh_float
type: float
restore_value: no
- id: el_aufnahmeleistung_ww_total_kWh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_ww_total_mWh
type: float
restore_value: no
- id: el_aufnahmeleistung_ww_total_mWh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_heiz_total_kWh_float
type: float
restore_value: no
- id: el_aufnahmeleistung_heiz_total_kWh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_heiz_total_mWh
type: float
restore_value: no
- id: el_aufnahmeleistung_heiz_total_mWh_flag
type: bool
restore_value: no
- id: waermemertrag_ww_tag_wh_float
type: float
restore_value: no
- id: waermemertrag_ww_tag_wh_flag
type: bool
restore_value: no
- id: waermemertrag_ww_tag_kwh
type: float
restore_value: no
- id: waermemertrag_ww_tag_kwh_flag
type: bool
- id: waermemertrag_electr_ww_tag_wh_float
type: float
restore_value: no
- id: waermemertrag_electr_ww_tag_wh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_ww_tag_kwh
type: float
restore_value: no
- id: waermemertrag_electr_ww_tag_kwh_flag
type: bool
restore_value: no
- id: waermemertrag_heiz_tag_wh_float
type: float
restore_value: no
- id: waermemertrag_heiz_tag_wh_flag
type: bool
restore_value: no
- id: waermemertrag_heiz_tag_kwh
type: float
restore_value: no
- id: waermemertrag_heiz_tag_kwh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_heiz_tag_wh_float
type: float
restore_value: no
- id: waermemertrag_electr_heiz_tag_wh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_heiz_tag_kwh
type: float
restore_value: no
- id: waermemertrag_electr_heiz_tag_kwh_flag
type: bool
restore_value: no
- id: waermemertrag_ww_total_kWh_float
type: float
restore_value: no
- id: waermemertrag_ww_total_kWh_flag
type: bool
restore_value: no
- id: waermemertrag_ww_total_mWh
type: float
restore_value: no
- id: waermemertrag_ww_total_mWh_flag
type: bool
restore_value: no
- id: waermemertrag_heiz_total_kWh_float
type: float
restore_value: no
- id: waermemertrag_heiz_total_kWh_flag
type: bool
restore_value: no
- id: waermemertrag_heiz_total_mWh
type: float
restore_value: no
- id: waermemertrag_heiz_total_mWh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_heiz_total_kWh_float
type: float
restore_value: no
- id: waermemertrag_electr_heiz_total_kWh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_heiz_total_mWh
type: float
restore_value: no
- id: waermemertrag_electr_heiz_total_mWh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_ww_total_kWh_float
type: float
restore_value: no
- id: waermemertrag_electr_ww_total_kWh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_ww_total_mWh
type: float
restore_value: no
- id: waermemertrag_electr_ww_total_mWh_flag
type: bool
restore_value: no
#Sensorabschnitt
name: "Outside temperature"
unit_of_measurement: "°C"
icon: "mdi:thermometer-lines"
device_class: "temperature"
state_class: "measurement"
accuracy_decimals: 1
name: "Source temperature"
name: "Hot water temperature"
icon: "mdi:timer-play"
accuracy_decimals: 0
icon: "mdi:timer-stop"
name: "COP value heating"
unit_of_measurement: "a.u."
icon: "mdi:chart-bell-curve-cumulative"
device_class: "power_factor"
accuracy_decimals: 2
name: "COP value hot water"
name: "Total COP value"
name: "Return temperature heating"
icon: "mdi:waves-arrow-left"
name: "Heating temperature circuit ACTUAL"
icon: "mdi:waves-arrow-right"
name: "Heating temperature circuit target"
name: "Storage target temperature"
icon: "mdi:thermometer-water"
name: "Storage temperature"
name: "Eco storage target temperature"
icon: "mdi:thermometer-low"
name: "Comfort tank target temperature"
icon: "mdi:thermometer-high"
unit_of_measurement: "%rH"
icon: "mdi:water-percent"
device_class: "humidity"
name: "Temperature living room"
name: "Electricity consumption hot water today"
unit_of_measurement: "kWh"
device_class: "energy"
accuracy_decimals: 3
icon: "mdi:transmission-tower"
name: "Electricity consumption heating today"
name: "Total consumption of hot water"
unit_of_measurement: "MWh"
name: "Electricity consumption heating total"
name: "Energy eating today"
icon: "mdi:water-boiler"
name: "Energy heating total"
name: "WM hot water today"
name: "WM hot water total"
name: "WM electr. Total hot water"
name: "WM electr. totally heat"
#Auswahlfeld zum Umschalten der Betriebsmodi
select:
name: "hot water operation"
optimistic: true
options:
- Notbetrieb
- Bereitschaft
- Automatik
- Komfort
- Eco
- Warmwasserbetrieb
initial_option: Automatik
on_value:
then:
- lambda: |-
id(dataframe0)=0x30;
id(dataframe1)=0x00;
id(dataframe2)=0xfa;
id(dataframe3)=0x01;
id(dataframe4)=0x12;
id(dataframe6)=0x00;
if (x=="Automatik"){
id(dataframe5)=0x02;
else if (x=="Komfort"){
id(dataframe5)=0x03;
else if (x=="Eco"){
id(dataframe5)=0x04;
else if (x=="Warmwasserbetrieb"){
id(dataframe5)=0x05;
else if (x=="Bereitschaft"){
id(dataframe5)=0x01;
else if (x=="Notbetrieb"){
id(dataframe5)=0x00;
ESP_LOGD("main", "The current value of hot water operation is %x", id(dataframe5));
#Einstellung Solltemp Eco: 0a06
#Einstellung Solltemp Komfort: 0013
button:
name: Switch hot water mode
on_press:
then:
- canbus.send:
data: !lambda
return {(uint8_t) id(dataframe0),(uint8_t) id(dataframe1),(uint8_t) id(dataframe2),(uint8_t) id(dataframe3), (uint8_t) id(dataframe4),(uint8_t) id(dataframe5),(uint8_t) id(dataframe6)};
can_id: 0x680
switch:
##Restart-sw um tÀglichen Restart von ESP-Device via Homeassistant zu initiieren (Ausfallsicherheit)
- platform: restart
name: "Boiler room ESP restart"
binary_sensor:
#Timer - alle 10 Minuten auslösen
time:
- platform: homeassistant
on_time:
- seconds: 10
then:
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x09,0x1c,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x09,0x1d,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x09,0x20,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x09,0x21,0x00,0x00 ]
can_id: 0x680
- delay: 10s
- lambda: |-
- lambda: |-
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x09,0x1b,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x09,0x1a,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x09,0x1e,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x09,0x1f,0x00,0x00 ]
can_id: 0x680
- delay: 10s
- lambda: |-
- lambda: |-
- canbus.send:
data: [ 0xa1, 0x14, 0xfa,0x00,0x74,0x00,0x00 ]
can_id: 0x680
- lambda: |-
ESP_LOGD("main", "EVU Sperre requested");
#WM NE WW Summe wh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x22,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE WW Summe kwh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x23,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE Heizen Summe wh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x26,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE Heizen Summe kwh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x27,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Tag wh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x2a,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Tag kwh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x2b,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Summe kwh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x2c,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Summe Mwh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x2d,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Tag wh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x2e,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Tag kwh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x2f,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Summe kwh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x30,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Summe Mwh - ok
- canbus.send:
data: [ 0xA1, 0x14, 0xfa,0x09,0x31,0x00,0x00 ]
can_id: 0x680
- delay: 10s
#WW_Programm
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x22,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x23,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x26,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x27,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE WW Summe kwh
- canbus.send:
can_id: 0x680
- delay: 500ms
#WM NE WW Summe mwh
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
#WM WW Tag wh
- canbus.send:
can_id: 0x680
- delay: 500ms
#WM WW Tag kwh
- canbus.send:
can_id: 0x680
- delay: 500ms
#WM WW Summe kwh
- canbus.send:
can_id: 0x680
- delay: 500ms
#WM WW Summe Mwh
- canbus.send:
can_id: 0x680
- delay: 500ms
#WM Heizen Tag wh
- canbus.send:
can_id: 0x680
- delay: 500ms
#WM Heizen Tag kwh
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- lambda: |-
- canbus.send:
can_id: 0x680
- delay: 500ms
#WW Speicher IST
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
#WW Soll-Temperatur
- canbus.send:
can_id: 0x680
- delay: 500ms
#Quelle IST: - 1/10
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
- canbus.send:
can_id: 0x680
- delay: 500ms
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
canbus:
- platform: mcp2515
spi_id: McpSpi
cs_pin: GPIO17
can_id: 4
bit_rate: 50kbps
on_frame:
- can_id: 0x514
then:
- lambda: |-
if(x[4]==0x1b){
- can_id: 0x514
then:
- lambda: |-
if (x[4]==0x1a){
ESP_LOGD("main", "el_aufnahmeleistung_ww_total_kkWh received over can is %f", id(el_aufnahmeleistung_ww_total_kWh_float));}
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0xfa and x[3]==0x00 and x[4]==0x74){
if(x[5]==0x80 and x[6]==0x00){
id(evu_lock).publish_state(false);
else{
id(evu_lock).publish_state(true);
- can_id: 0x514
then:
- lambda: |-
if(x[4]==0x23){
else if(x[4]==0x27){
- can_id: 0x514
then:
- lambda: |-
if(x[4]==0x22){
else if(x[4]==0x26){
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "T Comfort Should receiveover can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "T Eco target received over can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "T heating circuit ACTUAL received over can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "T heating circuit target receivedover can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "T Hot water target received over can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "Receive hot water program time start and end over can is %i %i", start, ende);
- can_id: 0x180
then:
- lambda: |-
if (x[5]==0x00){
call.perform();}
call.perform();}
call.perform();}
call.perform();}
call.perform();}
call.perform();}
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "Receive hot water temperature over can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "Source Temperature received over can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "Storage temperature received over can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "Return temperature receivedover can is %f", temperature);
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD("main", "Outside temperature received over can is %f", temperature);
- can_id: 0x301
then:
- lambda: |-
- can_id: 0x301
then:
- lambda: |-
ESP_LOGD("main", "Room temperature received over can is %f", temperature);
Hey Guys, can anyone please post their pinouts for either the Esp32-wroom and/or Wemos d1 mini?
I have both but I cannot confirm the MCP2515 device works.
Initially I had a raspberry pi zero with a CAN hat, that device works and I see data coming in, using it as a esphome alternative is not possible so I got a MCP2515 but whatever I do nothing is coming in from the Stiebel. When I link the MCP2515 with the RPI also nothing is showing, neither using the D1 nor esp32âŠ
I suspect the issue is with the way the MCP2515 is connected to the esp/d1 but I wanted to be sure before I order a new oneâŠ
Tia
As to âwhy donât you use the rpiâ?
I cannot get the can_tools to compile, I have been playing with python to receive the messages which works but all the stuff thatâs needed to convert the CAN message to something usable is not something I can do without first properly learning pythonâŠ
The esphome route is much easier and is exactly what Iâm looking forâŠ
Hey @Radiotechniman
I have it setup as follows
VCC â V5
GND â GND
SCK â G18 (GPIO18)
SI â G23 (GPIO23)
SO â G19 (GPIO19)
CS â G17 (GPIO17)
Can id â 4
Bit rate â 50kbps
Well that helped a bit, Iâm now seeing some response, just not the stuff Iâm looking for
Could this be the IDis not correct?
[22:02:57][D][canbus:033]: send extended id=0x680 rtr=FALSE size=7
[22:02:57][D][canbus:067]: received can message (#1) extended can_id=0x5fa13f size=5
[22:02:58][D][canbus:033]: send extended id=0x680 rtr=FALSE size=7
[22:02:59][D][canbus:033]: send extended id=0x680 rtr=FALSE size=7
[22:02:59][D][canbus:070]: received can message (#1) std can_id=0x0 size=0
[22:03:00][D][canbus:033]: send extended id=0x680 rtr=FALSE size=7
Just a quick question,
is it possible to use CAN with Home Assistant on a Raspberry PI with this CAN HAT?
Properties:
Raspberry Pi connectivity, compatible with Raspberry Pi Zero/Zero W/Zero WH/2B/3B/3B+
CAN function, onboard CAN controller MCP2515 via SPI interface, with transceiver SN65HVD230
RS485 function, controlled via UART, half-duplex communication, with transceiver SP3485
Reserved control pins, allows to work with other control boards
Comes with development resources and manual (examples in wiringPi/python)
Specifications
Operating voltage: 3.3V
CAN controller: MCP2515
CAN transceiver: SN65HVD230
485 transceiver: SP3485
Dimension: 65mm x 30mm
Mounting hole size: 3.0mm
Hello, since the outside temperatures go into the negative I get strange values. Looks like 16bit 65536 overflow to me. Do you have any idea how to fix this?
[18:18:28][D][canbus:033]: send extended id=0x680 rtr=FALSE size=7
[18:18:28][D][canbus:069]: received can message (#1) std can_id=0x180 size=7
[18:18:28][D][sensor:126]: âAuĂentemperaturâ: Sending state 6552.60010 °C with 1 decimals of accuracy
[18:18:28][D][main:616]: Temperature received over can is 6552.600098
[18:18:28][D][main:747]: Antwort von 180 Hex: d2 0 fa 0 c ff f6
[18:18:28][D][main:748]: Antwort von 180 Float: 65526.000000
[18:18:28][D][main:749]: Antwort von 180 Dez.: 255 246
#Aussentemperaturabfrage
- can_id: 0x180
then:
- lambda: |-
ESP_LOGD(âmainâ, âTemperature received over can is %fâ, temperature);
Usually you get this kind of answer if you query the wrong idx. E.g. the wrong device where this index is not available. Probably you should try to ask one of the other can addresses in the bus.
The index should be correct I think because when the temperature is positive everything is working like expected. Plz take a look at the pictures. Thanks in advance.
Log from negative temperature degree celsius
Log from positive temperature degree celsius
[14:02:23][D][sensor:126]: âAuĂentemperaturâ: Sending state 4.50000 °C with 1 decimals of accuracy
[14:02:23][D][main:616]: Temperature received over can is 4.500000
[14:02:23][D][main:747]: Antwort von 180 Hex: d2 0 fa 0 c 0 2d
[14:02:23][D][main:748]: Antwort von 180 Float: 45.000000
[14:02:23][D][main:749]: Antwort von 180 Dez.: 0 45
Brainstormin, possible solution?
When value > e.g. 65000
256 * 256 = 65536
65536 - value from reading in this case 65526 = 10
10 / 10 *-1 = -0.1 degree celsius
I have the same problem with my LWZ 304 Flex
I must admit, now that youâre telling this, I think I had this problem somewhere in the beginning of the year. But temperatures never went below zero since then. Is there a standard way to convert into float with negative sign?
Otherwise I think the solution proposed could work.
I have the same one, it receives the data from the CANbus perfectly but converting that to usable data is where I stopped. As mentioned I tried with the normal tools as with python but ultimately went with a Wemos D1 + Can which works pretty well
