Configuring Shelly EM Energy Meter
My Shelly EM energy meter arrived today (at last) and I’m having some difficulty configuring it to display in HA.
As it’s so new, Shelly haven’t yet updated the API docs, but most of it can be gleaned from here. The Shelly EM user manual is here.
The Shelly Web UI displays this:
Using MQTT explorer, I’ve determined that it publishes the following:
shellies/shellyem-xxxxxx/relay/0
shellies/shellyem-xxxxxx/emeter/0/returned_energy
shellies/shellyem-xxxxxx/emeter/0/energy
shellies/shellyem-xxxxxx/emeter/0/voltage
shellies/shellyem-xxxxxx/emeter/0/reactive_power
shellies/shellyem-xxxxxx/emeter/0/power
shellies/shellyem-xxxxxx/emeter/1/returned_energy
shellies/shellyem-xxxxxx/emeter/1/energy
shellies/shellyem-xxxxxx/emeter/1/voltage
shellies/shellyem-xxxxxx/emeter/1/reactive_power
shellies/shellyem-xxxxxx/emeter/1/power
I’ve configured a sensor in HA like this:
- platform: mqtt
  name: "Energy Meter 1"
  state_topic: "shellies/shellyem-xxxxxx/emeter/1/power"
  qos: 1
  unit_of_measurement: "W"
  icon: mdi:gauge
Any help will be much appreciated.
This is now working using the config above, replacing ‘power’ in the state_topic for whichever of the readings you want to display from returned_energy, energy, voltage, reactive_power and power.
I’m not too sure what the difference should be between ‘power’ and ‘energy’ but the power reading is constantly 0.
The returned_energy is for those with solar panels/turbine.
The web UI displays Power Factor but this does not seem to be available via MQTT.
You can use this script: Shellies Discovery Script
Mine arrived today. Holey shit that app is bad.
I cant even get my Shelly EM to connect to a local wifi network.
I connected to the EM’s local network.
Under user settings in the app I filled in the batch wifi update settings (2.4GHz network SSID and PWD) and selected both power meters that appear. Hit update but nothing appears in my DHCP server.
EDIT: I deleted the app and just used the web settings.
EDIT 2: Also if anyone is looking for an RSSI sensor, this works:
- platform: rest
  name: Shelly EM Wifi
  resource: http://10.1.1.24/status ### Edit to use the IP of your Shelly EM
  username: !secret shelly_usr ### Only required if you have set a password
  password: !secret shelly_pwd ###  "    "              "            "
  authentication: basic        ###  "    "              "            "
  value_template: '{{ value_json.wifi_sta.rssi }}'
  scan_interval: 180  ### Feel free to make faster, 30 or 60 sec would be fine
  unit_of_measurement: dB
Edit 3:
Another trap for players, who the flock uses Watt-minutes? Ugh. Fix:
- platform: mqtt
  name: "Tariff 31 Energy"
  state_topic: "shellies/shellyem-B9E940/emeter/0/energy"
  value_template: "{{ value|float / 60000 }}" # Fix for Watt-minutes
  qos: 1
  unit_of_measurement: "kWh"
  icon: mdi:chart-bar
- platform: mqtt
  name: "Tariff 41 Energy"
  state_topic: "shellies/shellyem-B9E940/emeter/1/energy"
  qos: 1
  icon: mdi:chart-bar
EDIT 4:
But ignore those sensors because they wont work with the Utility meter if you want a daily energy used sensor (they reset to 0 if no power is used for a minute). You need to use a rest sensor to interrogate the yearly totals like this:
- platform: rest
  name: Tariff 31 Total Energy
  value_template: '{{ value_json.emeters.0.total | float /1000 }}'
  scan_interval: 300 # no point updating faster than this. The Shelly only updates this every 5 minutes
  unit_of_measurement: kWh
- platform: rest
  name: Tariff 41 Total Energy
  value_template: '{{ value_json.emeters.1.total | float /1000 }}'
  scan_interval: 300
Used in the Utility meter:
utility_meter:
  daily_light_and_power:
    source: sensor.tariff_31_total_energy
    cycle: daily
    tariffs:
      - peak
  daily_heating:
    source: sensor.tariff_41_total_energy
    cycle: daily
    tariffs:
      - offpeak
You can omit the tariff configuration. I only needed it as you cant use the reset service without them and testing required a bit of resetting.
All of this shenanigans could have been avoided if Shelly provided a daily energy used total. Like every other freaking smart power meter on the market.
Mine arrived today and I’ve just connected it up. I skipped the app, and just connected to its wifi network and used the web interface, which allowed me to connect it to my main network.
I enabled MQTT, and I can see that it’s publishing nice values – perhaps because I’ve just updated the firmware? But anyway, I get
shellies/shellyem-B9F368/online
shellies/shellyem-B9F368/relay/0
shellies/shellyem-B9F368/emeter/0/power
shellies/shellyem-B9F368/emeter/0/reactive_power
shellies/shellyem-B9F368/emeter/0/voltage
shellies/shellyem-B9F368/emeter/0/energy
shellies/shellyem-B9F368/emeter/0/returned_energy
and the same for channel 1.
The power values seem to be in watts - at least, they look plausible and correspond to those shown as watts in the web interface.
Thanks for the hints about the REST interface…
Yeah power units are ok. It’s the energy units that are weird.
https://shelly-api-docs.shelly.cloud/#shelly-em
I think the conversion factor from [W/min] to [KWh] is 60000, and not 6000 as scripted some post above.
Indeed the value template should be:
Yeah you’re right but I didn’t end up using those sensors anyway.
Have tried to make rest sensor with utility meter from a shelly plug s.
All validates but the rest sensor has status unknown. I don´t use username and password on mina.
Anyone that has some tips.
What do you see when you visit this web page:
http://[shelly_ip_address]/status
If i just want to one sensor with utility meter shall I use
value_template: ‘{{ value_json.emeters.1.total | float /1000 }}’
or
value_template: ‘{{ value_json.emeters.0.total | float /1000 }}’
Neither of them. Those templates are for the shelly EM.
This is the information for the shelly plug s:
https://shelly-api-docs.shelly.cloud/#shelly-plug-plugs-settings
“wifi_sta”:{“connected”:true,“ssid”:“Michaels Wi-Fi-nätverk”,“ip”:“10.0.1.225”,“rssi”:-75},“cloud”:{“enabled”:false,“connected”:false},“mqtt”:{“connected”:true},“time”:“08:44”,“serial”:1,“has_update”:false,“mac”:“2CF432267F9D”,“relays”:[{“ison”:true,“has_timer”:false,“overpower”:false}],“meters”:[{“power”:0.00,“is_valid”:true,“timestamp”:1576831462,“counters”:[0.000, 0.000, 0.000],“total”:19258}],“temperature”:34.63,“overtemperature”:false,“tmp”:{“tC”:34.63,“tF”:94.34, “is_valid”:“true”},“update”:{“status”:“idle”,“has_update”:false,“new_version”:“20191216-090549/v1.5.7@c30657ba”,“old_version”:“20191216-090549/v1.5.7@c30657ba”},“ram_total”:50792,“ram_free”:38840,“fs_size”:233681,“fs_free”:174445,“uptime”:140317}
value_template: '{{ value_json.meters.0.total | float /1000 }}'
Tried exactly that but not luck. It validates but sensors don´t show anything.
Post your whole (correctly formatted) sensor config here.
First a rest sensor
'- platform: rest
resource: http://10.0.1.225/status
value_template: ‘{{ value_json.meters.total | float /1000 }}’
unit_of_measurement: kWh´
Then the daily and mountly
'utility_meter:
daily_energy:
source: sensor.element_loft_kwh
cycle: daily
monthly_energy:
cycle: monthly
daily_energy_tvattmaskin:
source: sensor.tvattmaskin_energy
cycle: daily
monthly_energy_tvattmaskin:
cycle: monthly’
Never mind the other one its a z-wave and its working
Hi all
I’m trying too to have the Shelly plug S work with utility meter, but with no success.
The Shelly power sensor is based on mqtt and it works.
I’m using sensor.shelly_plug_s_041662_power_0
Then I have added the configuration as @Michael_Roxin but the utility meter sensor are not created.
  frigo_daily:
    source: sensor.shelly_plug_s_041662_power_0
    cycle: daily
    tariffs:
      - day
      - night
  frigo_monthly:
    cycle: monthly
    tariffs:
      - day
      - night
Any suggestion?
I have not figured this out, my daily and mounthly sensor always just shows 0.
Shelly EM latest firmware now send the Total via MQTT in Wh
