Configuring a FS20z-1 for garage Door
I have a LINEAR-FS20Z-1-Isolated-Contact-Fixture that i am trying to use as a cover for garage door.
I also have a Ecolink Tilt Sensor that i am trying to use.
I looked the old topics and got this configuration in my configuration.yaml.
``cover:
  • platform: template
    covers:
    car_door:
    friendly_name: “Garage Door”
    open_cover:
    service: switch.turn_on
    entity_id: script.garage_door_toggle
    close_cover:
    stop_cover:
    value_template: >
    {{ is_state(‘binary_sensor.ecolink_tilt_sensor_sensor’, ‘on’) }}
    icon_template: >
    {% if is_state(‘binary_sensor.ecolink_tilt_sensor_sensor’, ‘on’) %}
    mdi:garage-open
    {% else %}
    mdi:garage
    {% endif %}``
I also have a garage_door_toogle.yaml (Linear NGDZ00-4 Garage Door)
However the cover does not work. There is no response or logs.
Can someone help me with this.
Please point me to any example you may have.
Can you format your code properly.
Thanks. Here is my cover.yaml.
    covers:
      garagedoor:
        friendly_name: 'Garage Door'
        value_template: >
          {%- if states.binary_sensor.ecolink_tilt_sensor_sensor -%}
            {{ states.binary_sensor.ecolink_tilt_sensor_sensor.state == 'on' }}
          {%- else -%}
            true
          {%- endif -%}
        open_cover:
          entity_id: switch.garage_relay
        close_cover:
        stop_cover:
        icon_template: >
          {%- if states.binary_sensor.ecolink_tilt_sensor_sensor.state == 'on' -%}
            mdi:garage-open
          {%- else -%}
            mdi:garage
          {%- endif -%}
I have included this thru configuration.yaml with
cover: !include cover.yaml
I was able to figure out. Thanks
